Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Micro-BoxTeam Products > Basic Micro-Box Software Support
Old 08-17-2009, 14:48   #1 (permalink)
Member: 892194
succesfully unlocked zte vegas 760 with mirco box here it is microbox is best
GORANGE VEGAS READ CODES: START!
PREPAIRING DATA: OK!
PRESS POWER: STOPPED BY USER!
ORANGE VEGAS READ CODES: END!
PRESS POWER: TIMEOUT!
ORANGE VEGAS UNLOCK: START!
ORANGE VEGAS UNLOCK: END!
PRESS POWER: OK! DON'T RELEASE POWER!
SENDING PRELOADER: ERROR 1004!
SENDING PRELOADER: OK! CAN RELEASE POWER!
SENDING LOADER: OK!
SET SPEED: ERROR 1002!
SENDING LOADER: OK!
SET SPEED: OK!
READING CPU ID: OK!
READING NOR FLASH INFO: OK!
READING NAND FLASH INFO: NOT AVAILABLE!
DETECTING VERSION BY SIGNATURE: UNKNOWN VERSION!
READING VERSION FROM EEPROM: OK!
READING IMEI: OK!
READING DATA: OK!
CALCULATING: OK!
WRITING DATA: OK!
my brother
all u have to do is use is use v3 com select the model download orange drivers see when u gna download the drivers its gna give you 2 folders 1 would be berlin and the other 1 would be newyork give this phone new york drivers and enjoy with out kilikg the phone
Old 08-18-2009, 02:01   #2 (permalink)
Member: 124648
Hello, please can you explain step by step how you install drivers from newyork to vegas? because I'm traying this afternoon and it's impossible for me. I have orange vegas driver and USB that it comes in the box.
When select in orange software the "vegas phone" just only MICROBOX cable selected. And if I select Newyork or Berlin not detects anything. Windows detects orange vegas like serial modem.
Please post step by step...
Old 08-18-2009, 09:29   #3 (permalink)
Registered User
Member: 975850
For vegas spain not works... always error
No needed drivers, only soft working... for zte vegas spaņol no work... three hous working for nothing. allways same error d'ont "release power"... but I not release I keep. I loocking for another solution.
Old 08-18-2009, 11:06   #4 (permalink)
Member: 892194
d veras
dear friend first of all u dont need usb cable as i ahve write u need a v3 com cable or any com cable which look like v3 and when u gna coonect the phone with it turn on the phone first select the phone to the com mode from the phone its gona show u and then when ur copmuter ask for the drivers download orange us drivers from the web site and extarct them when u extract them they give u 2 folders one berlin and other one would be newyork give it newyork drivers and u got the drivers start the whole proces gain i mean press unlock and there u go dont forget not usb com cable ok
Old 08-19-2009, 12:10   #5 (permalink)
Member: 124648
Hello observer123, at first, thanks for your reply.
I can't install any driver with SERIAL COM cable build from old cable (based on MAX 232) I thing you make cable with FTDi usb/serial converter or prolific, because the drivers inside NewYork folder are for USB not SERIAL.
Please can you explain with more details?
Old 08-19-2009, 15:39   #6 (permalink)
Member: 892194
the cable i used was the cable zte from infinity box bu i used that in micro box com and it did work i tell u what to do give ur phone drivers with usb i mean connect it with usb give it drivers the newyork ones and use com to unlock and that is the cable zte 341 com cable from infinity hope u wil fine
Old 08-19-2009, 17:35   #7 (permalink)
Member: 124648
Sorry brother but don't work for me.
The driver from Newyork was unable to install it! (download from support)
I don't understad well your text. You say "use zte from infinity" I have this cable.
Then you say "connect it with usb" I connected with USB and installed the driver from cd-rom of orange vegas, because it's unble to install the drivers from support.
With the drivers of cd-rom, windows xp detects it as follows
If I select Orange Newyork only show "port not found"
and if I select Orange Vegas the option changes to Micro-Box port
succesfully unlocked zte a305 sabbalde SAGEM JTAG UNLOCKER 0 03-26-2010 15:19
How do you unlock ZTE-G 760 via imei??? mossy007 Basic Micro-Box Software Support 1 12-01-2009 23:59
succesfully unlocked zte 760 with mirco box here it is microbox is best observer123 Basic Micro-Box Software Support 0 08-17-2009 14:47
+++Succesfully unlock ZTE A35 with new pana01/1.57 version +++ makkah mobile Infinity-Box 20 12-08-2008 02:58
Page generated in 0.68017 seconds with 11 queries
