Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 05-10-2013, 20:11   #1 (permalink)
DjamelGsm's Avatar
Member: 1612184
Thanks Meter: 103
Big Problem activation SPT-BOX[ANSWERED]
=> S/N: 0000XXXXXXXXX (XXXXXX)
==> Box owner: djamelgsm
==> Box owner e-mail: djamelgsm@XXXXXXXX
==> Reseller: GSMSOURCE
==> connecting to http://register.sptbox.info/...
searching dongle...
dongle found
==> result:
[0000XXXXXXXXXXXX]
Active=7416XXXXXXXXXXXX
searching dongle...
dongle found
firmware version: 0004
SPT-Box serial number (S/N): 000XXXXXXXXXXXX (XXXXX)
dongle hardware serial: 000XXXXXXXXXXXXX
Done: 0000XXXXXXXXXXX
Activation file created: user.ini
Copy file user.ini to folder with SPT-Box software !
Where can I find a file USER.INI
I did not find the file in email or in the computer
Old 05-10-2013, 20:35   #2 (permalink)
Haicha's Avatar
Member: 330579
Thanks Meter: 67,515
Copy file user.ini to folder with SPT-Box software ![/CODE]
Salam Brother!
Check C:\program filles\spt there must have user.ini file
You have File in your HDD Brother! Check better.After Run two Times Prog.
Regards
The Following User Says Thank You to Haicha For This Useful Post:
Old 05-10-2013, 21:42   #3 (permalink)
DjamelGsm's Avatar
Member: 1612184
Thanks Meter: 103
I've been activation
how activation Support Torrent???
Old 05-11-2013, 08:00   #4 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Both support arena should be activated in 24h after box activation with activator if not mean need ask your seller to help becosue he not add your serial that he sold and untile this your serial will not work with support arena but if your serial work with normal support and not with torrent mean problem on your side mean you not use utoorent 2.2.1 or other problem on your computer.
The Following User Says Thank You to wgmmmx1 For This Useful Post:
Old 07-03-2013, 08:05   #5 (permalink)
Member: 1582534
sir my spt torrent support not working plz help
Server Error in '/' Application.
The resource cannot be found.
Old 07-03-2013, 08:12   #6 (permalink)
Member: 1598381
Sonork: 1595992
Thanks Meter: 20
this verion of SPT SPTCARD1637 have no utorrent server......
Old 07-03-2013, 08:17   #7 (permalink)
Member: 535033
Sonork: 100.45908
Thanks Meter: 18,870
torrent support closed permantly now just have sptbox.com and sptbox2.com support area
The Following User Says Thank You to SPTTEAM For This Useful Post:
Old 02-10-2014, 11:42   #8 (permalink)
Member: 1582534
searching dongle...
dongle found
SPT-Box serial number (S/N): 00003C07510309BA (15367)
dongle hardware serial: 000AE258FF021982
==> SPT-Box S/N: 00003C07510309BA (15367)
my spt support not working plz help
Old 03-28-2014, 00:10   #9 (permalink)
Member: 558861
Thanks Meter: 26
Same problem here
Same problem here
box not working
Old 03-28-2014, 10:10   #10 (permalink)
Member: 1043909
Thanks Meter: 60,926
Originally Posted by mohammadfayyaz View Post
Same problem here
box not working
If you have SPT-Box activated for Infinity product - post your problem here: http://forum.gsmhosting.com/vbb/f452...-here-1777796/
If you have ordinary SPT-Box - wait answer from SPT-Box Supporters.
Old 01-18-2019, 12:35   #11 (permalink)
Member: 2508193
i have spt and its support not working....
Old 01-18-2019, 13:14   #12 (permalink)
THE GREAT ONE's Avatar
Member: 751235
Sonork: 100.1662008
Thanks Meter: 526
wakeup is 2019
Page generated in 0.23210 seconds with 8 queries
