Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Micro-Box Team Products > Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...)
Old 12-28-2009, 13:06   #1 (permalink)
Member: 793926
Thanks Meter: 67
Thumbs down sfr u3300 Successfully Unlocked Phones By micro-box[ANSWERED]
thinks micro-box11:45:38 > RESTARTING PHONE: OK!11:45:38 > HUAWEI U3300 READ CODES: END!11:45:41 > VERSION MICRO-BOX A.I.O. V1.0.1.111:45:42 > HUAWEI U3300 READ CODES: START!11:45:43 > READING MODEL: ERROR 1004!11:45:44 > RESTARTING PHONE: OK!11:45:44 > HUAWEI U3300 READ CODES: END!11:45:45 > VERSION MICRO-BOX A.I.O. V1.0.1.111:45:46 > HUAWEI U3300 READ CODES: START!11:45:47 > READING MODEL: OK!11:45:49 > READING IMEI: OK!11:45:57 > READING CPU INFO: OK!11:45:57 > MODEL: U330011:45:57 > IMEI: 35343602029907811:45:57 > CPU: M6275A-OEMSBL11:45:58 > PREPARING PHONE: OK!11:46:02 > SENDING LOADER: OK!11:46:02 > READING DATA: OK!11:46:04 > SENDING APPLICATION: OK!11:46:12 > READING DATA: OK!11:46:12 > SAVING DATA FOR R&D: OK!11:46:12 > BACKUPS\HUAWEI\U3300_353436020299078_2009_12_28_11 _46_12_R&D.mbf11:46:12 > PLEASE SEND THIS FILE TO: [email protected]11:46:15 > RESETING COUNTER: OK!11:46:16 > CALCULATING: OK!11:46:16 > PROVIDER: 208-1011:46:16 > NCK: 794116417929605211:46:16 > HOW TO: INSERT NOT WORKING SIMCARD AND USE CODE!11:46:16 > RESTARTING PHONE: OK!11:46:16 > HUAWEI U3300 READ CODES: END!
Old 12-28-2009, 13:12   #2 (permalink)
Member: 793926
Thanks Meter: 67
The Following 2 Users Say Thank You to haroum For This Useful Post:
Old 12-29-2009, 07:40   #3 (permalink)
SOHAIL BASHARAT's Avatar
Member: 748880
Thanks Meter: 1,705
Thanks for this test report .Enjoy unlocking micro box .
The Following User Says Thank You to SOHAIL BASHARAT For This Useful Post:
Old 02-21-2010, 11:11   #4 (permalink)
puumba's Avatar
Member: 613113
Thanks Meter: 21
How to install flash mode driver bro?because if i connected usb+tp in flash mode "unknown device"
Old 02-21-2010, 11:26   #5 (permalink)
Member: 793926
Thanks Meter: 67
hi *+#+power with baterie phone locale mode inser cable phone and pc computer 1 minute detecte detached baterie instal driver support read code 5second inser test point code read thinks
Old 02-21-2010, 23:27   #6 (permalink)
puumba's Avatar
Member: 613113
Thanks Meter: 21
I already try this method bro but not work : i put phone in flash mode *+0+#+power and insert the cable in pc and put tp "unknown device"
here is log:
01:24:15 > HUAWEI U3300 READ CODES: START!
01:24:17 > READING MODEL: OK!
01:24:20 > READING IMEI: OK!
01:24:53 > READING CPU INFO: ERROR 1002!
01:24:53 > MODEL: U3300
01:24:53 > IMEI: 353436020xxxxxx
01:24:53 > RESTARTING PHONE: OK!
01:24:53 > HUAWEI U3300 READ CODES: END!
i think it's an problem with flash mode driver!!!need help bro
Old 02-21-2010, 23:56   #7 (permalink)
Member: 793926
Thanks Meter: 67
hi yes unknown device" formating pc probleme driver or other pc 100/100 driver with message unknown device
Old 02-22-2010, 00:04   #8 (permalink)
puumba's Avatar
Member: 613113
Thanks Meter: 21
Ok!i'll try to format pc
Old 02-22-2010, 01:17   #9 (permalink)
tito millo's Avatar
Member: 390642
Sonork: 100.1573430
Thanks Meter: 2,476
Try to clean all drivers 1st if not work then try on a fresh OS
Br,
Tito Millo
Micro-Box Team
Old 02-26-2010, 08:39   #10 (permalink)
puumba's Avatar
Member: 613113
Thanks Meter: 21
Br,
Tito Millo
Micro-Box Team
I Already try to format pc,remove all driver,try with an other pc but problem still bro
Old 02-26-2010, 08:51   #11 (permalink)
Member: 748880
Thanks Meter: 1,705
Hi,
first make sure cable with TP should be good just first put the phone in test or boot mode *+0+#+Power ON than connect cable PC to phone and connect the TP Needle to Testpoint hold on after some second u will see in device manager comport detected choose correct COM in soft and press desire operation phone should be unlocked
Also you can see picture of test point .
http://forum.gsmhosting.com/vbb/atta...7&d=1242197408
The Following 2 Users Say Thank You to SOHAIL BASHARAT For This Useful Post:
Old 03-06-2010, 09:35   #12 (permalink)
puumba's Avatar
Member: 613113
Thanks Meter: 21
Unhappy
[QUOTE=sohailkh;5486238]Hi,
Thanks for help bro but not work,always unknown device if i connect phone
Old 05-11-2010, 14:39   #13 (permalink)
dez com's Avatar
Member: 525901
Sonork: 100.1607503
Thanks Meter: 47
hello
[QUOTE=puumba;5529121]
Originally Posted by sohailkh View Post
Hi,
i also have the same problem here i do evryting uknow device if smoebody can share the cable chema pic i am thinking maybe cable is the problem i will cheik it if not correct
thanks for the helper
Old 06-30-2010, 19:56   #14 (permalink)
Member: 870664
Sonork: 100.1614707
Thanks Meter: 56
DON'T USE USB HUB FOR YOUR PHONE
PLUG DIRECTLY TO USB BEHIND YOUR COMPUTER EVERYTHING SHOULD BE OK
1-CONECT CABLE TO YOUR PHONE WITHOUT BATTERY (this switch your phone on)
2-wait till the phone switch completely on select your comport
3-press read code and wait till the progression bar stops at 26% and the screen becomes pink
4-atach you tp http://forum.gsmhosting.com/vbb/atta...7&d=1242197408
5-finaly watch this result
9:52:13 > HUAWEI U3300 READ CODES: START!
19:52:15 > READING MODEL: OK!
19:52:16 > READING IMEI: OK!
19:52:25 > READING CPU INFO: OK!
19:52:25 > MODEL: U3300
19:52:25 > IMEI: 353436020248307
19:52:25 > CPU: M6275A-OEMSBL
19:52:25 > PREPARING PHONE: OK!
19:52:28 > SENDING LOADER: OK!
19:52:28 > READING DATA: OK!
19:52:28 > SENDING APPLICATION: OK!
19:52:30 > READING DATA: OK!
19:52:31 > SAVING DATA FOR R&D: OK!
19:52:31 > BACKUPS\HUAWEI\U3300_353436020248307_2010_06_30_19 _52_31_R&D.mbf
19:52:31 > PLEASE SEND THIS FILE TO: [email protected]
19:52:32 > RESETING COUNTER: OK!
19:52:32 > CALCULATING: OK!
19:52:32 > PROVIDER: 208-10
19:52:32 > NCK: 7411533186411517
19:52:32 > HOW TO: INSERT NOT WORKING SIMCARD AND USE CODE!
19:52:32 > RESTARTING PHONE: OK!
19:52:33 > HUAWEI U3300 READ CODES: END!
How to unlock s5230 with micro box[ANSWERED] sairat Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 12 10-29-2010 15:10
Please Post Here All SuccessFully Unlock HTC With Micro-Box MOBIL CLINIC Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 10 01-12-2010 05:41
Orange Berlin Successfully Unlock done with Micro Box Miftahudin Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 7 02-19-2009 13:03
LG KF600 unlock Sucessfully By Micro box NO.7 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2 09-11-2008 11:07
Page generated in 0.28467 seconds with 9 queries
