E2120b restrting/blinking only[SOLVED] E2120B RESTARTING CONTINUOUSLY TRIED TO RESET PHONE BUT SPT SHOWS FOLLOWING Connect Phone OK. Enter TAT Mode OK! Read Phone Info ... SW Ver: E2120XEIG3 HW Ver: MP 0.402 IMEI: 000440CC320100 S/N: RVKS928353 Check MSL Code Failure ! Total Time: 45.93 s ANY BODY EXPLAIN WHAT MSL CODE THANX |
E2120B need reflash phone if its blinking |
Flash file needed Please upload e2120b flash file to the support area. |
some days later will be added this model support also other more |
flash file can i flash the phone with following files. E2120XEIG3.cla E2120XEIG3.tfs |
E2120BBOIJ1.rar - 4shared.com - online file sharing and storage - download Br, XCachorrOX |
e2120 unlocking problem Hello XcachorroX Fashed handset with your file perfectly but for unlocking spt gives following log for spt mode Connect Phone OK. Enter TAT Mode OK! Read Phone Info ... SW Ver: E2120BBOIJ1 HW Ver: MP 0.402 IMEI: 000440CC320100 S/N: RVKS928353 Check MSL Code Failure ! Total Time: 42.18 s and for factory mode Press Power On Key ... Connect Phone OK. Initialize Phone ... Reading Device Info ... Flash ID: [ K5N5629ATA_TOP ] Initialize Phone OK. Switch Baudrate ... Switch Baudrate to 115200 Bps Transfer Boot Data... Boot OK. Reading E2p ... Old IMEI: 000440<<320100 MCK: 00000000 NCK: 00000000 SCK: 00000000 SPCK: 00000000 CPCK: 00000000 Writting E2p ... Write Data Error ! Total Time: 98.73 s |
did you try which version spt must use 9.2.6 or 9.3.0 we have tested this versions for this model |
I tried with 9.2.6 the log is as follows Press Power On Key ... Connect Phone OK. Initialize Phone ... Reading Device Info ... Flash ID: [ K5N5629ATA_TOP ] Initialize Phone OK. Switch Baudrate ... Switch Baudrate to 115200 Bps Transfer Boot Data... Boot OK. Reading E2p ... Old IMEI: 000440<<320100 MCK: 00000000 NCK: 00000000 SCK: 00000000 SPCK: 00000000 CPCK: 00000000 Writting E2p ... Write Data Error ! Total Time: 98.20 s |
Old IMEI: 000440<<320100 eeprom damaged u need first find good eeprom and write then later try write imei |
write data error hi can any one help me for this while Restore ee or Reset default ee it shows Press Power On Key ... Connect Phone OK. Initialize Phone ... Reading Device Info ... Flash ID: [ K5N5629ATA_TOP ] Initialize Phone OK. Switch Baudrate ... Switch Baudrate to 115200 Bps Transfer Boot Data... Boot OK. Reading E2p ... Old IMEI: 000440<<320100 Writting E2p ... Write Data Error ! Total Time: 94.70 s |
Added you on msn .... |
first write gud eprom if ur phone will dead after write eprom then flash it . |
bro i have 4 eprom files but cant write to phone it gives write data error can u explain how to write eprom file. |
