Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Micro-Box Team Products > Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...)
Old 09-22-2008, 19:41   #1 (permalink)
Member: 318507
Thanks Meter: 17
What is F480 procedure? First try with Microbox
This is my first attempt with Microbox.
I have connected F480 to Microbox and E210 combo cable but the phone is not detected. Does the USB lead have to be plugged in anywhere?
Is there a manual anywhere?
I haven’t received confirmation email. Does it matter?
Old 09-22-2008, 19:48   #2 (permalink)
shadi's Avatar
Member: 35002
Sonork: 100.98829
Thanks Meter: 167
samsung f480 unlock done !!!
SAMSUNG F480 UNLOCK: START!
SEARCHING FOR PHONE: FOUND!
READING IMEI: OK!
READING FIRMWARE INFO: OK!
READING HARDWARE INFO: OK!
READING SECURITY DATA: OK!
READING UNLOCK DATA: OK!
CONNECTING TO SERVER: OK!
ASKING SERVER FOR ACCESS: ACCEPTED!
SENDING DATA TO SERVER: OK!
WAITING FOR SERVER: OK!
GETTING UNLOCK DATA FROM SERVER: OK!
UNLOCKING: OK!
DISCONNECTING FROM SERVER: OK!
SAMSUNG F480 UNLOCK: END!
bro use rj and usb cable (e210) same ust cable
unlock done in 1 min
Old 09-22-2008, 19:54   #3 (permalink)
Member: 318507
Thanks Meter: 17
Nothing else happens
Old 09-22-2008, 20:01   #4 (permalink)
shadi's Avatar
Member: 35002
Sonork: 100.98829
Thanks Meter: 167
so your cable not work
Old 09-22-2008, 20:23   #5 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
[COLOR=white]I haven’t received confirmation email. Does it matter?
After you receive your confirmation email you have to download latest software and then update your box firmware, then install samsung cdma drivers, and make sure you set your phone's connection mode to PC Studio in menu, after all these steps you should be able to unlock your phone. Luck
Old 09-22-2008, 22:49   #6 (permalink)
Member: 318507
Thanks Meter: 17
I downloaded PC Studio (it took about 1 hour) and tried again:
READING IMEI: OK!
ASKING SERVER FOR ACCESS: NOT ACCEPTED! (PLEASE USE LAST SOFTWARE VERSION!)
I still haven't received conformation email.
Old 09-22-2008, 23:12   #7 (permalink)
midou01's Avatar
Member: 40632
Sonork: 98231
Thanks Meter: 1,658
READING IMEI: OK!
The solution is there m8, use last version, you can check it here http:///vbb/showthread.php?t=483193
For confirmation email, try to login with your user/pass, sometimes the email is redirected to spam folder by your mail provider.
Old 09-22-2008, 23:19   #8 (permalink)
Member: 318507
Thanks Meter: 17
Thank you all for great help. Microbox has been activated and I got this:
READING IMEI: OK!
UNLOCKING: OK!
I have one more problem. Phone asks for password to enter menu options. Can I read codes? Or is there a standard password?
I also have NsPro but F480 is not supported. Can I read codes using a different phone model?
Old 09-22-2008, 23:29   #9 (permalink)
midou01's Avatar
Member: 40632
Sonork: 98231
Thanks Meter: 1,658
READING IMEI: OK!
UNLOCKING: OK!
try with 00000000 as standard password, if not work then reset your phone with *2767*3855#
Old 09-22-2008, 23:45   #10 (permalink)
Member: 318507
Thanks Meter: 17
Thank you all, very helpful. I entered 00000000 and cleared the PIN numbers. Phone is ready for customer.
Old 10-02-2008, 14:23   #11 (permalink)
Crazy Poster
Member: 639799
Thanks Meter: 3
Hi do i need log to unlock f480
Hi do i need log to unlock f480 or i need to flash i'm new to micro box
thanks bye
Old 10-02-2008, 14:29   #12 (permalink)
Member: 318507
Thanks Meter: 17
Logs not needed for this phone. Have you activated box and unlocked any phones yet?
If yes, just make sure you have the latest version of the software and follow the instructions.
Old 10-02-2008, 17:16   #13 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
password to enter menu can't be read by Micro-Box , ( also no box can do it until now and via rest don't succeed i am still searching for solution )
First try with Vygis to unlock KE970 justmegt VygisToolbox 6 12-05-2007 01:10
What is the procedure for unlock bb5 with UID box Amit Tank UID - Box 7 09-20-2007 15:27
what is the procedure for changing band in bb uqbah FuriousGold 1 07-07-2006 11:41
what is the procedure change imei j300i Amit Tank Cruiser Suite 0 06-09-2006 06:40
First try with Phoenix Bernie Phoenix Black Box 13 06-09-2005 11:26
Page generated in 0.24029 seconds with 9 queries
