05-14-2008, 20:20 | #16 (permalink) |
Freak Poster Join Date: Dec 2005 Age: 61
Member: 206710 Status: Offline Thanks Meter: 13 | yesterday I received my Micro-Box and today I tried to update box to be able use new update software but I have same problem of window updater disappear even if firewall and antivirus are disable, same problem in my laptop and desk both with XP pro sp3. Please have you a solution to fix my box? Now is useless... see attached picture. Best Regards kiricu |
05-14-2008, 22:38 | #17 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Tunisia Age: 43
Member: 40632 Status: Offline Sonork: 98231 Thanks Meter: 1,658 | Quote:
Hi m8, plz use updater2.exe and be sure to remove all connected dongles and stop unnecessery running applications on background. | |
05-15-2008, 17:02 | #18 (permalink) | |
Member: 206710 Status: Offline Thanks Meter: 13 | Quote:
Hi, thanks for your answer, but after unistall all software antivirus, antispyware and firewall I'm not able to make update in my box. I used msconfig to close all prog at startup and services also but not lucky. Please can you advise what is the right configuration on msconfig (xp pro sp3) to be able to run the updater2? Thanks for your time and sorry if I bother you again. Best Regards kiricu | |
05-15-2008, 17:21 | #19 (permalink) | |
05-15-2008, 17:29 | #20 (permalink) |
Member: 206710 Status: Offline Thanks Meter: 13 | Hi, you are right!!! thanks for your answer, but I don't know how because nothing appears when the box updated. Anyway, just now tried samsung the latest and its working, prog is opening. I hope for the next update all will be OK. Thank you again kiricu |
05-15-2008, 18:08 | #21 (permalink) |
Member: 206710 Status: Offline Thanks Meter: 13 | Hi, found the problem, if I plug and unplug usb cable box do the reset otherwise all softwares cannot detected the box, see attached. Please, fix the bug its not so good to unplug the usb cable if I change from Alcatel to LG for example. What about LG U880? Thank you and BR kiricu |
The Following User Says Thank You to kiricu For This Useful Post: |
05-17-2008, 15:46 | #22 (permalink) |
Major Poster Join Date: Apr 2008
Member: 739757 Status: Offline Thanks Meter: 2 | I have an other problem, when I open Updater_2.exe the window also dissapears vey fast I tried on 2 computers without antivirus or firewall when I open the soft for the micro-box I always get :" NOT FOUND" the loading bar goes to 100% then not found, I can't install the driver, windows xp said the drivers are not properly correct for this material : I also installed manually microbox.inf but nothing works windows detects the material because I get the usb sound when I plug it then the assistant for setup new material is openning but I can't install the driver with it... I'm going crazy, nobody had experienced my problem ? |
05-17-2008, 19:25 | #23 (permalink) |
Member: 739757 Status: Offline Thanks Meter: 2 | The hardware was not installed because the wizard cannot find the necessary software In English I get that message : "The hardware was not installed because the wizard cannot find the necessary software." please please please help me, maybe I don't have the good driver. I downloaded the file on http://www.micro-box.com/members/userform.htm huuuu please |
07-01-2008, 22:57 | #27 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
thanks salim | |
07-02-2008, 00:33 | #29 (permalink) | |
thanks salim | |
07-12-2008, 15:14 | #30 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Quote:
Any hope to solve my problem ? | |
setool3 first instalation steps | dance2009 | SETool2 | 9 | 02-04-2009 06:41 |
4/11/2008 MICROBOX first in world update Bic phone Added for FREEEEEEEEEE | samigsm78 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 15 | 11-25-2008 13:24 |
01/07/2008 Microbox Full installer package 1.0 | midou01 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 9 | 07-13-2008 15:17 |
MIcrobox First in World Updates New Stock Ready For Ship | samigsm78 | Main Sales Section | 0 | 07-01-2008 11:20 |
MC tool install step step... | BesTCooL | MC-Tool | 0 | 01-15-2008 22:55 |
