04-05-2014, 21:38 | #1 (permalink) |
Freak Poster Join Date: Mar 2011 Location: Dallas
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | Has the unlock process for SM-N900t been proven and tested on SM-N900V [ANSWERED] Thank you for your help everyone. |
04-06-2014, 00:33 | #2 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Quote:
To repair IMEI N900V Select N9005 Put phone into download mode ..... Reset EFS .... Select super IMEI Done.... | |
04-06-2014, 01:14 | #3 (permalink) |
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | yes but no network afterwards and after it fails to connect to write t-mo NV items. NV writer fails because it says phone does not respond. I will try to flash stock odin 4.3 FW and see if that changes. |
04-06-2014, 07:18 | #6 (permalink) |
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | Anything else Fatal.... Do you have any more helpful comments like that?.... i'm sure people would agree that we need more of that here. Last edited by jub2k3; 04-06-2014 at 07:23. |
04-06-2014, 08:58 | #7 (permalink) |
Insane Poster Join Date: Mar 2012
Member: 1730061 Status: Offline Sonork: 100.1660052 Thanks Meter: 15 | Guys, This is HELPFUL for noobies not a dumb thing......... Take the best from mistakes brother and always be positive........ averyone started from the bottom. Good Advice bro. Never mix NV items.... See? that was easy to understand..... |
04-06-2014, 09:15 | #9 (permalink) | |
Dial ##366633# And make sure DM mode is selected ... | |
04-06-2014, 10:38 | #10 (permalink) |
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | I tried to reset efs and then rewrite imei and all worked just fine for a while then it rebooted and im now stuck in a boot loop. Sux first no signal after that delayed signal now no booting and looping @ the verizon logo. Any tips or pointers? |
04-08-2014, 05:36 | #14 (permalink) |
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | The solution was to wipe and flash the original firmware via odin 3.09 and then download mode and reset efs and voila! Working phone.. Thanks to Jose for the spot on advice and precise info. Sent from my GT-N5110 using Tapatalk |
04-08-2014, 17:32 | #15 (permalink) |
Member: 1081371 Status: Offline Thanks Meter: 720 | you shouldn't need to do all that, Unless you did something wrong ... But glad that you go it to work ... |
The Following User Says Thank You to jusmejose For This Useful Post: |
