06-21-2013, 23:06 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Imei repair i9505 no read phone How to: - Cable UART C3300K - Select com port box in ST software - Press *#7284# and select "Modem" (Only show one option interface "UART") *default setting: "PDA" - Press *#9090# and select "4 - DM over UART" *default setting: "DM/DUN over HS-USB" read unlock codes Cable perfect, read others phone. 18:06:05 > SAMSUNG I9505 REPAIR IMEI: START! 18:06:09 > SEARCHING FOR PHONE: ERROR! 18:06:10 > READING MODEL: ERROR 1001! 18:06:10 > SAMSUNG I9505 REPAIR IMEI: END! |
06-24-2013, 15:16 | #4 (permalink) | |
No Life Poster Join Date: Jan 2001 Location: StarSystem
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | Quote:
Hello, is not a realtime support here .. you just need to wait until we see it, and we not work in week end ! about your problem, what is "ST" software you mention ? in microbox, take last update of software, pres IMEI repair .. and when Software search phone , restart phone , then he will detect it and make the job BR | |
06-24-2013, 18:25 | #5 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | 13:24:04 > PORT: COM7 USB Serial Port SPEED: 921600 13:24:04 > SAMSUNG I9505 READ CODES: START! 13:24:09 > DETECTING PHONE: OK! 13:24:53 > WAITING FOR ANSWER: OK! 13:25:04 > SETTING TEST MODE: OK! 13:25:05 > READING MODEL: ERROR 1001! 13:25:05 > WAITING FOR ANSWER: 13:25:05 > SAMSUNG I9505 READ CODES: END! For repair imei 13:28:50 > PORT: COM7 USB Serial Port SPEED: 115200 13:28:50 > SAMSUNG I9505 REPAIR IMEI: START! 13:28:55 > SEARCHING FOR PHONE: ERROR! 13:28:57 > READING MODEL: ERROR 1001! 13:28:57 > SAMSUNG I9505 REPAIR IMEI: END! |
06-24-2013, 18:33 | #6 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | 13:31:47 > VERSION: MICRO-BOX A.I.O. V2.1.7.3 - MICRO-BOX connected 13:31:47 > BOX SN: AB942DXXXXXXXX02 BOX FW: 75 13:31:47 > PORT: COM7 USB Serial Port SPEED: 115200 13:31:47 > SAMSUNG I9505 READ CODES: START! 13:31:53 > DETECTING PHONE: OK! 13:32:40 > WAITING FOR ANSWER: OK! 13:32:51 > SETTING TEST MODE: OK! 13:32:53 > READING MODEL: ERROR 1001! 13:32:53 > WAITING FOR ANSWER: 13:32:53 > SAMSUNG I9505 READ CODES: END! |
06-24-2013, 19:04 | #7 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | 14:00:21 > VERSION: MICRO-BOX A.I.O. V2.1.7.3 - MICRO-BOX connected 14:00:21 > BOX SN: AB942DF85XXXX502 BOX FW: 75 14:00:21 > PORT: COM3 USB Serial Port SPEED: 115200 14:00:21 > SAMSUNG GALAXY S4 LTE READ CODES: START! 14:00:32 > DETECTING PHONE: OK! 14:00:47 > WAITING FOR ANSWER: OK! 14:00:59 > SETTING TEST MODE: OK! 14:00:59 > READING MODEL: OK! 14:00:59 > READING IMEI: OK! 14:00:59 > READING FIRMWARE INFO: OK! 14:00:59 > IMEI: 356891050XXXX07 14:00:59 > PLATFORM: ACEFWTAZ* 14:00:59 > Apr 13 2013 00:32:25 Mar 28 2013 09:00:00 14:00:59 > BUILD: M9615A-CEFWTAZM-4.0.17062 14:00:59 > READING DATA: OK! 14:01:00 > CHECKING SERVER 1: OK! 14:01:00 > CONNECTING TO SERVER: OK! 14:01:02 > ASKING SERVER FOR ACCESS: ACCEPTED! 14:01:02 > SENDING DATA TO SERVER: OK! 14:01:09 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 14:01:09 > DISCONNECTING FROM SERVER: OK! 14:01:09 > NET CODE: 00000000 14:01:09 > SUBS CODE: 00000000 14:01:09 > CP CODE: 00000000 14:01:09 > SP CODE: 00000000 14:01:09 > SAMSUNG GALAXY S4 LTE READ CODES: END! 14:01:27 > VERSION: MICRO-BOX A.I.O. V2.1.7.3 - MICRO-BOX connected 14:01:27 > BOX SN: AB942DF8XXXXX502 BOX FW: 75 14:01:27 > PORT: COM3 USB Serial Port SPEED: 115200 14:01:27 > SAMSUNG GALAXY S4 LTE REPAIR IMEI: START! 14:01:27 > SEARCHING FOR PHONE: OK! 14:01:27 > READING MODEL: OK! 14:01:27 > READING IMEI: OK! 14:01:27 > READING FIRMWARE INFO: OK! 14:01:27 > IMEI: 356891050XXXX07 14:01:27 > PLATFORM: ACEFWTAZ* 14:01:27 > Apr 13 2013 00:32:25 Mar 28 2013 09:00:00 14:01:27 > BUILD: M9615A-CEFWTAZM-4.0.17062 14:01:27 > NEW IMEI: 356391150XXXX07 14:01:27 > WRITING DATA: OK! 14:01:27 > SAMSUNG GALAXY S4 LTE REPAIR IMEI: END! But no repair imei 14:05:08 > PORT: COM3 USB Serial Port SPEED: 115200 14:05:08 > SAMSUNG I9505 READ CODES: START! 14:05:20 > DETECTING PHONE: OK! 14:05:34 > WAITING FOR ANSWER: OK! 14:05:45 > SETTING TEST MODE: OK! 14:05:45 > READING MODEL: OK! 14:05:45 > READING IMEI: OK! 14:05:45 > READING FIRMWARE INFO: OK! 14:05:45 > IMEI: 356891050XXXX07 14:05:45 > PLATFORM: ACEFWTAZ* 14:05:45 > Apr 13 2013 00:32:25 Mar 28 2013 09:00:00 14:05:45 > BUILD: M9615A-CEFWTAZM-4.0.17062 14:05:46 > READING DATA: OK! 14:05:46 > CHECKING SERVER 1: OK! 14:05:47 > CONNECTING TO SERVER: OK! 14:05:48 > ASKING SERVER FOR ACCESS: ACCEPTED! 14:05:49 > SENDING DATA TO SERVER: OK! 14:05:57 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 14:05:57 > DISCONNECTING FROM SERVER: OK! 14:05:57 > NET CODE: 00000000 14:05:57 > SUBS CODE: 00000000 14:05:57 > CP CODE: 00000000 14:05:57 > SP CODE: 00000000 14:05:57 > SAMSUNG I9505 READ CODES: END! 14:06:03 > VERSION: MICRO-BOX A.I.O. V2.1.7.3 - MICRO-BOX connected 14:06:03 > BOX SN: AB942DFXXXX502 BOX FW: 75 14:06:03 > PORT: COM3 USB Serial Port SPEED: 115200 14:06:03 > SAMSUNG I9505 REPAIR IMEI: START! 14:06:03 > SEARCHING FOR PHONE: OK! 14:06:03 > READING MODEL: OK! 14:06:03 > READING IMEI: OK! 14:06:03 > READING FIRMWARE INFO: OK! 14:06:03 > IMEI: 356891050XXXX07 14:06:03 > PLATFORM: ACEFWTAZ* 14:06:03 > Apr 13 2013 00:32:25 Mar 28 2013 09:00:00 14:06:03 > BUILD: M9615A-CEFWTAZM-4.0.17062 14:06:03 > NEW IMEI: 356391150XXXX07 14:06:03 > WRITING DATA: OK! 14:06:03 > SAMSUNG I9505 REPAIR IMEI: END! Imei in phone is same, no change |
06-25-2013, 16:42 | #8 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | is not a realtime support, but no response, no solution, Honestly until today, I am not happy with this equipment. Worst investment and activation made by me |
06-25-2013, 17:05 | #9 (permalink) |
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | Sorry to read this i have one question you have other box for Samsung ? did you try them to repair your IMEI ? they was working ? ... BR |
06-25-2013, 20:19 | #10 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | Unfortunately the others who do not have it, it does put the microbox, but does the other box I have when they say they do they do, I'll buy one today z3x because she does have spt, octopus, and microbox for samsung ! I've had other problems with microbox, never solved, already posted bugs and all, not used to microbox many months, never really works, but I'm willing to be beta tester and help a lot to microbox, as do many devices per day , and unlock upgrades, updates Sorry my english |
06-25-2013, 21:23 | #11 (permalink) |
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | Hi, i dont think you can be beta tester, you take almost 2 days just to manage connect phone to software , when is nothing complicate to be done .. anyway , thx for your help BR |
06-26-2013, 06:29 | #12 (permalink) | |
Member: 211017 Status: Offline Thanks Meter: 312 | Quote:
If you think so, I'm posting the amount of appliances that repair in a day, still think I do not know? Search my post on your section and see your bugs not fixed! | |
The Following User Says Thank You to turca For This Useful Post: |
06-26-2013, 09:00 | #13 (permalink) |
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | you say you not have other box ... then you say you have other box ... i am happy for you if you have much work to do, just beta tester is not just send software to test some .. is really someone with great experience what can help us in our work .. thank you anyway, and dont be angry |
06-26-2013, 16:19 | #14 (permalink) | |
