Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Micro-BoxTeam Products > Basic Micro-Box Software Support
Old 05-14-2008, 20:20   #16 (permalink)
kiricu's Avatar
Member: 206710
Hi Micro-Box Team,
yesterday I received my Micro-Box and today I tried to update box to be able use new update software but I have same problem of window updater disappear even if firewall and antivirus are disable, same problem in my laptop and desk both with XP pro sp3.
Please have you a solution to fix my box? Now is useless...
see attached picture.
Best Regards
kiricu
Old 05-14-2008, 22:38   #17 (permalink)
midou01's Avatar
Member: 40632
Sonork: 98231
Originally Posted by kiricu View Post
Hi Micro-Box Team,
Best Regards
kiricu
Hi m8, plz use updater2.exe and be sure to remove all connected dongles and stop unnecessery running applications on background.
Old 05-15-2008, 17:02   #18 (permalink)
kiricu's Avatar
Member: 206710
Hi,
thanks for your answer, but after unistall all software antivirus, antispyware and firewall I'm not able to make update in my box.
I used msconfig to close all prog at startup and services also but not lucky.
Please can you advise what is the right configuration on msconfig (xp pro sp3) to be able to run the updater2?
Thanks for your time and sorry if I bother you again.
Best Regards
kiricu
Old 05-15-2008, 17:21   #19 (permalink)
midou01's Avatar
Member: 40632
Sonork: 98231
Hi,
Best Regards
kiricu
Hi m8, sorry i didn't notice it at first time but your box is updated to latest fw version, you can check in your screenshot. You can use now all latest modules without problem so no need update
Old 05-15-2008, 17:29   #20 (permalink)
kiricu's Avatar
Member: 206710
Hi,
you are right!!!
thanks for your answer, but I don't know how because nothing appears when the box updated.
Anyway, just now tried samsung the latest and its working, prog is opening.
I hope for the next update all will be OK.
Thank you again
kiricu
Old 05-15-2008, 18:08   #21 (permalink)
kiricu's Avatar
Member: 206710
Hi,
found the problem, if I plug and unplug usb cable box do the reset otherwise all softwares cannot detected the box, see attached.
Please, fix the bug its not so good to unplug the usb cable if I change from Alcatel to LG for example.
What about LG U880?
Thank you and BR
kiricu
The Following User Says Thank You to kiricu For This Useful Post:
Old 05-17-2008, 15:46   #22 (permalink)
Member: 739757
I have an other problem, when I open Updater_2.exe the window also dissapears vey fast
I tried on 2 computers without antivirus or firewall
when I open the soft for the micro-box I always get :" NOT FOUND" the loading bar goes to 100% then not found, I can't install the driver, windows xp said the drivers are not properly correct for this material : I also installed manually microbox.inf but nothing works
windows detects the material because I get the usb sound when I plug it then the assistant for setup new material is openning but I can't install the driver with it...
I'm going crazy, nobody had experienced my problem ?
Old 05-17-2008, 19:25   #23 (permalink)
Member: 739757
The hardware was not installed because the wizard cannot find the necessary software
In English I get that message : "The hardware was not installed because the wizard cannot find the necessary software." please please please help me, maybe I don't have the good driver. I downloaded the file on http://www.micro-box.com/members/userform.htm
huuuu please
Old 05-18-2008, 21:36   #24 (permalink)
Member: 739757
sorry for all that posts, I have solved my problem thanks to the great support by the Micro box team !!! it's best team ever !
Old 05-24-2008, 14:19   #25 (permalink)
Member: 25589
tell us how you resolv your problem to know.
Thanks!
Old 05-24-2008, 22:56   #26 (permalink)
Member: 739757
I replied to your pm already
Old 07-01-2008, 22:57   #27 (permalink)
MUTUAL's Avatar
Member: 160928
i have same problem as u mate how u solve ur problem i just got micro box and i try to install drive but it said can not find driver very strange but i alredy download driver from micro box website i alredy try 3 computer all same please help me out guys
thanks
salim
Old 07-01-2008, 23:15   #28 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
me work fine on all my 2 pc at work and laptop also my pc athome work fine !
so i think you make mistake !
Old 07-02-2008, 00:33   #29 (permalink)
MUTUAL's Avatar
Member: 160928
thanks for reply but i dont know what i m doing wrong its not working fro and i have many software i install them all its work fine bro? i dont know i just can not install this?
thanks
salim
Old 07-12-2008, 15:14   #30 (permalink)
snsoftkiller's Avatar
Member: 250468
Sonork: 100.110362
thanks
salim
I have same problem too, windows says that the driver dont contain information for this hardware.
Any hope to solve my problem ?
setool3 first instalation steps dance2009 SETool2 9 02-04-2009 05:41
4/11/2008 MICROBOX first in world update Bic phone Added for FREEEEEEEEEE samigsm78 Basic Micro-Box Software Support 15 11-25-2008 12:24
01/07/2008 Microbox Full installer package 1.0 midou01 Basic Micro-Box Software Support 9 07-13-2008 15:17
MIcrobox First in World Updates New Stock Ready For Ship samigsm78 Main Sales Section 0 07-01-2008 11:20
MC tool install step step... BesTCooL MC-Tool 0 01-15-2008 21:55
Page generated in 1.34532 seconds with 12 queries
