07-07-2015, 11:40 | #1 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2423766 Status: Offline Thanks Meter: 0 | Micro-Box Pro: Asking Server for access - NOT ACCEPTED [SOLVED] I have Micro-Box Pro and I am using the AIO V2.1.8.0 Software I have sucessfully installed the drivers and got the box to communicate with the software however I cant get it to connect to the server... When clicking 'Update Box' I get this; 11:36:21 > LOADING LIBUSB: OK! 11:36:28 > RESETING BOX: OK! 11:36:30 > SEARCHING FOR BOX: FOUND MICRO-BOX PRO! 11:36:30 > READING MICRO-BOX PRO SN: OK! 11:36:30 > READING MICRO-BOX PRO VERSIONS: OK! 11:36:30 > READING ACTIVATIONS FROM BOX: OK! 11:36:31 > MICRO-BOX PRO SN: 0106CA82050000FB 11:36:31 > MICRO-BOX PRO FW: 200 11:36:31 > BOOT VERSION: 60 11:36:31 > READ BOX INFO: END! 11:36:31 > UPDATE BOX: START! 11:36:31 > CHECKING SERVER 1: OK! 11:36:31 > CONNECTING TO SERVER: OK! 11:36:32 > ASKING SERVER FOR ACCESS: NOT ACCEPTED! NOT IN SERVER! 11:36:32 > DISCONNECTING FROM SERVER: OK! 11:36:32 > UPDATE BOX: END! 11:36:32 > READ BOX INFO: START! 11:36:33 > LOADING LIBUSB: OK! 11:36:35 > SEARCHING FOR BOX: FOUND MICRO-BOX PRO! 11:36:36 > READING MICRO-BOX PRO SN: OK! 11:36:36 > READING MICRO-BOX PRO VERSIONS: OK! 11:36:36 > READING ACTIVATIONS FROM BOX: OK! 11:36:38 > READING CARD ATR: OK! 11:36:38 > READING CARD SN: OK! 11:36:39 > READING CARD VERSION: OK! 11:36:39 > READING CARD AGE: OK! 11:36:39 > READING CARD ACTIVATION: OK! 11:36:39 > READING CARD REGISTRATION: OK! 11:36:40 > MICRO-BOX PRO SN: 0106CA82050000FB 11:36:40 > MICRO-BOX PRO FW: 200 11:36:40 > BOOT VERSION: 60 11:36:40 > CARD SN. : 78BD554C 11:36:40 > CARD VERS. : 2.00 11:36:40 > CARD REG. : 0106CA82050000FB 11:36:40 > CARD AGE: 19 11:36:40 > ALCATEL: ACTIVATED! 11:36:40 > BLACKBERRY: ACTIVATED! 11:36:40 > HTC: ACTIVATED! 11:36:40 > LG: ACTIVATED! 11:36:40 > SAGEM: ACTIVATED! 11:36:40 > READ BOX INFO: END! 11:36:40 > SYNC WITH SERVER: START! 11:36:41 > READING ACTIVATIONS FROM BOX: OK! 11:36:41 > READING MICRO-BOX PRO SN: OK! 11:36:41 > MICRO-BOX PRO SN: 0106CA82050000FB 11:36:41 > CHECKING SERVER 1: OK! 11:36:42 > CONNECTING TO SERVER: OK! 11:36:42 > ASKING SERVER FOR ACCESS: NOT ACCEPTED! NOT IN SERVER! 11:36:42 > SYNC WITH SERVER: END! 11:36:42 > WRITING ACTIVATIONS IN BOX: START! 11:36:43 > BOX SN. : 0106CA82050000FB 11:36:43 > CHECKING SERVER 1: OK! 11:36:43 > CONNECTING TO SERVER: OK! 11:36:44 > ASKING SERVER FOR ACCESS: NOT ACCEPTED! NOT IN SERVER! 11:36:44 > DISCONNECTING FROM SERVER: OK! 11:36:44 > WRITING ACTIVATIONS IN BOX: END! 11:36:45 > CONNECT TO BOX: START! 11:36:46 > LOADING LIBUSB: OK! 11:36:48 > SEARCHING FOR BOX: FOUND MICRO-BOX! 11:36:48 > READING MICRO-BOX SN: OK! 11:36:48 > READING MICRO-BOX VERSIONS: OK! 11:36:51 > LOADING LIBUSB: OK! 11:37:13 > RESETING BOX: ERROR 1003! when clicking sync with server; 11:39:33 > ATTENTION! SYNC WITH SERVER REQUIRED! 11:39:44 > SYNC WITH SERVER: START! 11:39:44 > READING ACTIVATIONS FROM BOX: OK! 11:39:45 > READING MICRO-BOX PRO SN: OK! 11:39:45 > MICRO-BOX PRO SN: 0106CA82050000FB 11:39:45 > CHECKING SERVER 1: OK! 11:39:45 > CONNECTING TO SERVER: OK! 11:39:46 > ASKING SERVER FOR ACCESS: NOT ACCEPTED! NOT IN SERVER! 11:39:46 > SYNC WITH SERVER: END! Thanks for any help Darius |
07-07-2015, 11:47 | #2 (permalink) | |
No Life Poster Join Date: Sep 2003 Location: Right There ( Croatia )
Member: 38150 Status: Offline Sonork: 100.1611516 Thanks Meter: 143 | @dariuscov Quote:
Try Download and install last AIO 3.0.0.8 wich you can find there or there Just unzip and put in same folder where is AIO wich you have right now BR Mario | |
07-07-2015, 12:08 | #4 (permalink) | |
In my post is 2 time used words " there " you just need to click on words "there " and you will be redirect to download site | |
07-07-2015, 14:13 | #5 (permalink) | |
Member: 2423766 Status: Offline Thanks Meter: 0 | Quote:
14:06:24 > Reading ACTIVATIONS: OK! 14:06:25 > Checking server 1: OK! 14:06:26 > Connecting to server: OK! 14:06:27 > Asking server for access: ERROR! NOT ACCEPTED! 14:06:27 > NOT IN SERVER! 14:06:27 > Disconnecting from server: OK! 14:06:27 > SYNC WITH SERVER: END! that still doesnt work | |
