09-27-2008, 10:23 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Portugal, Algarve
Member: 212823 Status: Offline Thanks Meter: 27 | Please help needed!! CAN NOT INSTALL!!!! (Solved) I have tried to install in dieferents hard drives and always get the same error pop up message, that says as follows: "C/Archivos de Programa/MicroBox/updater_2.exe An error ocurred while trying to reneme a file in the destination directory: Movefile failed; code 2. System can not find the specified file. Click retry to try again, ignore to skip this error (not recomended), or abort to exit instalation.". Can please someone help me with this issue??? why is happening this ???? Thanks in advance. Regards. Eskerra. |
The Following User Says Thank You to eskerra For This Useful Post: |
09-27-2008, 10:40 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Pakistan Age: 36
Member: 300354 Status: Offline Sonork: 100.1577485 Thanks Meter: 760 | First of all Updater_2.exe is Obsolete so it wont work...! One Question that other modules are working? if yes then download new updater from support & copy on your destination folder.. |
The Following User Says Thank You to .::Skylinks::. For This Useful Post: |
09-27-2008, 11:08 | #3 (permalink) |
Member: 212823 Status: Offline Thanks Meter: 27 | Skylinks, first thanks for replying. Then , to say that i am not installing Updater_2, I am just running main software installation, and i get that error. Just tested, right now, and yes, i can use modules separate, but not install main software "Micro Box Installer 2.0". Dou you know why that happens ???? Thanks. |
09-27-2008, 12:53 | #4 (permalink) |
Member: 300354 Status: Offline Sonork: 100.1577485 Thanks Meter: 760 | Which OS you are using? Some Times That Error Accure due to Untypical Installation & crupted exe or Viruses... So You have to Do These Steps if still hav,t Success.. 1: Download and Install "Micro Box Installer 2.0" From Support Again... 2: Make Installation in Default HD,s Sub Directry "Use Default Configratuation"... 3: Make Sure You have installed a better Antivirus in your Personal Computer.. 4: Make Sure Your pc is not Overload with FTDI Devices.. |
09-27-2008, 13:04 | #5 (permalink) |
Member: 212823 Status: Offline Thanks Meter: 27 | @ Skylinks: I Have done and I do have system working properly, just one thing doubt, and its: How to know if my system is or not overloaded with FTDI devices ???? I do have several boxes installed, but al least i do try to install them in a separate usb, for each one, and till now, every one is working properly, even yours, but is just that can not install the main software. żżżż??????? Thanks once more. Eskerra |
09-27-2008, 13:15 | #6 (permalink) | |
Member: 300354 Status: Offline Sonork: 100.1577485 Thanks Meter: 760 | Quote:
09-27-2008, 13:57 | #7 (permalink) |
Member: 212823 Status: Offline Thanks Meter: 27 | OK Skylinks. I just found out what was causing that trouble. Its name is : NOD 32. ( yes my antivirus) I just uninstall it and set up worked up like a charm. Just to let you know, and other users of course. Thanks so much for your time and help. I do now begin to use this "little surprise" box. Regards. Eskerra |
09-27-2008, 17:46 | #8 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | Quote:
thx for info but i use also nod32 on my pc and i can update the box without any problem | |
The Following User Says Thank You to hitibiti For This Useful Post: |
09-27-2008, 20:56 | #9 (permalink) |
Member: 212823 Status: Offline Thanks Meter: 27 | @ hitibiti, thanks, but my problem was not updating the box. Was just installing for first time the main software. Once i uninstall the NOD 32, I could then install the main software at the first try. Did not try to reinstall NOD 32 after, i did install one other antivirus. Maybe it helps someone else. Thanks and regards. Eskerra |
09-28-2008, 07:40 | #11 (permalink) | |
http:///vbb/showpo...08&postcount=4 You Only said that "i have done all" but no you did,t ... Anyway your problem is solved so i have to close thead and mention it as Solved... | |
Please help " can not Activating PinFinder Adapter | Audsky | Infinity-Box | 1 | 07-01-2008 14:20 |
please help i can not go to the support | zulea912 | SonyEricsson (USB-Smart) | 1 | 02-15-2006 20:39 |
Please help i can not read 8250 | fox | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 16 | 09-14-2001 19:12 |
