01-22-2008, 11:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 36
Member: 137426 Status: Offline Thanks Meter: 50 | Microbox not working also not updating Why isnt it just working as it supposed to be or am i doing something wrong here. Cables also dont fit properly, need to remove plastic part and push really hard. Help needed |
01-22-2008, 12:07 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Tunisia Age: 43
Member: 40632 Status: Offline Sonork: 98231 Thanks Meter: 1,658 | If you have problem in unlocking alcatel E201 you have to: - Update your box firmware with updater2.exe (the new one that you can download from support area). To work with updater you have to close all running programms in background and firewalls. If you use it on laptop, plz change on a desktop because of power consumption is low on laptops. - For cables if it didn't work you can solder directly on phones pins. We are producing new cables for alcatel e207 that you will find very soon in your resseler. PS: you cannot unlock any new vle untill you update your box firmware so that's why you cannot boot it. |
01-22-2008, 12:40 | #3 (permalink) |
Member: 137426 Status: Offline Thanks Meter: 50 | I have updated with updater2 on another laptop so its good now. Still cant connect phone though. I will not solder wires on phone because i have so many to do. I expect it should work with the giving cable as i should be. I will try to unlock it and post result. |
01-22-2008, 12:58 | #4 (permalink) |
Member: 137426 Status: Offline Thanks Meter: 50 | can you post pinout from cable and phone for E201. When connection phone blue led just lights up a little bit, is that normal. Now phone doesnt turn when reading the codes but dont connect |
01-22-2008, 18:39 | #5 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 640944 Status: Offline Sonork: 100.62393 Thanks Meter: 6,965 | 1) Box Must Be Updated After you can open Software 2) Select Your model in the panel selct correct one if like E201 it s old vle 5 3 connect your cable be carrefull connect is not jsut enter the cable all pin must touch pcb if nothing touch for sure no communication 4 ) unlock your phone by code reader |
01-29-2008, 16:22 | #7 (permalink) |
Member: 640944 Status: Offline Sonork: 100.62393 Thanks Meter: 6,965 | There is Two Things you don t adjuste your cable perfectly ior your box yis not updated if not update To version 60 must update the box and if need cable original E201 ,E207 ,E101 check your resseller for buy one |
01-29-2008, 20:48 | #8 (permalink) |
Member: 40632 Status: Offline Sonork: 98231 Thanks Meter: 1,658 | yes right all microbox customers are unlocking new vle everyday, me also everyday i have many E221 or E207 to unlock, i used to solder directly on phone pins but with new cable it is really easy. If you don't want solder for the moment m8, ask your resseler for new cable, it already exists. |
02-03-2008, 16:39 | #12 (permalink) |
Member: 640944 Status: Offline Sonork: 100.62393 Thanks Meter: 6,965 | Your resellers have he just received i was sending to him cables few days ago perhaps he was busy and cannot check his mail ask him on msn or i will tell to him for contact you don t care man New update is under process will be release very soon for all micro box users br Micro box Team |
02-12-2008, 07:53 | #14 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Kumasi-Ghana
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | If you use it on laptop, plz change on a desktop because of power consumption is low on laptop please why can't we use laptop... power consumption is low on laptop... pls. xplain futher.. Thank Last edited by karikari; 02-12-2008 at 07:59. |
02-19-2008, 23:24 | #15 (permalink) | |
Member: 137426 Status: Offline Thanks Meter: 50 | Quote:
New cable is needed!!!!! | |
c168 SPEAKER AND MIC NOT WORKING . ALSO NEED ITS SCH | shahi | Motorola Hardware Repair | 10 | 10-06-2011 10:47 |
@DZstorm server not work also in tunisia plz check | LABOSSEF | SMTi | 2 | 03-19-2010 14:09 |
HWK not Work and not update | misal | HWK | 1 | 05-04-2009 10:21 |
