12-24-2009, 13:15 | #1 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 631998 Status: Offline Thanks Meter: 13 | unable to read code htc touch dual (niki 100) 12:10:21 > VERSION MICRO-BOX A.I.O. V1.0.1.2 12:10:21 > HTC NIKI READ CODES: START! 12:10:21 > CONNECTING TO SERVER: OK! 12:10:22 > ASKING SERVER FOR ACCESS: ACCEPTED! 12:10:23 > CHECKING HTC ACTIVATION: OK! 12:10:23 > HTC: ACTIVATED 12:10:25 > CHECKING MBTOOL INSTALLATION: OK! 12:10:28 > SENDING WINDOWS MOBILE LOADER: OK! 12:11:31 > SEARCHING FOR PHONE: NOT FOUND! 12:11:31 > HTC NIKI READ CODES: END! and if i disconnect and reconnect quickly during "searching for phonoe" its get detected but again giving following error : 11:48:03 > VERSION MICRO-BOX A.I.O. V1.0.1.2 11:48:03 > HTC NIKI READ CODES: START! 11:48:03 > CONNECTING TO SERVER: OK! 11:48:04 > ASKING SERVER FOR ACCESS: ACCEPTED! 11:48:04 > CHECKING HTC ACTIVATION: OK! 11:48:05 > HTC: ACTIVATED 11:48:06 > CHECKING MBTOOL INSTALLATION: OK! 11:48:09 > SENDING WINDOWS MOBILE LOADER: OK! 11:48:15 > SEARCHING FOR PHONE: OK! 11:48:16 > READING MODEL: OK! 11:51:13 > SENDING LOADER: ERROR 1003! 11:51:15 > RESTARTING PHONE: ERROR 1002! 11:51:15 > HTC NIKI READ CODES: END! any idea what to do |
12-26-2009, 07:12 | #3 (permalink) |
No Life Poster Join Date: Apr 2008 Location: ♥ ♥ ♥ ♥ Age: 35
Member: 748880 Status: Offline Thanks Meter: 1,705 | 1 - Install Microsoft Activesync on your computer 2 - Download latest microbox Archive from support, inside this file you can find the HTC Micro-Box Tool.cab. 3 - Connected Your HTC at your computer with Activesync 4 - Copy the HTC Micro-Box Tool.cab file to your phone 5 - Install the file on your phone. 6 - Run Microbox ALL In One software, and Select your Modele in list : Press Read code ! |
The Following User Says Thank You to SOHAIL BASHARAT For This Useful Post: |
12-27-2009, 12:28 | #8 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 984268 Status: Offline Thanks Meter: 150 | .... im connecting the phone true activesync (phone hafe no security code) micro box detects the phone and when i push the read code buttons this is the log 12:10:21 > VERSION MICRO-BOX A.I.O. V1.0.1.2 12:10:21 > HTC NIKI READ CODES: START! 12:10:21 > CONNECTING TO SERVER: OK! 12:10:22 > ASKING SERVER FOR ACCESS: ACCEPTED! 12:10:23 > CHECKING HTC ACTIVATION: OK! 12:10:23 > HTC: ACTIVATED 12:10:25 > CHECKING MBTOOL INSTALLATION: OK! 12:10:28 > SENDING WINDOWS MOBILE LOADER: OK! 12:11:31 > SEARCHING FOR PHONE: NOT FOUND! 12:11:31 > HTC NIKI READ CODES: END! and if i reconnect my phone when it is searching i get this... 11:48:03 > VERSION MICRO-BOX A.I.O. V1.0.1.2 11:48:03 > HTC NIKI READ CODES: START! 11:48:03 > CONNECTING TO SERVER: OK! 11:48:04 > ASKING SERVER FOR ACCESS: ACCEPTED! 11:48:04 > CHECKING HTC ACTIVATION: OK! 11:48:05 > HTC: ACTIVATED 11:48:06 > CHECKING MBTOOL INSTALLATION: OK! 11:48:09 > SENDING WINDOWS MOBILE LOADER: OK! 11:48:15 > SEARCHING FOR PHONE: OK! 11:48:16 > READING MODEL: OK! 11:51:13 > SENDING LOADER: ERROR 1003! 11:51:15 > RESTARTING PHONE: ERROR 1002! 11:51:15 > HTC NIKI READ CODES: END! this problem i hafe with 2 htc niki's and i try to put the phone in bootloader when it is searching but it gives another error...... |
12-27-2009, 12:40 | #9 (permalink) |
Member: 748880 Status: Offline Thanks Meter: 1,705 | plz check your phone is connect properly with activesync before ? First connect phone proper with activesync after press read code and also try method like i said as at post (3) . |
12-28-2009, 13:47 | #12 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: In code Age: 52
Member: 6321 Status: Offline Thanks Meter: 1,665 | Quote:
Can you test something right now ? after send loader and start search for phone wait like 10 sec, disconnect phone, wait again 10 sec, connect back then report me what happen please | |
01-17-2010, 15:59 | #15 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Hi, U followed as been said above copy cab file to phone install it ? then entablish active sync connection and proceed for unlock..? what u cant install cab file i guess u have app lock on |
How to Enter code HTC Touch HD | louisgsm | FuriousGold | 14 | 05-27-2013 22:10 |
Unable to read K-Touch H888 | m_amien | Infinity-Box | 4 | 03-18-2010 15:50 |
How to Upgrade ROM of HTC Touch Dual and to Put Language Portugese? | nofear99 | HTC & PDA WM( With Touchscreen) | 1 | 11-18-2009 05:20 |
Unlock HTC Diamond/HTC Touch PRO/HTC Touch Dual/HTC **** Instantly at 10 EUR only | HTCodes | Main Sales Section | 0 | 12-03-2008 18:50 |
