GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) (https://forum.gsmhosting.com/vbb/f447/)
-   -   sony flasher has bug to remove pin, pattern, password. (https://forum.gsmhosting.com/vbb/f447/sony-flasher-has-bug-remove-pin-pattern-password-2218274/)
Hacker84 04-25-2017 17:56
Many phone that i try to factory reset by SONY FLASHER of MicroBox FAIL, because the phone turn on in same condition (pattern, pin, password..etc)
11:45:15 - Device disconnected
11:45:24 - Selected FTF pattern: null
11:45:34 - DownloadFlash: Reading the list of devices...
11:46:10 - Download: trying to dowload pattern unlocker for D2206
11:46:10 - Donwload job finished!
11:46:10 - Downloading pattern ftf for D2206...
11:48:05 - Download finished for D2206
11:48:17 - Selected FTF pattern: C:\Users\Unlocker84\.sonyflasher\firmwares\D2206_p attern.ftf
11:48:17 - Decrypting ftf pattern...
11:48:21 - Selected Bundle for D2206. FW release : . Customization : pattern
11:48:21 - Preparing files for flashing
11:48:21 - Please connect your device into flashmode.
11:48:29 - Device connected in flash mode
11:48:30 - Opening device for R/W
11:48:30 - Reading device information
11:48:30 - Phone ready for flashmode operations.
11:48:30 - Opening TA partition 2
11:48:30 - Current device : D2206 - HL4830D41752 - 1288-9721_R6B - 1285-1179_18.5.C.0.25 - AMERICAS-LTE_18.5.C.0.25
11:48:30 - Closing TA partition
11:48:30 - Start Flashing
11:48:30 - Processing loader.sin
11:48:30 - Checking header
11:48:30 - Flashing data
11:48:31 - Loader : S1_Root_f82d - Version : LOADER_RELEASE_MSM8X26_32_AID_4 / Boot version : S1_Boot_MSM8x26_LA1.0_317 / Bootloader status : ROOTABLE
11:48:31 - Max packet size set to 512K
11:48:31 - Making a TA backup
11:48:31 - Opening TA partition 1
11:48:31 - Start Dumping TA partition 1
11:48:31 - Finished Dumping TA partition 1
11:48:31 - TA partition 1 saved to C:\Users\Unlocker84\.sonyflasher\registeredDevices \HL4830D41752\s1ta\2017-04-25_11-48-31\1.ta
11:48:31 - Closing TA partition
11:48:31 - Opening TA partition 2
11:48:31 - Start Dumping TA partition 2
11:48:32 - Finished Dumping TA partition 2
11:48:33 - TA partition 2 saved to C:\Users\Unlocker84\.sonyflasher\registeredDevices \HL4830D41752\s1ta\2017-04-25_11-48-31\2.ta
11:48:33 - Closing TA partition
11:48:34 - No flash script found. Using 0.9.18 flash engine
11:48:34 - Opening TA partition 2
11:48:34 - Writing TA unit 00002774. Value : 01
11:48:34 - Closing TA partition
11:48:34 - Writing TA unit 00002725. Value : 32 30 31 37 2D 30 34 2D 32 35 20 31 31 3A 34 38 3A 33 34 00
11:48:34 - Writing TA unit 00002774. Value : 00
11:48:34 - Ending flash session
11:48:34 - Flashing finished.
11:48:34 - Please unplug and start your phone
11:48:34 - For SonyFlasher, Unknown Sources and Debugging must be checked in phone settings
11:48:35 - Device connected in flash mode
11:48:41 - Device disconnected
There is many bug with this soft.....
Please try to fix it.
allumts 04-25-2017 21:54
Hello, how have explained very many times, the "Flash Files" are Download direct from SONY Database, so if some phone is Undone, issue goes searched if are using "Right" File, procedure itc...
Anyway, i want to report to our coder of ceck if there's some issue from our sw, also i just know the answer, all Bug are been solved....
If find some bug in one specific model we will be update as soon possible.
allumts
Page generated in 0.10840 seconds with 6 queries
