09-25-2012, 10:08 | #1 (permalink) |
Registered User Join Date: Feb 2006 Location: Ireland / Belarus
Member: 234917 Status: Offline Thanks Meter: 160 | Vodafone 858 drivers needed [Solved] |
09-25-2012, 11:26 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Tunisia
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | You need turn phone in test mode. VOL DOWN + POWER button hold about 10 secound and you should see only logo on lcd. When 10 secounds gone, stop hold buttons and just connect usb cable to phone and do unlock |
09-25-2012, 11:51 | #4 (permalink) |
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | try this HiSuite - Android Smart Device Manager - Huawei Device., Co Ltd.. you must install hisuite by huawei v1.6.10.1606 |
The Following User Says Thank You to noure30 For This Useful Post: |
09-25-2012, 12:52 | #5 (permalink) |
Member: 234917 Status: Offline Thanks Meter: 160 | Just spotted the drivers on support and have finally succeeded Code: 12:46:33 > VODAFONE 858 SMART UNLOCK: START! 12:46:33 > KILLING ADB SERVER (IF RUNNING): OK! 12:46:34 > READING INFO: OK! 12:46:34 > MANUFACTURER: HUAWEI 12:46:34 > MODEL: U8160 12:46:34 > VERSION: U8160V100R001C02B650 12:46:34 > CHECKING PHONE VERSION: SUPPORTED! 12:46:45 > SWITCHING TO FAST-BOOT MODE: ERROR! 12:46:45 > PLEASE MANUALLY PUT PHONE IN FAST-BOOT MODE! 12:46:45 > POWER OFF PHONE AND DISCONNECT FROM USB CABLE! 12:46:45 > WITH PHONE OFF PRESS VOLUME DOWN + POWER ON! 12:46:45 > KEEP PRESSED FOR ~10 SECONDS AND THEN RECONNECT TO USB! 12:47:08 > WAITING FOR FAST-BOOT MODE: OK! 12:47:08 > SENDING PARAMETERS: OK! 12:47:23 > SEARCHING FOR PHONE: NOT FOUND! 12:47:23 > PLEASE RECONNECT PHONE TO USB! 12:47:25 > SEARCHING FOR PHONE: OK! 12:47:25 > READING PARAMETERS: OK! 12:47:25 > READING FLASH INFO: OK! 12:47:25 > FLASH ID: Hynix 4Gbit (ADBC:1055, 1000, 0040, 0800) 12:48:52 > READING BACKUP: OK! 12:48:52 > BACKUPS\VODAFONE\858 Smart\HUAWEI_U8160_U8160V100R001C02B650_356652049416660_2012_09_25_12_48_52_SIMLOCK_BKP.mbf 12:48:53 > SAVING BACKUP: OK! 12:48:53 > OTP_IMEI: 356652049416660 12:48:53 > OTP_BT_ADDR: 19B81E1FC610 12:48:53 > OTP_WIFI_ADDR: 1AB81E1FC610 12:48:53 > ANALIZING SIMLOCK ZONE: OK! 12:48:53 > SIMLOCK STATUS: LOCKED 12:48:53 > WRITING FLASH: OK! 12:48:53 > VODAFONE 858 SMART UNLOCK: END! |
The Following User Says Thank You to ronandaly For This Useful Post: |
