Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 09-16-2014, 20:03   #406 (permalink)
Member: 1851293
Thanks Meter: 19
Originally Posted by truwrxtacy View Post
Hey guys i got a n900A that i am having issues with repairing the 3g net work, and i've read the entire thread.
Its on 4.4.2 I did the super imei repair, but no signal after, I tried to do the network repair, but says not supported, the thread said i need to root it. So
thanks
After the repair, root the phone and do 3G repair with USB cable I have use N900T model, other models cause the baseband to be null (look at OP 1st page) or try Octo been repairing this model with that box, have not had any issues with the signal dropping with them.
Old 09-16-2014, 20:14   #407 (permalink)
Member: 2188956
Thanks Meter: 29
I tried still does not work. Right now i have the IMEI repair via superimei, then i have the phone rooted via towelroot, then i put it into MODEM mode with *#7286#, then i put it into DM + MODEM + ADB with *#8080#, then i plug the phone directly into the computer and choose the appropriate COM port, then i choose n900t click 3g service repair. It goes to Waiting to enter test mode, and the SPT program freezes up and goes into not responding.
Old 09-17-2014, 04:32   #408 (permalink)
Member: 1851293
Thanks Meter: 19
that's the problem you're selecting *#7284# and conecting the phone via usb to the comp, there are 2 ways to do it, if you select *#7284# + 0808 DM....thats for UART cable with BOX COM port, if you going to do with USB just do 0808 and DM....and select the proper usb COM port
Old 09-19-2014, 18:08   #409 (permalink)
Member: 2203633
Thanks Meter: 6
I hope this new update is released soon. Many if the super imei are being blocked now.
Old 09-19-2014, 20:37   #410 (permalink)
Member: 2211311
About Restoring The Original Imei And Fix Baseband on a corrupted S5 & NOTE 3
I found some guys are repairing the original imei's on s5 and note 3 for a hell of a fortune. Is there a way we can do this with any box?
Old 09-22-2014, 19:27   #411 (permalink)
Member: 2262200
Hi, I'm trying repair imei SM-N900T and appear write imli failed, what can I do? someone can help me?
Old 09-25-2014, 11:30   #412 (permalink)
Member: 2214664
Thanks Meter: 16
look
Guide & Step by Step for Note 3 Unlocking/IMEI Repair
http://forum.gsmhosting.com/vbb/f452...014-a-1785414/
Old 10-11-2014, 08:44   #413 (permalink)
Member: 1474211
Thanks Meter: 3
Hi friends can I use z3x uart cable in spt to repair imei in note 3
Thanks
Old 10-11-2014, 08:45   #414 (permalink)
Member: 1474211
Thanks Meter: 3
Thanks
Old 10-20-2014, 22:12   #415 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 347
you around bro need help
Old 10-21-2014, 14:24   #416 (permalink)
Member: 1607116
Sonork: 100.1617729
Thanks Meter: 52
New security, is support?
Note 3 N900A & N900T New security
Old 10-22-2014, 03:47   #417 (permalink)
banziitox24's Avatar
Member: 2051392
Thanks Meter: 161
4.4.4 have you tried IMEI Repair on this version?
Old 10-22-2014, 11:07   #418 (permalink)
Member: 2154494
Originally Posted by XpErTsGsM View Post
---NOTE---
All Note 3 With Current Unlocking Solution You Will Lose Original IMEI And Will Be Replaced With Supper IMEI.
Can anyone confirm that super IMEI is being blocked, and on which carriers has this happened?
I am interested in repairing the IMEI on my T-Mobile Note 3, but if it's just going to be blocked, I won't bother.
Old 10-22-2014, 15:59   #419 (permalink)
Member: 1607116
Sonork: 100.1617729
Thanks Meter: 52
I have not yet tested
Old 10-22-2014, 16:47   #420 (permalink)
Member: 2076039
Thanks Meter: 648
You need to use an IMEI+CERT. I personally wouldn't use a super IMEI. I've had network issues with them.
Page generated in 0.28769 seconds with 9 queries
