01-15-2010, 23:25 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 610285 Status: Offline Thanks Meter: 3 | Need help htc elf fail to read codes 22:15:52 > HTC ELF READ CODES: START! 22:15:53 > CONNECTING TO SERVER: OK! 22:15:54 > ASKING SERVER FOR ACCESS: ACCEPTED! 22:15:54 > CHECKING HTC_BB ACTIVATION: OK! 22:15:55 > HTC_BB: ACTIVATED 22:15:55 > CHECKING MBTOOL INSTALLATION: OK! 22:16:03 > SENDING WINDOWS MOBILE LOADER: ERROR 1005! 22:16:10 > RESTARTING PHONE: OK! 22:16:10 > HTC ELF READ CODES: END! |
The Following User Says Thank You to Master Bl4ster For This Useful Post: |
01-16-2010, 00:53 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | Install the archives that are in the HTC Micro-Box Tool in your HTC then try to read codes with Micro-Box Br, Tito Millo Micro-Box Team |
01-16-2010, 02:55 | #5 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: In code Age: 52
Member: 6321 Status: Offline Thanks Meter: 1,665 | Quote:
01-16-2010, 10:17 | #6 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Quote:
U can make hard Reset to Device Firstly and then proceed again | |
01-20-2010, 01:12 | #7 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: Djazair
Member: 111121 Status: Offline Sonork: 100.99340 : CrKdz13 Thanks Meter: 487 | Quote:
i have this message only with this model , all other works , and all tested : full bat , cable , cab installed , old versions of AIO also tested | |
01-20-2010, 03:17 | #8 (permalink) |
Freak Poster Join Date: Oct 2002 Location: Bulgaria Age: 49
Member: 16994 Status: Offline Thanks Meter: 157 | Try with this soft. First of all make hard reset! Steps : 1. Copy 'Cert_SPCS.cab' on your phone & install(run). 2. Copy 'EnableRapi.cab' on your phone & install(run). 3. Establish an Activesync connection with your phone. 4. Unzip the zip file & Run 'Unlock_Touch.exe' on your PC. ( New Unlocker) 5. File 'unlock_code.txt' thus generated will have your unlock code( Eight-digit number).Ignore any other digits if generated. |
01-20-2010, 06:23 | #10 (permalink) |
Member: 91045 Status: Offline Thanks Meter: 8,696 | Hi, Yes new ELf were ROm Dependable That unlocker will not work.. @Shaytan CrKdz13 ltd with Microbox Using last Version Uploading cab installing it ..then while Unlocking what Error u get ? Also post here the Current ELF ROM version inside Your Device |
01-20-2010, 23:00 | #11 (permalink) | |
error 1005! . | |
01-21-2010, 09:45 | #13 (permalink) |
No Life Poster Join Date: Apr 2008 Location: ♥ ♥ ♥ ♥ Age: 35
Member: 748880 Status: Offline Thanks Meter: 1,705 | Mr@Master Bl4ster - Get the active sync connection settings ready (right click active sync icon - connection settings) - First make sure usb connections are allowed and icon is green (connected) - Then start HTC code reading: - At this point in active sync immediately disable the allow usb connection option and press ok. - After this micro box software finally continues and reads the code: |
l6i Failed to read codes | yui | Smart-Clip | 26 | 06-11-2010 10:55 |
support team help my T456 trying to read codes. | ticksjarub | UST Pro II | 0 | 03-22-2010 10:03 |
Elco, where are you when we need help, A877 always failed to read unlock code | Unlockemall | NSPRO | 0 | 03-01-2010 08:12 |
hi v 88 failed to read code | unlock_solution | CPF-Dongle | 1 | 04-25-2009 01:34 |
L7i Fail to read code, Plz Help !!! | Speedy | Smart-Clip | 1 | 11-10-2007 09:27 |
