Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 01-06-2014, 12:40   #16 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
Thanks Meter: 503
post the screenshot and LOGS...
Old 01-07-2014, 09:57   #17 (permalink)
karwanyhata's Avatar
Member: 211830
Thanks Meter: 13
same as you said not luck for me too tried many pcs plz spt team give slution
Old 01-18-2014, 15:20   #18 (permalink)
SanjanMobile's Avatar
Member: 316292
Thanks Meter: 102
FLASH N9005JVDMJ4 FILE FROM SUPPORT
REMOVE ID LOCK (DOWNLOAD MODE)
RESET EFS (DOWNLOAD MODE)
Use *#0808# Set USB Settings to DM + MODEM + ADB
WRITE SUPER IMEI
WITH UNLOCK - RESET PHONE - AUTO RESTART (RJ45 CABLE)
SELECT N9005W8 SELECT MODEM PORT REPAIR 3G (MODEM PORT)
100% OK
The Following User Says Thank You to SanjanMobile For This Useful Post:
Old 01-30-2014, 14:14   #19 (permalink)
simcityreal's Avatar
Member: 955971
Sonork: 100.1638835
Thanks Meter: 115
N9005 not working 3G........
Originally Posted by SPTTEAM View Post
choice n900w8 and press repair 3g
After Not Working 3G Network(Data & Voice)WCDMA mode.........
Old 01-31-2014, 06:56   #20 (permalink)
Member: 955971
Sonork: 100.1638835
Thanks Meter: 115
Red face
WRITE SUPER IMEI
100% OK
After No Working 3G Network(Data & Voice)WCDMA mode.........
working 2G Only......
Old 02-01-2014, 12:38   #21 (permalink)
Member: 87188
Thanks Meter: 227
WRITE SUPER IMEI
100% OK
Supplement if the 2G is not working:
After again SPT SELECT SM-N9005 MODEM PORT REPAIR 3G
Then continue on 2G and 3G will be too!
If (very rarely) does not come 3G:
Then It makes no sense but you can also: octopusbox select SM-N900W8 repair nvm and 3G will be too.
(this time on 2G is no longer lost approx. 20pcs SM-N9005 Tested)
Old 02-01-2014, 12:41   #22 (permalink)
Member: 87188
Thanks Meter: 227
Old 02-01-2014, 21:15   #23 (permalink)
Member: 87188
Thanks Meter: 227
Sorry, I can no longer modify my previous post but it's clear:
Supplement if the 2G is not working after imei repair:
SPT: SELECT N900W8 SELECT MODEM PORT REPAIR 3G (MODEM PORT)
Then 2G OK but the 3G probably will not work:
Old 02-02-2014, 20:02   #24 (permalink)
Member: 1246670
Sonork: tanveermantu
100% working
I test dis solutiin and done .fully network....now am happy
Old 10-14-2014, 08:36   #25 (permalink)
Member: 205474
Sonork: 100.1585171
Thanks Meter: 97
have unlock n9008w unlock done but no network register
Old 01-19-2015, 23:03   #26 (permalink)
Member: 1347775
newwwwwwwwwww
Step 1 connect phone in download mode
step 2 choose sm-n9005 in spt box
step 3 click reset default efs
step 4 write super imei + unlock
now u dont have network
step 5 do imei repair with original imei dont choice unlock
i hope now you have network
if dont work after setp4 flash youer phone then do step 6
Old 01-20-2015, 00:13   #27 (permalink)
Member: 1319175
Sonork: 1000.2
Thanks Meter: 51
3g repair with usb cable not with uart
Old 01-20-2015, 00:13   #28 (permalink)
Member: 2076039
Thanks Meter: 648
You MUST write a QCN to the phone. Just restoring the NV items does not work.
Page generated in 0.18500 seconds with 9 queries
