05-10-2011, 22:28 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Zooropa Age: 42
Member: 18832 Status: Offline Thanks Meter: 18 | Samsung I9000 Unlock problem [Answered] SAMSUNG I9000 UNLOCK: START! 23:24:57 > KILLING ADB SERVER (IF RUNNING): OK! 23:24:58 > SEARCHING FOR PHONE: OK! 23:24:59 > READING INFO: OK! 23:24:59 > MODEL: GT-I9000 / GT-I9000 23:24:59 > VERSION: 2.2 / FROYO 23:24:59 > FIRMWARE: GT-I9000-user / I9000XXJPK 23:24:59 > KERNEL: 2.6.32.9 (gcc 4.4.1) 23:24:59 > CPU TYPE: S5PC110 / ARMv7 23:25:06 > CHECKING ROOT: OK! 23:25:19 > READING DATA: ERROR 1005! 23:25:20 > SAMSUNG I9000 UNLOCK: END! I cannot do direct unlock for some reason. Any advice is appreciated. WBR e-studio.hu |
05-11-2011, 07:17 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RO, Nasaud
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Hi, Change your USB, don't plug the phone in USB HUB, install first original drivers (kies) then force install Android drivers from support again and Unlock it. WBR, gsm9l |
07-16-2011, 15:48 | #3 (permalink) |
No Life Poster Join Date: May 2005 Location: MIND MAKING COMPANY Age: 44
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | 19:46:27 > VERSION MICRO-BOX A.I.O. V2.0.2.0 19:46:27 > SAMSUNG GALAXY S UNLOCK: START! 19:46:27 > KILLING ADB SERVER (IF RUNNING): OK! 19:46:27 > SEARCHING FOR PHONE: OK! 19:46:27 > READING INFO: OK! 19:46:28 > MODEL: GT-I9000 / GT-I9000 19:46:28 > IMEI: 35478104660XXXX 19:46:28 > VERSION: 2.3.3 / GINGERBREAD 19:46:28 > FIRMWARE: GT-I9000-USER / I9000XXJVO 19:46:28 > KERNEL: 2.6.35.7-I9000XWJVI-CL210427 (gcc 4.4.0) 19:46:28 > CPU TYPE: S5PC110 / ARMv7 19:46:33 > CHECKING ROOT: NOT ROOTED! 19:46:52 > RUNNING TEMP ROOT: OK! 19:46:52 > SEARCHING FOR PHONE: OK! 19:46:57 > CHECKING ROOT: NOT ROOTED! 19:46:58 > PLEASE RESTART PHONE AND TRY AGAIN! 19:46:58 > SAMSUNG GALAXY S UNLOCK: END! |
07-17-2011, 11:23 | #6 (permalink) | |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Quote:
Then read codes with Micro-Box WBR, gsm9l | |
07-18-2011, 13:33 | #7 (permalink) |
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | even after buying the code it still in freeze mode so i think direct unlock or downgrade needed Show comments 35478104660XXXX NCK: 60513526 MCK: 68460851 SCK: 40911262 SPCK: 30018540 Samsung Europe (Instant) 14759 Date : 2011-07-16 | Credit : 15 | Comments:t-mobile UK | Reply Date : 16-07-2011 |
07-18-2011, 13:51 | #8 (permalink) |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Why do you buy code if Micro-Box give you now unlock code and freeze code? It seems you are lazy to folow a small procedure. It's your choice. And by the way if you downgrade it will work also the Direct Unlock option. WBR, gsm9l |
The Following User Says Thank You to gsm9l For This Useful Post: |
07-19-2011, 23:46 | #9 (permalink) |
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | Sent from my iPhone using Tapatalk I m not able to downgrade it coz I don't want headache of lengthy procedure and google Nothing is mention on ur forum about downgrading every thing is on xda developers site I know risk at your own self so I never want to give demage to others money ifu people are so much help full then why don't u post these procedurs on your support site in samsung folders and files can be put over there fir downloads coz I sick using the mediafire and rapidshare also magaupload If u got some guts on that prepair a link for unlockable media link if person is not able to unlock the set after completing the procedure the link appear in end to read the FAQs about the selected model u can do this if u want Also I want to add a screen shot button in the program so every person can use it for taking the screen shot and post it to forum About I9000 even after buying the code I m not able to unlock that set it's not a big task but I m sure I do what ever I can do to save theoney of the customer and don't even risking his set for single second and loss came in my side I will manage it my self nothing to worry about that Plz introduce screen shot and help link if error accured request from my side |
08-11-2011, 15:08 | #10 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 746882 Status: Offline Thanks Meter: 164 | 15:14:18 > VERSION MICRO-BOX A.I.O. V2.0.2.4 15:14:18 > SAMSUNG I9000 READ INFO: START! 15:14:18 > KILLING ADB SERVER (IF RUNNING): OK! 15:14:19 > SEARCHING FOR PHONE: OK! 15:14:19 > READING INFO: OK! 15:14:25 > CHECKING ROOT: NOT ROOTED! 15:14:25 > MODEL: GT-I9000 / GT-I9000 15:14:25 > IMEI: 350000000000000000 15:14:25 > VERSION: 2.2.1 / FROYO 15:14:25 > FIRMWARE: GT-I9000-USER / I9000BVJP4 15:14:25 > KERNEL: 2.6.32.9 (gcc 4.4.1) 15:14:25 > CPU TYPE: S5PC110 / ARMv7 15:14:25 > SAMSUNG I9000 READ INFO: END! 15:14:28 > VERSION MICRO-BOX A.I.O. V2.0.2.4 15:14:28 > SAMSUNG I9000 READ CODES: START! 15:14:28 > KILLING ADB SERVER (IF RUNNING): OK! 15:14:28 > SEARCHING FOR PHONE: OK! 15:14:29 > READING INFO: OK! 15:14:29 > MODEL: GT-I9000 / GT-I9000 15:14:29 > IMEI: 350000000000000000 15:14:29 > VERSION: 2.2.1 / FROYO 15:14:29 > FIRMWARE: GT-I9000-USER / I9000BVJP4 15:14:29 > KERNEL: 2.6.32.9 (gcc 4.4.1) 15:14:30 > CPU TYPE: S5PC110 / ARMv7 15:14:35 > CHECKING ROOT: NOT ROOTED! 15:14:48 > RUNNING TEMP ROOT: OK! 15:14:48 > SEARCHING FOR PHONE: OK! 15:14:50 > CHECKING ROOT: OK! 15:15:07 > READING DATA: OK! 15:15:08 > CHECKING SERVER 1: OK! 15:15:08 > CONNECTING TO SERVER: OK! 15:15:09 > ASKING SERVER FOR ACCESS: ACCEPTED! 15:15:10 > SENDING DATA TO SERVER: OK! 15:15:16 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 15:15:16 > FREEZE CODE: 61647142 15:15:16 > NET CODE: 27415296 15:15:16 > SP CODE: 00000000 15:15:16 > CP CODE: 00000000 15:15:16 > SIM CODE: 00000000 15:15:16 > DISCONNECTING FROM SERVER: OK! 15:15:17 > SAMSUNG I9000 READ CODES: END! 15:51:56 > BOX DISCONNECTED: ERROR! |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
