Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > SPT BOX
Old 05-26-2009, 12:06   #1 (permalink)
rea1One's Avatar
Member: 236564
Failed to unlock S7350
Failed to unlock S7350 via Qulcomm mode.
Qualcomm modem not found. why?
Old 05-26-2009, 14:17   #2 (permalink)
Member: 137474
Sonork: 100.109924
You need select too LOCAL UNLOCK and select com port not modem. bye
Old 05-26-2009, 14:22   #3 (permalink)
rea1One's Avatar
Member: 236564
LOCAL UNLOCK
same problem.
Can Not Found Qualcomm Modem Port!
Total Time 51.05s
this is umts phone.
SPTBOX Deluxe 4.9.2
Now With Spt Can Just With Usb Cable Unlock And Repair imei ALL Umts Model.
SPTBOX Deluxe 4.9.2 RELEASED!!!
Old 05-26-2009, 15:30   #4 (permalink)
SPTTEAM's Avatar
Member: 535033
Originally Posted by rea1One View Post
same problem.
Total Time 51.05s
this is umts phone.
Procedure is following.
1. Connect phone in qualcomm mode then press rescan port
2. Spt Will Find A Port
3. Then Replug Phone
4. Rescan Port Again
5. Now Will have 2 Qualcomm port same time and will work unlock and imei
B.R
Old 05-26-2009, 17:59   #5 (permalink)
rea1One's Avatar
Member: 236564
B.R
yes sir that was the my procedure.
not only twice but more i unplug & replug usb, still only one Qualcomm usb port found.
Qualcomm Modem port not appear on port settings.
Old 05-27-2009, 00:46   #6 (permalink)
xiaoyuz's Avatar
Member: 76767
Sonork: 100.1594567
what ver qualcomm driver your install?
For S7350 I think you need install quallcomm driver 2.0.3.9
try this
C:\Program Files\SPT\Driver\Samsung Qualcomm MSM7200A HS USB Driver
B.R
Xiaoyuz
Old 05-27-2009, 04:26   #7 (permalink)
hoangtruongson's Avatar
Member: 392170
Sonork: 1587688
Here log Samsung S8300
then try again
Not succesfull with SPT 4.9.2
Old 05-28-2009, 06:30   #8 (permalink)
SPTTEAM's Avatar
Member: 535033
this error mean phone have problem need flash with boot file then try again
Old 05-29-2009, 10:26   #9 (permalink)
BouRRi_GSM's Avatar
Member: 111457
Attachment 199730
then try again
Attachment 199731
Flash with unbranded FW then unlock.
br
Failed to Unlock 2323c Using Super DCT4 Activation [Solved Thanks to Alex] tims Cyclonebox 7 07-31-2010 10:31
2680s RM500 keeps on failing to unlock! how to solve this??? Unlockemall Universalbox 14 02-20-2010 09:51
Z240 failed to unlock using " Fast Direct Unlock " A-H-T UST Pro II 23 11-06-2009 10:43
How to unlock s7350 with ust faisal4friend UST Pro II 5 09-08-2009 12:13
Page generated in 0.72280 seconds with 12 queries
