08-22-2014, 12:01 | #1786 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 12:59:44 > box sn: Box fw: 75 12:59:44 > port: Micro-box speed: 115200 12:59:44 > samsung i8190 unlock: Start! 12:59:45 > reading model: Ok! 12:59:45 > reading imei: Ok! 12:59:45 > reading version: Ok! 12:59:45 > model: Goldennfcxx 12:59:45 > imei: 35478505404990 12:59:45 > unlocking phone: Ok! 12:59:45 > for unlock use code: 00000000 12:59:46 > samsung i8190 unlock: End! |
08-26-2014, 13:51 | #1787 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | s5260 unlocked Code: 12:23:59 > SAMSUNG S5260 READ CODES: START! 12:23:59 > READING MODEL: OK! 12:23:59 > READING IMEI: OK! 12:23:59 > READING VERSION: OK! 12:24:00 > READING HARDWARE INFO: OK! 12:24:01 > READING EXTENDED INFO: OK! 12:24:01 > MODEL: GT-S5260 12:24:01 > IMEI: 3591150448xxxxx 12:24:01 > COUNTRY CODE: COA 12:24:02 > VERSION: BCM2133x_SW_Release_SI1.3.70.16_V26 12:24:02 > FIRMWARE: S5260XXKG2_OXFKG2 12:24:02 > HARDWARE: MP0.400 12:24:02 > MSL ADDRESS: RR3BB91230 12:24:02 > PHONE SN: 55680001907656 12:24:02 > BT ADDR: E4 B0 21 79 3A 0F 12:24:02 > DATE: 2011-08-01 12:24:02 > MEMORY NAME: K5W2G1HACI(S5260) 12:24:02 > CHECKING SERVER 1: OK! 12:24:03 > CONNECTING TO SERVER: OK! 12:24:05 > ASKING SERVER FOR ACCESS: ACCEPTED! 12:24:09 > SENDING DATA TO SERVER: OK! 12:24:25 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 12:24:25 > FREEZE CODE: 46906414 (Insert not accepted simcard press call and type the code) 12:24:25 > NET CODE: #7465625*638*04738042# 12:24:25 > SP CODE: #7465625*77*00000000# 12:24:25 > SIM CODE: #7465625*782*00000000# 12:24:25 > CP CODE: #7465625*27*00000000# 12:24:25 > DISCONNECTING FROM SERVER: OK! 12:24:25 > SAMSUNG S5260 READ CODES: END! |
08-26-2014, 13:53 | #1788 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | samsung e1200 unlocked done.. Code: 11:53:20 > VERSION: A.I.O. V2.1.8.0 - MICRO-BOX 11:53:20 > BOX SN: 98EA566C BOX FW: 75 11:53:20 > PORT: MICRO-BOX SPEED: 115200 11:53:20 > SAMSUNG E1200 TAT MODE READ CODES: START! 11:53:20 > INIT DATA: OK! 11:53:33 > DETECTING PHONE: OK! 11:53:34 > WAITING FOR TAT MODE: OK! 11:53:35 > READING MSL STATUS: OK! (ACTIVE) 11:53:35 > READING BLUETOOTH ADDRESS: OK! 11:53:35 > READING IMEI: OK! 11:53:35 > READING VERSION: OK! 11:53:35 > IMEI: 3577940533xxxxx 11:53:35 > FIRMWARE: E1200XFLF2 11:53:35 > HARDWARE: MP 0.500 11:53:35 > MSL ADDRESS: R21D79DZ5 11:53:37 > READING DATA: OK! 11:53:37 > BACKUPS\SAMSUNG\E1200 Tat Mode\3577940533xxxxx_SIMLOCK_2014_08_21_11_53_37.mbf 11:53:37 > SAVING BACKUP: OK! 11:53:37 > CHECKING DATA: OK! 11:53:37 > CALCULATING: OK! 11:53:37 > ~~~~~~~ CODES SET 1 ~~~~~~~ 11:53:37 > PHONE CODE: 1234 11:53:37 > MASTER CODE: 69686740 (UNFREEZE) 11:53:37 > NET CODE: #7465625*638*51746390# 11:53:37 > SUBS CODE: #7465625*782*00000000# 11:53:37 > SP CODE: #7465625*77*00000000# 11:53:37 > CP CODE: #7465625*27*00000000# 11:53:37 > SIM CODE: #7465625*746*00000000# 11:53:37 > ~~~~~~~ CODES SET 2 ~~~~~~~ 11:53:37 > PHONE CODE: 00000000 11:53:37 > MASTER CODE: 69686740 (UNFREEZE) 11:53:38 > NET CODE: #7465625*638*51746390# 11:53:38 > SUBS CODE: #7465625*782*00000000# 11:53:38 > SP CODE: #7465625*77*00000000# 11:53:38 > CP CODE: #7465625*27*00000000# 11:53:38 > SIM CODE: #7465625*746*00000000# 11:53:38 > ~~~~~~~ CODES SET 3 ~~~~~~~ 11:53:38 > PHONE CODE: 1234 11:53:38 > MASTER CODE: 51746390 (UNFREEZE) 11:53:38 > NET CODE: #7465625*638*51746390# 11:53:38 > SUBS CODE: #7465625*782*00000000# 11:53:38 > SP CODE: #7465625*77*00000000# 11:53:38 > CP CODE: #7465625*27*00000000# 11:53:38 > SIM CODE: #7465625*746*00000000# 11:53:39 > SAMSUNG E1200 TAT MODE READ CODES: END! |
09-07-2014, 09:17 | #1789 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | Samsung S5230 unlocked done Code: 11:06:29 > WARNING! PHONE NOT FOUND ON USB! 11:09:26 > VERSION: A.I.O. V2.1.8.0 - MICRO-BOX 11:09:26 > BOX SN: 98EA566C091B85D5 BOX FW: 75 11:09:26 > PORT: COM9 SAMSUNG USB Mobile Modem SPEED: 115200 11:09:26 > SAMSUNG S5230 READ CODES: START! 11:09:26 > READING MODEL: OK! 11:09:26 > READING IMEI: OK! 11:09:27 > READING VERSION: OK! 11:09:27 > READING HARDWARE INFO: OK! 11:09:28 > READING EXTENDED INFO: OK! 11:09:29 > SWITCHING TO DOWNLOAD MODE: OK! 11:09:31 > READING FLASH ID: OK! 11:09:31 > SETTING SPEED TO 115200: OK! 11:09:31 > MODEL: GT-S5230 11:09:31 > IMEI: 3598970445xxxxx 11:09:31 > COUNTRY CODE: SEB 11:09:31 > VERSION: SS_21331_Platform_SW_Release_SI1.3.10_V5.0 11:09:31 > FIRMWARE: S523MXXKE1 11:09:32 > HARDWARE: MP0.620 11:09:32 > MSL ADDRESS: R21C234QRS 11:09:32 > PHONE SN: 55220002078103 11:09:32 > BT ADDR: 38 0A 94 2B 08 BE 11:09:32 > DATE: 2011-05-26 11:09:32 > MEMORY ID: ECBA 11:09:32 > K522H1HACA(S5230) 11:09:35 > READING DATA: OK! 11:09:56 > CHECKING SERVER 1: NOT OK! 11:10:17 > CHECKING SERVER 2: NOT OK! 11:10:17 > CHECKING SERVER 3: OK! 11:10:17 > CONNECTING TO SERVER: OK! 11:10:18 > ASKING SERVER FOR ACCESS: ACCEPTED! 11:10:19 > SENDING DATA TO SERVER: OK! 11:10:21 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 11:10:21 > NET CODE: #7465625*638*00000000# 11:10:21 > CP CODE: #7465625*27*00000000# 11:10:21 > SP CODE: #7465625*77*00000000# 11:10:21 > SIM CODE: #7465625*782*00000000# 11:10:21 > FREEZE CODE: 08503925 (Insert not accepted simcard press call and type the code) 11:10:21 > DISCONNECTING FROM SERVER: OK! 11:10:21 > SAMSUNG S5230 READ CODES: END! |
09-19-2014, 09:59 | #1795 (permalink) |
Registered User Join Date: Feb 2006 Location: Ireland / Belarus
Member: 234917 Status: Offline Thanks Meter: 160 | SM-G3815 unlocked successfully 09:50:30 > Samsung SM-G3815 FACTORY UNLOCK: START! 09:50:30 > Checking server 1: OK! 09:50:31 > Connecting to server: OK! 09:50:32 > Asking server for access: OK! 09:50:34 > Getting credit from server: OK! 09:50:34 > CREDIT: 09:50:34 > USED: 6,00 09:50:34 > LIMIT: 6,00 09:50:34 > CREDIT SPECIAL: 09:50:34 > USED: 0 09:50:34 > LIMIT: 10 09:50:34 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! 09:50:37 > Searching for phone: OK! 09:50:38 > Reading BUILD INFO: OK! 09:50:38 > MODEL: SM-G3815 09:50:38 > IMEI: 35826705236266 09:50:38 > FIRMWARE: G3815XXUBMK5 09:50:38 > MSL ADDRESS: R28F10FGMR 09:50:38 > UNIQUE NO: C08900AEF42E8D0 09:50:39 > Reading data: OK! 09:50:40 > Sending data to server: OK! 09:50:58 > Calculating [by server] please wait: OK! 09:50:58 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! 09:51:00 > Searching for phone: OK! 09:51:12 > Unlocking phone: OK! 09:51:12 > For unlock use CODE: 00000000 09:51:14 > Restarting phone: OK! 09:51:16 > Getting credit from server: OK! 09:51:17 > CREDIT: 09:51:17 > USED: 6,00 09:51:17 > LIMIT: 6,00 09:51:17 > CREDIT SPECIAL: 09:51:17 > USED: 10 09:51:17 > LIMIT: 10 09:51:17 > Disconnecting from server: OK! 09:51:17 > Samsung SM-G3815 FACTORY UNLOCK: END! |
The Following User Says Thank You to ronandaly For This Useful Post: |
09-24-2014, 13:17 | #1796 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | SAMSUNG GALAXY S5 UNLOCKED SUCCESSFULLY G900T Samsung G900T FACTORY UNLOCK: START! 12:49:10 > Checking server 1: OK! 12:49:11 > Connecting to server: OK! 12:49:12 > Asking server for access: OK! 12:49:14 > Getting credit from server: OK! 12:49:14 > CREDIT: 12:49:14 > USED: 0,10 12:49:14 > LIMIT: 1,00 12:49:14 > CREDIT SPECIAL: 12:49:14 > USED: 0 12:49:14 > LIMIT: 10 12:49:14 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! 12:49:17 > Searching for phone: OK! 12:49:18 > Reading BUILD INFO: OK! 12:49:18 > MODEL: SM-G900T 12:49:18 > IMEI: 12:49:18 > FIRMWARE: G900TUVU1BNH5 12:49:18 > MSL ADDRESS: RV8F4151HN 12:49:18 > UNIQUE NO: CMA00CFAD978431 12:49:20 > Reading data: OK! 12:49:20 > Sending data to server: OK! 12:49:34 > Calculating [by server] please wait: OK! 12:49:34 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! 12:49:36 > Searching for phone: OK! 12:49:48 > Unlocking phone: OK! 12:49:48 > For unlock use CODE: 00000000 12:49:50 > Restarting phone: OK! 12:49:52 > Getting credit from server: OK! 12:49:53 > CREDIT: 12:49:53 > USED: 0,10 12:49:53 > LIMIT: 1,00 12:49:53 > CREDIT SPECIAL: 12:49:53 > USED: 10 12:49:53 > LIMIT: 10 12:49:53 > Disconnecting from server: OK! 12:49:53 > Samsung G900T FACTORY UNLOCK: END! |
The Following User Says Thank You to sefiu1 For This Useful Post: |
09-24-2014, 19:26 | #1797 (permalink) |
No Life Poster Join Date: Aug 2010 Location: HGJIKL
Member: 1360208 Status: Offline Thanks Meter: 133 | Galaxy i8730 4g done.thx julvir. 20:17:26 > Reading MSL INFO: OK! 20:17:27 > MODEL: GT-I8730 20:17:27 > IMEI: 3569460540xxxx 20:17:27 > FIRMWARE: I8730XWANE1 20:17:27 > MSL ADDRESS: R28DC02B2Z 20:17:27 > UNIQUE NO: C0890098FECCBB0 20:17:27 > Samsung FACTORY UNLOCK READ INFO: END! 20:17:41 > Samsung FACTORY UNLOCK FACTORY UNLOCK: START! 20:17:41 > Checking server 1: OK! 20:17:41 > Connecting to server: OK! 20:17:43 > Asking server for access: OK! 20:17:45 > Getting credit from server: OK! 20:17:45 > CREDIT: 20:17:45 > USED: 0,00 20:17:45 > LIMIT: 0,00 20:17:45 > CREDIT SPECIAL: 20:17:45 > USED: 0 20:17:46 > LIMIT: 250 20:17:46 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! 20:17:49 > Searching for phone: OK! 20:17:51 > Reading BUILD INFO: OK! 20:17:51 > MODEL: GT-I8730 20:17:51 > IMEI: 3569460540xxxx 20:17:51 > FIRMWARE: I8730XWANE1 20:17:51 > MSL ADDRESS: R28DC02B2Z 20:17:51 > UNIQUE NO: C0890098FECCBB0 20:17:53 > Reading data: OK! 20:17:54 > Sending data to server: OK! 20:18:10 > Calculating [by server] please wait: OK! 20:18:10 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! 20:18:12 > Searching for phone: OK! 20:18:25 > Unlocking phone: OK! 20:18:25 > For unlock use CODE: 00000000 20:18:27 > Restarting phone: OK! 20:18:30 > Getting credit from server: OK! 20:18:30 > CREDIT: 20:18:30 > USED: 0,00 20:18:30 > LIMIT: 0,00 20:18:30 > CREDIT SPECIAL: 20:18:30 > USED: 10 20:18:30 > LIMIT: 250 20:18:30 > Disconnecting from server: OK! 20:18:30 > Samsung FACTORY UNLOCK FACTORY UNLOCK: END! |
The Following User Says Thank You to swisss For This Useful Post: |
09-25-2014, 14:27 | #1798 (permalink) |
Junior Member Join Date: Jul 2007 Location: República Dominicana
Member: 555917 Status: Offline Thanks Meter: 4 | s5 G900A Unlock Ok 13:22:30 > Samsung SM-N900A FACTORY UNLOCK: START! 13:22:30 > Checking server 1: 13:22:31 > Checking server 1: OK! 13:22:31 > Connecting to server: 13:22:31 > Connecting to server: OK! 13:22:31 > Asking server for access: 13:22:33 > Asking server for access: OK! 13:22:33 > Getting credit from server: 13:22:35 > Getting credit from server: OK! 13:22:36 > CREDIT: 13:22:36 > USED: 2,00 13:22:36 > LIMIT: 2,00 13:22:36 > CREDIT SPECIAL: 13:22:36 > USED: 20 13:22:36 > LIMIT: 30 13:22:36 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! 13:22:36 > Searching for phone: 13:22:38 > Searching for phone: OK! 13:22:39 > Reading BUILD INFO: 13:22:40 > Reading BUILD INFO: OK! 13:22:40 > MODEL: SM-G900A 13:22:40 > IMEI: 3539200611**** 13:22:40 > FIRMWARE: G900AUCU2AND3 13:22:40 > MSL ADDRESS: R38F50PJEP 13:22:40 > UNIQUE NO: CMA00C278B87A51 13:22:40 > Reading data: 13:22:41 > Reading data: OK! 13:22:42 > Sending data to server: 13:22:42 > Sending data to server: OK! 13:22:42 > Calculating [by server] please wait: 13:22:46 > Calculating [by server] please wait: OK! 13:22:46 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! 13:22:46 > Searching for phone: 13:22:48 > Searching for phone: OK! 13:22:49 > Unlocking phone: 13:23:01 > Unlocking phone: OK! 13:23:01 > For unlock use CODE: 00000000 13:23:01 > Restarting phone: 13:23:03 > Restarting phone: OK! 13:23:03 > Getting credit from server: 13:23:05 > Getting credit from server: OK! 13:23:06 > CREDIT: 13:23:06 > USED: 2,00 13:23:06 > LIMIT: 2,00 13:23:06 > CREDIT SPECIAL: 13:23:06 > USED: 20 13:23:06 > LIMIT: 30 13:23:06 > Disconnecting from server: 13:23:06 > Disconnecting from server: OK! 13:23:06 > Samsung SM-N900A FACTORY UNLOCK: END! |
The Following User Says Thank You to solution86 For This Useful Post: |
09-25-2014, 14:38 | #1799 (permalink) |
Member: 555917 Status: Offline Thanks Meter: 4 | s5 G900T Unlock Ok 10:34:43 > Samsung SM-G900T FACTORY UNLOCK: START! 10:34:43 > Checking server 1: 10:34:43 > Checking server 1: OK! 10:34:43 > Connecting to server: 10:34:43 > Connecting to server: OK! 10:34:43 > Asking server for access: 10:34:45 > Asking server for access: OK! 10:34:45 > Getting credit from server: 10:34:47 > Getting credit from server: OK! 10:34:48 > CREDIT: 10:34:48 > USED: 2,00 10:34:48 > LIMIT: 2,00 10:34:48 > CREDIT SPECIAL: 10:34:48 > USED: 10 10:34:48 > LIMIT: 20 10:34:48 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! 10:34:48 > Searching for phone: 10:34:50 > Searching for phone: OK! 10:34:50 > Reading BUILD INFO: 10:34:52 > Reading BUILD INFO: OK! 10:34:52 > MODEL: SM-G900T 10:34:52 > IMEI: 3518810604**** 10:34:52 > FIRMWARE: G900TUVU1ANCH 10:34:52 > MSL ADDRESS: RV8F31D1JB 10:34:52 > UNIQUE NO: CMA00DC20D3C631 10:34:52 > Reading data: 10:34:53 > Reading data: OK! 10:34:53 > Sending data to server: 10:34:54 > Sending data to server: OK! 10:34:54 > Calculating [by server] please wait: 10:35:08 > Calculating [by server] please wait: OK! 10:35:08 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! 10:35:08 > Searching for phone: 10:35:10 > Searching for phone: OK! 10:35:10 > Unlocking phone: 10:35:22 > Unlocking phone: OK! 10:35:22 > For unlock use CODE: 00000000 10:35:22 > Restarting phone: 10:35:24 > Restarting phone: OK! 10:35:25 > Getting credit from server: 10:35:27 > Getting credit from server: OK! 10:35:27 > CREDIT: 10:35:27 > USED: 2,00 10:35:27 > LIMIT: 2,00 10:35:27 > CREDIT SPECIAL: 10:35:27 > USED: 20 10:35:27 > LIMIT: 20 10:35:27 > Disconnecting from server: 10:35:28 > Disconnecting from server: OK! 10:35:28 > Samsung SM-G900T FACTORY UNLOCK: END! |
09-27-2014, 09:48 | #1800 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Paris Age: 36
Member: 670113 Status: Offline Sonork: 100:1615871 Thanks Meter: 44 | G900F GalaXy S5 Unlock Done 10:41:47 > Samsung G900F FACTORY READ CODES: START! 10:41:47 > Checking server 1: OK! 10:41:48 > Connecting to server: OK! 10:41:49 > Asking server for access: OK! 10:41:50 > Getting credit from server: OK! 10:41:51 > CREDIT: 10:41:51 > USED: 34,60 10:41:51 > LIMIT: 35,00 10:41:51 > CREDIT SPECIAL: 10:41:51 > USED: 0 10:41:51 > LIMIT: 250 10:41:51 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! 10:43:03 > Searching for phone: OK! 10:43:05 > Reading BUILD INFO: OK! 10:43:05 > Reading MODEL: OK! 10:43:18 > Reading VERSIONS: OK! 10:43:19 > Reading IMEI: OK! 10:43:33 > Reading BLUETOOTH INFO: ERROR! 10:43:34 > Reading MSL INFO: OK! 10:43:34 > MODEL: SM-G900F 10:43:34 > IMEI: 35380********* 10:43:34 > FIRMWARE: G900FXXU1ANCE 10:43:34 > MSL ADDRESS: ********* 10:43:34 > UNIQUE NO: *************** 10:43:36 > Reading data: OK! 10:43:36 > Sending data to server: OK! 10:43:49 > Calculating [by server] please wait: OK! 10:43:49 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! 10:43:52 > Searching for phone: OK! 10:43:59 > Reading codes: OK! 10:44:00 > Detecting simlock type: ERROR! [ UNSUPPORTED TYPE ] 10:44:05 > Reseting codes: OK! 10:44:05 > For unlock use CODE: 00000000 10:44:07 > Restarting phone: OK! 10:44:09 > Getting credit from server: OK! 10:44:10 > CREDIT: 10:44:10 > USED: 34,60 10:44:10 > LIMIT: 35,00 10:44:10 > CREDIT SPECIAL: 10:44:10 > USED: 10 10:44:10 > LIMIT: 250 10:44:10 > Disconnecting from server: OK! 10:44:10 > Samsung G900F FACTORY READ CODES: END! THANKS MICROBOX :* |
Put in this thread all successfull story with Cyclone-box | NADEEM GONDAL | Cyclonebox | 3058 | 05-24-2019 07:07 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box | FullFLASHgSMPH | Cyclonebox | 2 | 04-13-2009 14:00 |
