10-19-2008, 09:52 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: UK
Member: 232050 Status: Offline Thanks Meter: 23 | Sagem Trouble I have the prolific cable and select the cable's com port in microbox software - but when i go to unlock the phone i always get errors. For example, I am now trying to unlock a sagem my411x Searching for phone ....... found Reading firmware info ......error(1)! sagem my411x read codes : end I have tried many times with phone on/off, connecting cable and battery when software is searching for phone etc but still no good. I notice that the 'Searching for phone ....... found' comes up even if no phone is connected! Sometimes a little more info is read; Searching for phone ....... found Reading firmware info ..... ok Reading hash table info.... ok reading imei ........ error(1)! sagem my411x read codes : end I must be doing something wrong, someone please help, i'm going mad!!!! P.S I have 25 credits, so I'm sure it is not server problem |
10-19-2008, 15:14 | #3 (permalink) |
Member: 232050 Status: Offline Thanks Meter: 23 | I have searched this forum and tried pretty much all of the 'handy tricks' for sagem phones. battery is fully charged, have tried powering phone and then clicking read codes. have tried different phones, have tried different computers. have purchased prolific cable. have tried at least 50 times but still not unlocking! anyone got any ideas other than searching? or at least provide me with a link to the post with the answer because i cant find it! |
10-19-2008, 20:04 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | it is not soft problem, try using another interface as port, an ftdi box, hi have succeeded using setool box as interface, i couldn't make it work with prolific, luck |
10-19-2008, 20:13 | #6 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Croatia,Varazdin
Member: 33901 Status: Offline Thanks Meter: 5 | y3kt yu are woman???pls read old post ....soft not work...with ftdi interface says********Reading firmware info ......error with prolific cable soft says Reading firmware info ......error(1)! soft not work with phone Croatia lock 219-10 microbox support pls fix this problem log: SAGEM VDF526 READ CODES: START! CONNECTING TO SERVER: OK! ASKING SERVER FOR ACCESS: ACCEPTED! GETTING CREDIT DATA FROM SERVER: OK! CREDIT USED: 0 CREDIT LIMIT: 5 SEARCHING FOR PHONE: FOUND! READING FIRMWARE INFO: OK! READING HASH TABLE INFO: OK! READING IMEI: OK! READING MODEL INFO: OK! PRESS POWER: OK! READING CPU INFO: OK! LOADING CERTIFICATE: OK! LOADING APPLICATION: OK! READING DATA: ERROR! SAGEM VDF526 READ CODES: END! MODEL : VF526 IMEI : FIRMW. : EVN,HN: 050608 1016 HT. : A22105 CPU : LOCOSTO HS |
10-20-2008, 00:36 | #8 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | solution her read this http:///vbb/showthread.php?t=588839 |
10-20-2008, 02:14 | #9 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | i think YOU are the woman, i have unlocked a couple of sagem phones using FTDI interface (SETOOL BOX) i even tried with PROLIFIC interface and nothing, so go try and then cry here, respect for others should be the first, now this is the first and last time i try to help you, no luck |
10-20-2008, 07:58 | #11 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Croatia Age: 54
Member: 45796 Status: Offline Thanks Meter: 13 | Yes,I can confirm,Sagem soft have bug or must be upgraded,specialy for Croatian V526 phones firmware.I have all possible kinde of interface and same error is happened.100 % soft bug. |
ned unlock code for sagem my W-8 | nokia4m | Phone Unlocking Codes & Maps | 2 | 05-03-2010 17:23 |
Vodafone sagem my401v possibale to unlock | ..::AppleLinks::.. | FuriousGold | 1 | 03-29-2010 17:28 |
Look here if you have trouble using sagem | micka22 | FuriouS II | 4 | 12-02-2004 17:12 |
Sagem MC810 with new version firmware, big trouble with unlock | Pluton | Infineon C16X M51 & ARM7 M52 BASED | 8 | 06-07-2003 11:48 |
Sagem 922 double trouble | Dodo | Infineon C16X M51 & ARM7 M52 BASED | 0 | 02-15-2001 10:11 |
