10-21-2008, 11:36 | #1 (permalink) |
Insane Poster Join Date: Jun 2005 Age: 45
Member: 151853 Status: Offline Thanks Meter: 7 | Log's problem SAGEM MY400X READ CODES: START! CONNECTING TO SERVER: OK! ASKING SERVER FOR ACCESS: ACCEPTED! GETTING CREDIT DATA FROM SERVER: OK! CREDIT USED: 9 CREDIT LIMIT: 10 SEARCHING FOR PHONE: NOT FOUND! SAGEM MY400X READ CODES: END! END TIME: 12:13:57 START TIME: 12:14:18 SAGEM MY400X READ CODES: START! CONNECTING TO SERVER: OK! ASKING SERVER FOR ACCESS: ACCEPTED! GETTING CREDIT DATA FROM SERVER: OK! CREDIT USED: 9 CREDIT LIMIT: 10 SEARCHING FOR PHONE: FOUND! READING FIRMWARE INFO: OK! READING HASH TABLE INFO: OK! READING IMEI: OK! READING MODEL INFO: OK! PRESS POWER: OK! READING CPU INFO: OK! LOADING CERTIFICATE: OK! LOADING APPLICATION: OK! READING DATA: OK! DISCONNECTING PHONE: OK! CONNECTING TO SERVER: OK! ASKING SERVER FOR ACCESS: ACCEPTED! SENDING PHONE DATA TO SERVER: OK! GETTING CREDIT DATA FROM SERVER: OK! CREDIT USED: 10 CREDIT LIMIT: 10 ATTENTION! LOW CREDIT! YOU MUST BUY MORE CREDIT! SAGEM MY400X READ CODES: END! PHONE INFO: MODEL : my401X IMEI : 352911012237758 FIRMW. : LE5,BF: 090306 1739 HT. : 281501 CPU : CALYPSO HS END TIME: 12:16:43 That was my last log , what happend ? why don't calculate the codes ? |
10-21-2008, 15:00 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | try now with the Get Codes option to see if the server has your code, if not then you will have to wait for a product supporter to see this, luck |
Converter log's for Mt,M50 to calculate in Maxim | bart3 | x1x to x45/x50 | 4 | 12-04-2002 21:39 |
the result of calculate not same with two 'all sagem calculate by log' | raino | Infineon C16X M51 & ARM7 M52 BASED | 16 | 11-11-2002 07:23 |
3 x C45 log's | Saulyss | Phone Unlocking Codes & Maps | 4 | 10-19-2002 11:01 |
LOg's And Map's How Does it Work | SoftSkiner | GSM Programming & Reverse Engineering | 4 | 06-06-2002 03:33 |
LOG'S FOR SIEMENS ALL MODELS | JAMLU | Main Sales Section | 0 | 02-21-2002 00:30 |
