01-19-2013, 13:41 | #1 (permalink) |
Freak Poster Join Date: Nov 2012
Member: 1834583 Status: Offline Thanks Meter: 15 | Samsung Galaxy Y S5360 unlocking problem [Answered] 13:38:31 > KILLING ADB SERVER (IF RUNNING): OK! 13:38:31 > SEARCHING FOR PHONE: OK! 13:38:32 > READING INFO: OK! 13:38:33 > BRAND: SAMSUNG 13:38:33 > MODEL: GT-S5360 / GT-S5360 13:38:33 > VERSION: 2.3.6 / GINGERBREAD 13:38:33 > FIRMWARE: GT-S5360-USER / S5360XXLE1 13:38:33 > KERNEL: 2.6.35.7 (gcc 4.4.3) 13:38:33 > CPU TYPE: BCM21553 / ARMv6 13:38:33 > CARD ID: 1B534D3030303030107FF41F5D00B300 13:38:39 > CHECKING ROOT: OK! 13:39:19 > READING DATA: OK! 13:39:20 > IMEI: 354661055593959 13:39:20 > Backups\SAMSUNG\S5360\S5360_354661055593959_SIMLOC K_2013_01_19_13_39_20.mbf 13:39:20 > SAVING BACKUP: OK! 13:39:23 > CALCULATING: ERROR! 13:39:23 > SAMSUNG S5360 READ CODES: END! MicroBoxALLinONE V2.1.4.7 CR FINAL |
The Following User Says Thank You to tarpepan For This Useful Post: |
01-24-2013, 15:51 | #9 (permalink) |
Member: 1834583 Status: Offline Thanks Meter: 15 | In MicroBoxALLinONE V2.1.4.8 there's S5360 Tat Mode option. Tried that one too and here's what happend: 15:34:35 > SAMSUNG S5360 TAT MODE READ INFO: START! 15:34:35 > DETECTING PHONE: INIT ERROR! 15:34:35 > SAMSUNG S5360 TAT MODE READ INFO: END! Honestly, I'm not sure how to put this phone model into Tat Mode and which port should I use. |
01-25-2013, 15:24 | #13 (permalink) |
Member: 1834583 Status: Offline Thanks Meter: 15 | In less then a millisecond after I click READ UNLOCK CODES I got this Code: 15:13:10 > SAMSUNG S5360 TAT MODE READ CODES: START! 15:13:10 > DETECTING PHONE: INIT ERROR! 15:13:10 > SAMSUNG S5360 TAT MODE READ CODES: END! |
01-25-2013, 15:32 | #14 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RO, Nasaud
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Only now I sow you have selected TAT MODE for this S5360. You need to wait direct unlock solution. By mistake it appear in tat mode - you need to forget about it we will remove it. WBR, gsm9l |
01-25-2013, 15:37 | #15 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 268332 Status: Offline Thanks Meter: 16 | I have sam problem many tims, solution is : full flash for flash S5360_XXLE1_XXLE1_XXLE1_open then ROOT manualy. After this just tick USB Debbuging , select com port in the program and unlock it. I Micro Box give you error, then try Z3x or SGTool and post results. |
