12-15-2008, 10:20 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Space
Member: 352237 Status: Offline Sonork: 100.1577161 Thanks Meter: 605 | **** Successfully Unlocked 6300 **** READING JAF FIRMWARE: OK! (FW: 01B1) NOKIA 6300 RM217 UNLOCK: START! SET PHONE TO TEST MODE: OK! SET JAF TO FBUS MODE: OK! READING MCU SW VERSION: OK! READING IMEI: OK! READING LOCK INFO: OK! CONFIG KEY: 8000000000000000 PROVIDER KEY: 2341000000000000 COUNTERS: 0(3) 0(10) STATUS: LOCKED READING DATA: OK! SAVING BACKUP: OK! D:\MICRO BOX\SETUP'S\MODULES\MICROBOX\\35351102964xxxx_2008 _12_15_14_14_11.PM SET JAF TO FLASH MODE: OK! SENDING BOOT: OK! RAPX VERSION: RAP3GV3 RAPX ID: 000000010000022600010006010C192101001101 RAPX PUBID: 08F000026A7C7A56219B2E0D936A9A8000B52CD6 RAPX ROMID: 191EC665DFAAF68F RAPX HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 EM ID 1: 00000232 EM ID 2: 00000353 SENDING PATCH APPLICATION: OK! TEST CALL: CPSR - 0X0000001F P15_1 - 0X0005307F P15_2 - 0X0005117F P15_3 - 0X0005317F ESN_INIT RET - 0X00000001, <TMP_BUFF2> - 0X00000027 ESN_READ RET - 0X00000001, <TMP_BUFF2> - 0X00000001 NORMAL BB5 FOUND - 0X0002B400 LR - FFFF3688, PARAM - 0X03, SIZE - 0X00 UPDSLOCK - 0X00000001 RET - 0X01, <TMP_BUFF2> - 0X23 PM_308 CRC - 0X0018F558 RUNING PATCH APPLICATION: OK! READING CALCULATED SPDATA: OK! D:\MICRO BOX\SETUP'S\MODULES\MICROBOX\\35351102964xxxx_2008 _12_15_14_14_41_UNLOCKED.PM REBOOTING PHONE: OK! SET JAF TO FBUS MODE: OK! PREPAIRING UNLOCK DATA: OK! WRITING UNLOCK DATA: OK! REBOOTING PHONE: OK! READING MCU SW VERSION: OK! READING IMEI: OK! READING LOCK INFO: OK! CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 COUNTERS: 0(3) 0(10) STATUS: NOT LOCKED NOKIA 6300 RM217 UNLOCK: END! |
12-16-2008, 12:32 | #6 (permalink) |
Junior Member Join Date: Dec 2008
Member: 925473 Status: Offline Thanks Meter: 0 | I have a problem using the two together.: This is the message microbox gives: CONNECTING TO JAF: OK! READING JAF FIRMWARE: OK! (FW: 01B1) NOKIA 6300 RM217 READ INFO: START! SET PHONE TO TEST MODE: ERROR 1004! NOKIA 6300 RM217 READ INFO: END! --------------------------------------------------------------- The phone connects to jaf, blue dot is lit and it turns into local mode. (sometimes to test mode) But when I press Unlock, the jaf box reconnects the phone, because of the time that takes it says error 1004! anyone with the same problem? Or with a solution for this problem? |
12-20-2008, 14:57 | #9 (permalink) |
Junior Member Join Date: May 2007
Member: 508022 Status: Offline Thanks Meter: 2 | Connecting to jaf: Ok! Reading jaf firmware: Ok! (fw: 01b1) nokia n95 rm159 unlock: Start! Set phone to test mode: Ok! Set jaf to fbus mode: Ok! Reading mcu sw version: Error! Nokia n95 rm159 unlock: End! Connecting to jaf: Ok! Reading jaf firmware: Ok! (fw: 01b1) unlock: Start! Set phone to test mode: Ok! Set jaf to fbus mode: Ok! Reading mcu sw version: Error! Unlock: End! |
12-20-2008, 14:58 | #10 (permalink) |
Member: 508022 Status: Offline Thanks Meter: 2 | i have a big problem i always see CONNECTING TO JAF: OK! READING JAF FIRMWARE: OK! (FW: 01B1) NOKIA N95 RM159 UNLOCK: START! SET PHONE TO TEST MODE: OK! SET JAF TO FBUS MODE: OK! READING MCU SW VERSION: ERROR! NOKIA N95 RM159 UNLOCK: END! CONNECTING TO JAF: OK! READING JAF FIRMWARE: OK! (FW: 01B1) UNLOCK: START! SET PHONE TO TEST MODE: OK! SET JAF TO FBUS MODE: OK! READING MCU SW VERSION: ERROR! UNLOCK: END! |
Successfully unlocked 6300 by JAF No Tp unlocker by Cinek | thirunilavan | JAF No Tp Unlocker by Cinek | 2 | 02-03-2009 05:01 |
Successfully Unlock 6300 by bb5 king w/o tp & pkey | R@jusat | Nokia Base Band 5 ( BB-5 ) | 0 | 12-31-2008 11:53 |
success unlock 6300 version 5.50 | DaWizard | BB5BOX | 6 | 11-26-2007 09:31 |
