03-03-2014, 02:23 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: XpErTs GsM ® Age: 41
Member: 272796 Status: Offline Sonork: 1603232 Thanks Meter: 411 | Guide for Note 3 Unlocking/IMEI Repair Moving Into Main Guide Thread ***SUPPORTED MODELS*** * First IN WORLD SM-N900 Unlock/Super IMEI * First IN WORLD SM-N900W8 Unlock/Super IMEI * First IN WORLD SM-N900T Unlock/Super IMEI * First IN WORLD SM-N900A Unlock/Super IMEI * First IN WORLD SM-N900V Unlock/Super IMEI (N900T or A or V Pls Choose N9005/N900w8 To Reset EFS) * First IN WORLD SM-N9008 Unlock/Super IMEI * First IN WORLD SM-N9006 Unlock/Super IMEI * First IN WORLD SM-N9005 Unlock/Super IMEI * First IN World SM-N9008V Flash/UNLOCK/SuperIMEI ---NOTE--- All Note 3 With Current Unlocking Solution You Will Lose Original IMEI And Will Be Replaced With Supper IMEI.****Procedure of Unlocking/Repairing(NEWBIES)***** 1- Select Supported Model From List 2- Put Your Phone In Download Mode 3- Reset Default EFS 4- Select Comport Use UART Cable 5- Chose Supper IMEI 6- Select Repair IMEI + UNLOCK 7- Do Factory Mode (Further Network and 3g Problems for Any Note 3 Select N9005 or N900w8) 8- Select Comport Use UART cable (For 4.3 Version) 9- Dial *#7284# and choose UART -> MODEM and Qualcom Setting DM+MODEM+ADB 10- DIAL *#0808# Select DM OVER UART 11- Do 3G NETWORK REPAIR (For 4.4.2 KITKAT All Models Execpt N900 Root Your Phones After Supper IMEI to Repair 3g/4g Network and Signals After ROOTING Just Do *#0808# Select DM+MODEM+ADB Connect USB and Select Daignostic PORT And Repair IT ) ****Procedure of Unlocking/Repairing(EXPERTS)***** 1- Select Model and RESET DEFAULT EFS 2- Select Supper IMEI Then REPAIR IMEI + UNLOCK With UART Cable 3- For Network Problems Repair 3G Network With UART 4-Dial *#7284# and choose UART -> MODEM and Qualcom Setting DM+MODEM+ADB 5-DIAL *#0808# Select DM OVER UART and Click Repair 3G Network NOTE: ( N9005 AND N900w8 are Similer You can Reset EFS and repair IMEI and 3g Network for N9005 in N900w8 ) (For 4.4.2 KITKAT All Models Execpt N900 Root Your Phones After Supper IMEI to Repair 3g/4g Network and Signals After ROOTING Just Do *#0808# Select DM+MODEM+ADB Connect USB and Select Daignostic PORT And Repair IT ) Best Regards: Team SPT Last edited by XpErTsGsM; 08-25-2014 at 16:42. |
The Following 29 Users Say Thank You to XpErTsGsM For This Useful Post: |
03-05-2014, 17:35 | #4 (permalink) |
No Life Poster Join Date: Apr 2012 Location: Black Market Age: 39
Member: 1744748 Status: Offline Thanks Meter: 752 | Is super IMEI a unique imei for all unlocks or its a random imei which changes everytime you open the unlock application? my question is if there are 100 phones with same super imei it will be blacklisted by the provider... I don't want many customers coming to my shop with their phones blocked. Please advise I am trying to make a decision of buying this device.... also is there a way to edit the efs file to replace it with original imei? |
03-05-2014, 17:38 | #5 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: DUBAI Age: 33
Member: 1189306 Status: Offline Sonork: 100.1589231 Thanks Meter: 273 | Quote:
now in this time no one have other option for note 3 unlocking with out the super ime. Bro | |
03-05-2014, 17:41 | #6 (permalink) |
Member: 1744748 Status: Offline Thanks Meter: 752 | So basically when you are resetting the default efs... I am guessing the imei (super imei) is included in that... is there a way to alter it manually using a software? |
03-05-2014, 17:46 | #7 (permalink) | |
when you default after that u will be write the super ime. And there is aprox 100+ super ime list.. Now its depend on u witch one u wanna write to ur set.. Bro | |
03-16-2014, 10:34 | #10 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Kuwait
Member: 735013 Status: Offline Thanks Meter: 74 | Ok, I have N9005XXUBMJ2 version. Dialing *#7284# is not working unless you have connected UART Cable. Dialing *#9090# says not supported. Dialing *#0808# has the option for DM+MODEM+ADB I got connection failure while performing the above instruction. What I need to know is, Is there any specific version to be able to unlock this device? Because I'm planning to upgrade to kitkat in order to change the modem of the device. hoping for you immediate support. tnx |
03-16-2014, 13:13 | #11 (permalink) | |
Member: 272796 Status: Offline Sonork: 1603232 Thanks Meter: 411 | Quote:
First Wipe/Format Your Phone Then Do Step By Step.... Dont Upgrade To KitKat if You Are Unlocking/Repairing Your Phone.. Detail About KITKAT is Here .. !!! WARNING !!! Dont Upgrade To 4.4.2 KITKAT [UPDATED] | |
The Following 2 Users Say Thank You to XpErTsGsM For This Useful Post: |
03-17-2014, 12:32 | #12 (permalink) |
Member: 735013 Status: Offline Thanks Meter: 74 | Still it can not detect the phone Detect Phone Connect ... Connect Phone Failure ! Please Sure Phone Is Download Mode ! Total Time: 2.25 s |
The Following User Says Thank You to czaren For This Useful Post: |
03-18-2014, 03:48 | #13 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi About SM-N900 and Similer ,"Reset Default EFS " Not Working if Phone is in 4.4.2 Please fix this... About SM-N9005,,,, *#7284# not work in 4.4.2.... Plus *#0808# Can Show "DM+ADB+Modem" and 3g Can repair only via USB..... But Phone Still "No Services" With 3g Sim.... 2g working Anyway....Please Fix This Problem in next update Thanks -- Who have problem for detecting phone with repair 3g button....Follow This: 1-enable "USB Debauging" 2-Accept HW Fingerprint 3-Dial *#0808# 4-Select "DM+ADB+Modem" 5-Press "Scan" and Now You Must See 2 Port(with usb).... JUST SELECT Higher Number for example if you see port 100 and 101.....Need select port 101 6-Now Press repair 3G Button -- if any one sucess repair 3g and phone back to work,,,Please report ...Plus Tell us for which firmware have on the phone Thanks again |
The Following 7 Users Say Thank You to BABAK NURI For This Useful Post: |
03-18-2014, 11:46 | #14 (permalink) |
Member: 1189306 Status: Offline Sonork: 100.1589231 Thanks Meter: 273 | @theunlockpros76 hello tick on repair ime and unlock and also select the correct com and use the Gt-c3300k cable are urt cable.. bro |
The Following User Says Thank You to gsm_new1 For This Useful Post: |
