*** Microbox First Installation Steps *** To be able to use Microbox without problems you have to follow this steps when you use it for the first time:
PS:
Added in Support : Tutorial Helps :
If you have box detection problem follow this steps, thanks to @pakstar: Go to device manager. click on + with PORTS Double click on AVL VT port after installation with normal driver procedure, It will come under ports section. 1. Double click on allocated Port 2. Go to Drivers and select UPDATE driver. select YES THIS TIME ONLY 3. Choose "Install from List or specific Location". click NEXT 4. select "Don't search I will select the dirver to Install" and click NEXT 5. Now click on "SHOW COMPATIBLE DRIVER" and then Click "HAVE DISK" 6. NOW BROWSE to the folder where the orignaly drivers are present. Now you will see MICROBOX under the models.. select and next next next WBR |
The card that comes with the box do u open the box to put the card in or is the card for a dongle |
Yes you open the box inside have slot for sim card you put the card and close your box |
hi i have now checked my box and there's nothing like sim card in it thats why i cant update my box my reseller is ipmart what can i do |
u can update ur box with or without sim card br <= The_Gorr => |
pls can someone upload the latest update software here cos i cant login to support always login error thanks |
here is it http://rapidshare.com/files/10398216...ter_2.rar.html br <= The_Gorr => Quote:
box disconnect and connect pls help br atiefour-gsm |
freind, this can happen with some antivirus, firwell and some windows bug, so all what u have to do is : disable any antivirus and firwell, if still same, try on another os or computer and i'm sure it will work br <= The_Gorr => |
i have try on 4 pc thesame problem |
really strange, what about ur internet connexion !!* are u using a network connextion or connected directly with internet !! br <= The_Gorr => |
thanks:D |
and i talk about connexion of updater software :D br <= The_Gorr => |
this is what update software tells me trying to connect: ok ->01DDDB06DEC******X connecting server : ok check usb update check fw update then software disappear pls help tthanks |
