01-18-2014, 15:20 | #18 (permalink) |
Freak Poster Join Date: Jul 2006 Age: 45
Member: 316292 Status: Offline Thanks Meter: 102 | FLASH N9005JVDMJ4 FILE FROM SUPPORT REMOVE ID LOCK (DOWNLOAD MODE) RESET EFS (DOWNLOAD MODE) Use *#0808# Set USB Settings to DM + MODEM + ADB WRITE SUPER IMEI WITH UNLOCK - RESET PHONE - AUTO RESTART (RJ45 CABLE) SELECT N9005W8 SELECT MODEM PORT REPAIR 3G (MODEM PORT) 100% OK |
The Following User Says Thank You to SanjanMobile For This Useful Post: |
01-31-2014, 06:56 | #20 (permalink) | |
Freak Poster Join Date: Jan 2009 Location: india,kerala..in NAJMU
Member: 955971 Status: Offline Sonork: 100.1638835 Thanks Meter: 115 | Quote:
working 2G Only...... | |
02-01-2014, 12:38 | #21 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 227 | Quote:
After again SPT SELECT SM-N9005 MODEM PORT REPAIR 3G Then continue on 2G and 3G will be too! If (very rarely) does not come 3G: Then It makes no sense but you can also: octopusbox select SM-N900W8 repair nvm and 3G will be too. (this time on 2G is no longer lost approx. 20pcs SM-N9005 Tested) Last edited by Pufi164; 02-01-2014 at 12:44. | |
02-01-2014, 21:15 | #23 (permalink) |
Member: 87188 Status: Offline Thanks Meter: 227 | Sorry, I can no longer modify my previous post but it's clear: Supplement if the 2G is not working after imei repair: SPT: SELECT N900W8 SELECT MODEM PORT REPAIR 3G (MODEM PORT) Then 2G OK but the 3G probably will not work: After again SPT SELECT SM-N9005 MODEM PORT REPAIR 3G Then continue on 2G and 3G will be too! If (very rarely) does not come 3G: Then It makes no sense but you can also: octopusbox select SM-N900W8 repair nvm and 3G will be too. |
01-19-2015, 23:03 | #26 (permalink) |
Junior Member Join Date: Jul 2010 Location: egypt Age: 43
Member: 1347775 Status: Offline Thanks Meter: 0 | newwwwwwwwwww Step 1 connect phone in download mode step 2 choose sm-n9005 in spt box step 3 click reset default efs step 4 write super imei + unlock now u dont have network step 5 do imei repair with original imei dont choice unlock i hope now you have network if dont work after setp4 flash youer phone then do step 6 |
