04-10-2014, 23:03 | #241 (permalink) |
Junior Member Join Date: Feb 2005 Location: toronto
Member: 120224 Status: Offline Thanks Meter: 4 | micro box driver problem for windows 7 64bit enterprise i was using microbox in window8 and was running good , now i changed to window 7 enterprise 64bit , now i am having problem its not starting up properly and imei code calulator field is deactive , Does micro box support windows7 64bit enterprise , i also tired with windows server 2008 r2 its not working in that too, kindly reply thanks |
04-11-2014, 08:38 | #242 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: RO, Nasaud
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Quote:
WBR, gsm9l | |
04-29-2014, 05:19 | #243 (permalink) |
Member: 120224 Status: Offline Thanks Meter: 4 | problem in installing micro box Hi Micro Box Team, well i am still having to use the micro box i install windows 7 64bit now and as u said to disable the driver enforcement i did through F8 option in boot menu but still the software is not opening in proper way,and i am unable to use it kindly help thanks |
04-29-2014, 08:43 | #244 (permalink) |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | -You must install latest drivers: http://www.micro-box.com/free_downlo...r_v1.2.7.0.rar -Also you must be sure digital signature is off (sometimes is moving to on after restart - so check again) -And finaly run Micro-Box software as admin. If have problem contact me on sonork and will join with team viewer to do it. WBR, gsm9l |
The Following User Says Thank You to gsm9l For This Useful Post: |
04-30-2014, 23:15 | #245 (permalink) |
Member: 120224 Status: Offline Thanks Meter: 4 | still having problem in using microbox hi microbox, well i install the latest driver but still having problem , u talking about disable digital driving , can you tell me how can i disable digital driver singing in windows, i did with the following option but it does not work for me in windows 7 64 it, boot menue f8, disable enforcement driver and also tried with the following command bcdedit.exe -set loadoptions DDISABLE_INTEGRITY_CHECKS bcdedit.exe -set TESTSIGNING ON but does not work for me, i have install teamveiwer and sonork my sonork id is = 100.1655202 let me know the time so we can join thx |
08-01-2014, 17:04 | #247 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2232799 Status: Offline Thanks Meter: 0 | not found box hello I am new to the forums is I hope you could help me thank you I have a setup with microbox is that I just bought problem. here I have followed the steps you described in the forums but it still does not function. I download and install: microbox drivers v1.2.7.0 then I connect my microbox I download and run MICRO-box micro box dongle & sn read I run MICRO-box micro box dongle & sn read I read is this message : not found box |
08-01-2014, 17:30 | #248 (permalink) | |
No Life Poster Join Date: Nov 2010 Location: THE MOBILE SHOP
Member: 1432329 Status: Offline Sonork: 100.1615863 Thanks Meter: 1,626 | Quote:
The Following User Says Thank You to sunilkumar70791 For This Useful Post: |
08-01-2014, 17:45 | #249 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2232208 Status: Offline Thanks Meter: 1 | I'm new to micro box help me hie i need to use my micro box but i'm struggling to make it work please help below is the screen log 18:08:38 > ATTENTION! SYNC WITH SERVER REQUIRED! 18:08:42 > READ BOX INFO: START! 18:08:43 > LOADING LIBUSB: OK! 18:08:44 > SEARCHING FOR BOX: FOUND MICRO-BOX! 18:08:44 > READING MICRO-BOX SN: OK! 18:08:44 > READING MICRO-BOX VERSIONS: OK! 18:08:44 > READING ACTIVATIONS FROM BOX: DONE! NO ACTIVATION FOUND! 18:08:44 > MICRO-BOX SN: 175578xxxxx42880 18:08:44 > MICRO-BOX FW: 75 18:08:44 > BOOT VERSION: 50 18:08:44 > ALCATEL: NOT ACTIVATED! 18:08:44 > BLACKBERRY: NOT ACTIVATED! 18:08:45 > HTC: NOT ACTIVATED! 18:08:45 > LG: NOT ACTIVATED! 18:08:45 > SAGEM: NOT ACTIVATED! 18:08:45 > READ BOX INFO: END! 18:09:48 > READ BOX INFO: START! 18:09:49 > LOADING LIBUSB: OK! 18:09:50 > SEARCHING FOR BOX: FOUND MICRO-BOX! 18:09:51 > READING MICRO-BOX SN: OK! 18:09:51 > READING MICRO-BOX VERSIONS: OK! 18:09:51 > READING ACTIVATIONS FROM BOX: DONE! NO ACTIVATION FOUND! 18:09:51 > MICRO-BOX SN: 175578xxxxx42880 18:09:51 > MICRO-BOX FW: 75 18:09:51 > BOOT VERSION: 50 18:09:51 > READ BOX INFO: END! 18:09:51 > UPDATE BOX: START! 18:09:52 > CHECKING SERVER 1: OK! 18:09:53 > CONNECTING TO SERVER: OK! 18:09:54 > ASKING SERVER FOR ACCESS: NOT ACCEPTED! NOT IN SERVER! 18:09:54 > DISCONNECTING FROM SERVER: OK! 18:09:54 > UPDATE BOX: END! 18:09:54 > READ BOX INFO: START! 18:09:55 > LOADING LIBUSB: OK! 18:09:57 > SEARCHING FOR BOX: FOUND MICRO-BOX! 18:09:57 > READING MICRO-BOX SN: OK! 18:09:57 > READING MICRO-BOX VERSIONS: OK! 18:09:57 > READING ACTIVATIONS FROM BOX: DONE! NO ACTIVATION FOUND! 18:09:57 > MICRO-BOX SN: 175578xxxxx42880 18:09:57 > MICRO-BOX FW: 75 18:09:57 > BOOT VERSION: 50 18:09:57 > ALCATEL: NOT ACTIVATED! 18:09:57 > BLACKBERRY: NOT ACTIVATED! 18:09:57 > HTC: NOT ACTIVATED! 18:09:57 > LG: NOT ACTIVATED! 18:09:58 > SAGEM: NOT ACTIVATED! 18:09:58 > READ BOX INFO: END! 18:09:58 > SYNC WITH SERVER: START! 18:09:58 > READING ACTIVATIONS FROM BOX: DONE! NO ACTIVATION FOUND! 18:09:58 > READING MICRO-BOX SN: OK! 18:09:58 > MICRO-BOX SN: 175578xxxxx42880 18:09:59 > CHECKING SERVER 1: OK! 18:09:59 > CONNECTING TO SERVER: OK! 18:10:01 > ASKING SERVER FOR ACCESS: NOT ACCEPTED! NOT IN SERVER! 18:10:01 > SYNC WITH SERVER: END! 18:10:01 > WRITING ACTIVATIONS IN BOX: START! 18:10:01 > BOX SN. : 1755784857442880 18:10:02 > CHECKING SERVER 1: OK! 18:10:02 > CONNECTING TO SERVER: OK! 18:10:03 > ASKING SERVER FOR ACCESS: NOT ACCEPTED! NOT IN SERVER! 18:10:03 > DISCONNECTING FROM SERVER: OK! 18:10:03 > WRITING ACTIVATIONS IN BOX: END! 18:10:04 > CONNECT TO BOX: START! 18:10:05 > LOADING LIBUSB: OK! 18:10:07 > SEARCHING FOR BOX: FOUND MICRO-BOX! 18:10:07 > READING MICRO-BOX SN: OK! 18:10:07 > READING MICRO-BOX VERSIONS: OK! 18:10:10 > LOADING LIBUSB: OK! 18:10:12 > RESETING BOX: OK! 18:10:16 > SEARCHING FOR BOX: FOUND MICRO-BOX! 18:10:16 > READING MICRO-BOX SN: OK! 18:10:16 > READING MICRO-BOX VERSIONS: OK! 18:10:16 > READING ACTIVATIONS FROM BOX: DONE! NO ACTIVATION FOUND! 18:10:16 > MICRO-BOX SN: 175578xxxxx42880 18:10:16 > MICRO-BOX FW: 75 18:10:16 > BOOT VERSION: 50 18:10:16 > ALCATEL: NOT ACTIVATED! 18:10:17 > BLACKBERRY: NOT ACTIVATED! 18:10:17 > HTC: NOT ACTIVATED! 18:10:17 > LG: NOT ACTIVATED! 18:10:17 > SAGEM: NOT ACTIVATED! 18:10:17 > CONNECT TO BOX: END! 18:10:26 > SYNC WITH SERVER: START! 18:10:26 > READING ACTIVATIONS FROM BOX: DONE! NO ACTIVATION FOUND! 18:10:26 > READING MICRO-BOX SN: OK! 18:10:27 > MICRO-BOX SN: 1755784857442880 18:10:27 > CHECKING SERVER 1: OK! 18:10:27 > CONNECTING TO SERVER: OK! 18:10:29 > ASKING SERVER FOR ACCESS: NOT ACCEPTED! NOT IN SERVER! 18:10:29 > SYNC WITH SERVER: END! |
10-13-2014, 19:48 | #251 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Cochabamba Age: 38
Member: 87396 Status: Offline Thanks Meter: 64 | hello i am having this problem on info reader and updater dongle 14:46:14 > READ BOX INFO: START! 14:46:15 > SEARCHING FOR BOX: FOUND MICRO-DONGLE! 14:46:15 > READING MICRO-DONGLE SN: OK! 14:46:16 > READING MICRO-DONGLE VERSIONS: OK! 14:46:16 > READING ACTIVATIONS FROM BOX: OK! 14:46:22 > READING CARD ATR: ERROR 1001! 14:46:22 > READ BOX INFO: END! always the same when i try to open AIO it gets to reading ATR and then it closes it is a new dongle BTW |
10-14-2014, 22:41 | #255 (permalink) |
Member: 87396 Status: Offline Thanks Meter: 64 | i just tried on 2 more computers with different OS same result it is brand new i was trying to use it for the first time, ok i will contact ipmart |
setool3 first instalation steps | dance2009 | SETool2 | 9 | 02-04-2009 06:41 |
4/11/2008 MICROBOX first in world update Bic phone Added for FREEEEEEEEEE | samigsm78 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 15 | 11-25-2008 13:24 |
01/07/2008 Microbox Full installer package 1.0 | midou01 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 9 | 07-13-2008 15:17 |
MIcrobox First in World Updates New Stock Ready For Ship | samigsm78 | Main Sales Section | 0 | 07-01-2008 11:20 |
MC tool install step step... | BesTCooL | MC-Tool | 0 | 01-15-2008 22:55 |
