Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Micro-Box Team Products > Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...)
Old 09-26-2008, 14:11   #1 (permalink)
arwanis's Avatar
Member: 100185
Thanks Meter: 36
new micro-box installing problem
hi
i bought micro-box install drivers install application but when i tried to run any application its gave me error 1003 so i search in forum it says because of security reason bla bal change computer and try again so i did
but when i try another system its not detecting micro-box "searching for micro-box ............ not found" then one after one i tried 3 diffrent system no joy. then i tried again in first system its detecting but again same error 1003
i cant keep changing or buying system so if u have any suggestion plz reply soon
1 thing i wana mention that i register my box without accuring any problem
thanks
Old 09-26-2008, 18:01   #2 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,174
some time same to me but after unplug box 2 r3 time r system restart problem solv.
Old 09-26-2008, 18:03   #3 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,556
you have allot of box on same pc !!
clean your system driver the install driver box again
Old 09-30-2008, 08:19   #4 (permalink)
Member: 51453
Thanks Meter: 729
that is not the solution your just spamming forum.
br
The Following User Says Thank You to shawgsm For This Useful Post:
Old 09-30-2008, 09:50   #5 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,068
team,
please to this ERROR,
i want to buy this box but,i read so many error like this........
can you fix this????
Old 10-03-2008, 05:47   #6 (permalink)
cairnquay's Avatar
Member: 64893
Thanks Meter: 220
yes its true but i have found that when it says RESETTING BOX i disconnect box and reconnect box. Always success, try it and post here.
Old 10-04-2008, 07:29   #7 (permalink)
.::Skylinks::.'s Avatar
Member: 300354
Sonork: 100.1577485
Thanks Meter: 759
Micro-Box uses many Source of Computer so be Sure to Use better system instead of headack...!
Old 10-16-2008, 09:38   #8 (permalink)
kaiserstumm's Avatar
Member: 100770
Thanks Meter: 50
this solution is working!
Old 10-16-2008, 12:30   #9 (permalink)
Member: 575900
Thanks Meter: 3,174
This is not a proper solution. I will request Micro Box team to fix this problem. I am using seperate computer only for Macro Box but still I have the same problem.
Old 10-16-2008, 14:24   #10 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,515
i am using micro-box with in the same pc i have other tools installed, no problem so far and i have my OS installed since long ago, maybe there is a specific device causing this trouble.
Old 10-18-2008, 11:35   #11 (permalink)
pakstar's Avatar
Member: 59991
Thanks Meter: 40
hAVe you tried installing drivers manually as windows take these drivers as Digitally UNSIGNED and does not installs directly to system automatically.
Goto Device manager, double click on AVT LT port under PORTS + sign, now click on drivers tab, click on UPDATE driver, select THIS TIME ONLY, next, now select Do not install I will select driver myself,, now click on HAVE disk, click BROWSE ... now select folder where you unzip the installation drivers.. you will not see under models MICROBOX, choose and select , click next.. ignore the message you want to install unsigned driver etc...
click next.. now windows will install the driver.. properly.
good luck
The Following User Says Thank You to pakstar For This Useful Post:
Micro-Box Installer 2009 Edition arodney Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 14 09-27-2009 17:15
Micro-Box Installer arodney Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 10 08-27-2009 16:16
14-11-2008 Micro-Box Installer 2.4 hitibiti Service Products News & Updates 0 11-13-2008 23:57
Micro Box Installer - Full Package for Your Box ! Dengel Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 5 06-23-2008 00:08
Page generated in 0.36948 seconds with 8 queries
