12-09-2012, 12:05 | #1 (permalink) |
Junior Member Join Date: Jun 2006 Location: Slovakia
Member: 301469 Status: Offline Thanks Meter: 0 | huawei U8110 unlock problem simlock status unknown [Answered] 1:47:50 > HUAWEI U8110 READ INFO: START! 11:47:50 > KILLING ADB SERVER (IF RUNNING): OK! 11:47:56 > READING INFO: OK! 11:47:56 > MANUFACTURER: HUAWEI Technologies 11:47:56 > MODEL: U8110 11:47:56 > VERSION: M7X25V100R001C00B215 11:47:56 > IMEI: 359145031200173 11:47:56 > CHECKING PHONE VERSION: SUPPORTED! 11:47:56 > HUAWEI U8110 READ INFO: END! 11:47:58 > VERSION: MICRO-BOX A.I.O. V2.1.4.1 11:47:58 > BOX SN: AE33DACE348B5513 BOX FW: 75 11:47:58 > HUAWEI U8110 UNLOCK: START! 11:47:58 > KILLING ADB SERVER (IF RUNNING): OK! 11:48:04 > READING INFO: OK! 11:48:04 > MANUFACTURER: HUAWEI Technologies 11:48:04 > MODEL: U8110 11:48:04 > VERSION: M7X25V100R001C00B215 11:48:04 > IMEI: 359145031200173 11:48:04 > CHECKING PHONE VERSION: SUPPORTED! 11:48:15 > SWITCHING TO FAST-BOOT MODE: ERROR! 11:48:15 > PLEASE MANUALLY PUT PHONE IN FAST-BOOT MODE! 11:48:15 > POWER OFF PHONE AND DISCONNECT FROM USB CABLE! 11:48:15 > WITH PHONE OFF PRESS VOLUME DOWN + POWER ON! 11:48:15 > KEEP PRESSED FOR ~10 SECONDS AND THEN RECONNECT TO USB! 11:49:43 > WAITING FOR FAST-BOOT MODE: OK! 11:49:43 > SENDING PARAMETERS: OK! 11:50:06 > SEARCHING FOR PHONE: NOT FOUND! 11:50:06 > PLEASE INSTALL LAST MICRO-BOX SECURE PORT DRIVERS FROM SUPPORT! 11:50:06 > PLEASE RECONNECT PHONE TO USB! 11:50:31 > SEARCHING FOR PHONE: OK! 11:50:31 > READING PARAMETERS: OK! 11:50:31 > READING FLASH INFO: OK! 11:50:31 > FLASH ID: Samsung 4Gbit (ECBC:0055, 1000, 0040, 0800) 11:55:57 > READING DATA: OK! 11:55:57 > BACKUPS\HUAWEI\U8110\TLj(HUAWEI_Technologies_U8110 _M7X25V100R001C00B215_359145031200173_2012_12_09_1 1_55_57_SIMLOCK_BKP.mbf 11:55:58 > SAVING BACKUP: OK! 11:55:58 > OTP_IMEI: 359145031200173 11:55:58 > OTP_BT_ADDR: 62A6CC99544C 11:55:58 > OTP_WIFI_ADDR: 63A6CC99544C 11:55:58 > ANALIZING SIMLOCK ZONE: OK! 11:55:58 > SIMLOCK STATUS: UNKNOWN 11:55:58 > HUAWEI U8110 UNLOCK: END! |
01-10-2013, 16:56 | #7 (permalink) |
Freak Poster Join Date: Jul 2006 Location: lusaka
Member: 320108 Status: Offline Thanks Meter: 18 | WHEN IS THE UPDATE .................. 17:50:52 > HUAWEI U8110 UNLOCK: START! 17:50:52 > KILLING ADB SERVER (IF RUNNING): OK! 17:51:06 > READING INFO: OK! 17:51:06 > MANUFACTURER: HUAWEI Technologies 17:51:06 > MODEL: U8110 17:51:06 > VERSION: M7X25V100R001C00B215 17:51:06 > IMEI: 359145030715031 17:51:07 > CHECKING PHONE VERSION: SUPPORTED! 17:51:18 > SWITCHING TO FAST-BOOT MODE: ERROR! 17:51:18 > PLEASE MANUALLY PUT PHONE IN FAST-BOOT MODE! 17:51:18 > POWER OFF PHONE AND DISCONNECT FROM USB CABLE! 17:51:18 > WITH PHONE OFF PRESS VOLUME DOWN + POWER ON! 17:51:18 > KEEP PRESSED FOR ~10 SECONDS AND THEN RECONNECT TO USB! 17:51:44 > WAITING FOR FAST-BOOT MODE: OK! 17:51:45 > SENDING PARAMETERS: OK! 17:55:08 > SEARCHING FOR PHONE: NOT FOUND! 17:55:08 > PLEASE INSTALL LAST MICRO-BOX SECURE PORT DRIVERS FROM SUPPORT! 17:55:08 > PLEASE RECONNECT PHONE TO USB! 17:56:21 > SEARCHING FOR PHONE: OK! 17:56:21 > READING PARAMETERS: OK! 17:56:21 > READING FLASH INFO: OK! 17:56:21 > FLASH ID: Samsung 4Gbit (ECBC:0055, 1000, 0040, 0800) 17:57:58 > READING DATA: OK! 17:57:59 > BACKUPS\HUAWEI\U8110\TL+HUAWEI_Technologies_U8110_ M7X25V100R001C00B215_359145030715031_2013_01_10_17 _57_58_SIMLOCK_BKP.mbf 17:57:59 > SAVING BACKUP: OK! 17:57:59 > OTP_IMEI: 359145030715031 17:57:59 > OTP_BT_ADDR: A1F84E99544C 17:57:59 > OTP_WIFI_ADDR: A2F84E99544C 17:57:59 > ANALIZING SIMLOCK ZONE: OK! 17:58:00 > SIMLOCK STATUS: UNKNOWN 17:58:00 > HUAWEI U8110 UNLOCK: END! |
01-12-2013, 11:13 | #8 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Hungary Age: 48
Member: 47989 Status: Offline Thanks Meter: 40 | I have same problem with U8110 unlock SIMLOCK STATUS: UNKNOWN I send backup files Br. ZAXGSM |
The Following User Says Thank You to zaxgsm For This Useful Post: |
01-14-2013, 16:03 | #9 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RO, Nasaud
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | As soon as we will find the solution for that new security we will release an update for it. WBR, gsm9 |
The Following User Says Thank You to gsm9l For This Useful Post: |
