06-07-2011, 09:41 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: ...............
Member: 1104369 Status: Offline Sonork: 78954213 Thanks Meter: 14 | problem unlock GT-I9100 (2.3.3) [Solved] 09:37:33 > SAMSUNG I9100 READ CODES: START! 09:37:33 > KILLING ADB SERVER (IF RUNNING): OK! 09:37:33 > SEARCHING FOR PHONE: OK! 09:37:34 > READING INFO: OK! 09:37:34 > MODEL: GT-I9100 / GT-I9100 09:37:34 > IMEI: 35************* 09:37:34 > VERSION: 2.3.3 / GINGERBREAD 09:37:34 > FIRMWARE: GT-I9100-USER / I9100XXKDJ 09:37:34 > KERNEL: 2.6.35.7-I9100XWKE2-CL187606 (gcc 4.4.0) 09:37:34 > CPU TYPE: S5PC210 / ARMv7 09:37:40 > CHECKING ROOT: NOT ROOTED! 09:37:57 > RUNNING TEMP ROOT: OK! 09:37:57 > SEARCHING FOR PHONE: OK! 09:38:03 > CHECKING ROOT: NOT ROOTED! 09:38:03 > PLEASE RESTART PHONE AND TRY AGAIN! 09:38:03 > SAMSUNG I9100 READ CODES: END! |
06-07-2011, 09:56 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RO, Nasaud
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | You need to root the phone manual. This 2.3.3 version don't allow yet temp root and without root you can't unlock the phone Solutions: 1. root your phone first and try again 2. downgrade fw and try again WBR, gsm9l |
06-07-2011, 10:15 | #4 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | my friend,this is tutorial how to do it: -visit this page http://www.addictivetips.com/mobile/...axy-s-2-i9100/ -same pictures how to: and finally UNLOCK CODE Micro box best tool in Business |
The Following 9 Users Say Thank You to galijus For This Useful Post: |
06-07-2011, 10:57 | #5 (permalink) | |
Member: 1104369 Status: Offline Sonork: 78954213 Thanks Meter: 14 | yes unlock ok . Quote:
06-16-2011, 10:49 | #6 (permalink) | |
Freak Poster Join Date: Nov 2007 Location: Craiova, Romania Age: 45
Member: 633967 Status: Offline Thanks Meter: 24 | Quote:
Very good solution. workit like a charm Thanks | |
06-18-2011, 23:07 | #7 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Proud To Be A Muslim Age: 39
Member: 434968 Status: Offline Sonork: 100.1590883 Thanks Meter: 580 | keep it up good job ....nice infm unlock done smae too keep it up mirco team 02:49:16 > SAMSUNG GALAXY S2 READ CODES: END! 03:00:41 > VERSION MICRO-BOX A.I.O. V2.0.1.6 03:00:41 > SAMSUNG GALAXY S2 READ CODES: START! 03:00:42 > KILLING ADB SERVER (IF RUNNING): OK! 03:00:42 > SEARCHING FOR PHONE: OK! 03:00:43 > READING INFO: OK! 03:00:43 > MODEL: GT-I9100 / GT-I9100 03:00:43 > IMEI: 355310044344871 03:00:43 > VERSION: 2.3.3 / GINGERBREAD 03:00:43 > FIRMWARE: GT-I9100-USER / I9100BOKD1 03:00:43 > KERNEL: 2.6.35.7-I9100XWKDD-CL161513 (gcc 4.4.0) 03:00:43 > CPU TYPE: S5PC210 / ARMv7 03:00:44 > CHECKING ROOT: OK! 03:01:02 > READING DATA: OK! 03:01:03 > CHECKING SERVER 1: OK! 03:01:03 > CONNECTING TO SERVER: OK! 03:01:04 > ASKING SERVER FOR ACCESS: ACCEPTED! 03:01:06 > SENDING DATA TO SERVER: OK! 03:01:12 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 03:01:12 > FREEZE CODE: 00000000 03:01:12 > NET CODE: 90470494 03:01:12 > SP CODE: 00000000 03:01:12 > CP CODE: 00000000 03:01:12 > SIM CODE: 00000000 03:01:12 > DISCONNECTING FROM SERVER: OK! 03:01:13 > SAMSUNG GALAXY S2 READ CODES: END! |
The Following User Says Thank You to diljan_07 For This Useful Post: |
08-03-2011, 16:57 | #11 (permalink) |
No Life Poster Join Date: May 2006
Member: 275689 Status: Offline Thanks Meter: 64 | im trying to unlock i9100, and it cant find codes!!!! why? 16:53:22 > VERSION MICRO-BOX A.I.O. V2.0.2.3 16:53:22 > SAMSUNG I9100 READ CODES: START! 16:53:23 > KILLING ADB SERVER (IF RUNNING): OK! 16:53:24 > SEARCHING FOR PHONE: OK! 16:53:24 > READING INFO: OK! 16:53:25 > MODEL: GT-I9100 / GT-I9100 16:53:25 > IMEI: 358537044917804 16:53:25 > VERSION: 2.3.3 / GINGERBREAD 16:53:25 > FIRMWARE: GT-I9100-USER / I9100NEKF2 16:53:25 > KERNEL: 2.6.35.7-I9100XWKDD-CL161513 (gcc 4.4.0) 16:53:25 > CPU TYPE: S5PC210 / ARMv7 16:53:26 > CHECKING ROOT: OK! 16:53:44 > READING DATA: OK! 16:53:45 > CHECKING SERVER 1: OK! 16:54:06 > CONNECTING TO SERVER: SOCKET ERROR # 10060 CONNECTION TIMED OUT.! 16:54:06 > DISCONNECTING FROM SERVER: OK! 16:54:09 > SAMSUNG I9100 READ CODES: END! 16:54:12 > VERSION MICRO-BOX A.I.O. V2.0.2.3 16:54:12 > SAMSUNG I9100 READ CODES: START! 16:54:12 > KILLING ADB SERVER (IF RUNNING): OK! 16:54:34 > SEARCHING FOR PHONE: OK! 16:54:34 > READING INFO: OK! 16:54:35 > MODEL: GT-I9100 / GT-I9100 16:54:35 > IMEI: 358537044917804 16:54:35 > VERSION: 2.3.3 / GINGERBREAD 16:54:35 > FIRMWARE: GT-I9100-USER / I9100NEKF2 16:54:35 > KERNEL: 2.6.35.7-I9100XWKDD-CL161513 (gcc 4.4.0) 16:54:35 > CPU TYPE: S5PC210 / ARMv7 16:54:38 > CHECKING ROOT: OK! 16:54:55 > READING DATA: OK! 16:55:11 > CHECKING SERVER 1: NOT OK! 16:55:13 > CHECKING SERVER 2: OK! 16:55:14 > CONNECTING TO SERVER: OK! 16:55:17 > ASKING SERVER FOR ACCESS: ACCEPTED! 16:55:18 > SENDING DATA TO SERVER: OK! 16:55:28 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 16:55:28 > CODES NOT FOUND! 16:55:28 > DISCONNECTING FROM SERVER: OK! 16:55:31 > SAMSUNG I9100 READ CODES: END! someone please help |
08-27-2011, 14:43 | #12 (permalink) |
Freak Poster Join Date: May 2005 Age: 59
Member: 147105 Status: Offline Thanks Meter: 8 | problem unlock i9000 15:42:17 > SAMSUNG I9100 READ CODES: START! 15:42:17 > KILLING ADB SERVER (IF RUNNING): OK! 15:42:17 > SEARCHING FOR PHONE: OK! 15:42:18 > READING INFO: OK! 15:42:18 > MODEL: GT-I9100 / GT-I9100 15:42:18 > IMEI: 358848045xxxxxx 15:42:18 > VERSION: 2.3.3 / GINGERBREAD 15:42:18 > FIRMWARE: GT-I9100-USER / I9100BOKG1 15:42:19 > KERNEL: 2.6.35.7-I9100XWKDD-CL161513 (gcc 4.4.0) 15:42:19 > CPU TYPE: S5PC210 / ARMv7 15:42:20 > CHECKING ROOT: OK! 15:42:37 > READING DATA: OK! 15:42:38 > CHECKING SERVER 1: OK! 15:42:38 > CONNECTING TO SERVER: OK! 15:42:39 > ASKING SERVER FOR ACCESS: ACCEPTED! 15:42:39 > SENDING DATA TO SERVER: OK! 15:42:41 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 15:42:41 > CODES NOT FOUND! 15:42:41 > DISCONNECTING FROM SERVER: OK! 15:42:43 > SAMSUNG I9100 READ CODES: END! |
08-27-2011, 16:45 | #13 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Guyana / USA
Member: 205897 Status: Offline Sonork: 100.1589406 Thanks Meter: 230 | Quote:
http://forum.gsmhosting.com/vbb/show....php?t=1321238 Sent from my HTC Glacier using Tapatalk | |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
