Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 10-24-2014, 21:31   #1 (permalink)
Member: 2156601
Thanks Meter: 3
G900t imei repair help[ANSWERED]
Have problem on g900t after reset efs I cannot get to repair imei. Do I change diag mode to dm-modem-adb When selecting com port? I kept it on mtp adb mode then plugged in to uart cable. Factory mode never displays so I'm not sure where I am going wrong.
Old 10-25-2014, 06:33   #2 (permalink)
sunilkumar70791's Avatar
Member: 1432329
Sonork: 100.1615863
Thanks Meter: 1,626
Hi,
plese post full logs or screen shot for better understand your problem
Old 10-25-2014, 07:01   #3 (permalink)
Member: 655586
Thanks Meter: 11
do a factory reset after efs reset. it will work then 100 %.
Old 10-26-2014, 08:39   #4 (permalink)
zakryia's Avatar
Member: 640361
Thanks Meter: 77
I have the same problem
Old 10-26-2014, 16:52   #5 (permalink)
Member: 2076039
Thanks Meter: 648
DM+MODEM+ADB to write IMEI. UART must be set to pda not modem. Didn't write it? Disable knox. Still didn't write it? Take battery out of phone, put battery back in and try again.
The Following User Says Thank You to ecs87 For This Useful Post:
Old 10-26-2014, 18:28   #6 (permalink)
Member: 272796
Sonork: 1603232
Thanks Meter: 411
* SM-G900T Flash Supported Only Check Before Posting.\
Use Search Button Before Last Waring Next Post With out check that supported or not will be Deleted
Page generated in 0.19364 seconds with 9 queries
