how to change I9003 IMEI? [SOLVED] I need , change I9003 imei, how to do it? give me a guide!!!!,,, thanks a lot!!!! |
Simple just select model and you will see instruction. You got 2 option. 1. Write patch from support ftp, powered on phone connect to uart/box microusb cabel and change imei(write imei in imei box and press factory mode). 2. Root phone by other free software on net. Restart phone, Select in phone debug mode and install not know aplication, connect to usb cable, select unlock, reset phone and press SPT MODE button after end successfully just write imei like you want got in phone in spt sw and press FACTORY MODE button. |
check i t , no spt mode can be choiced |
just only factory mode appeared |
of course 12.0.0 .......................................... |
if its 12.0.0 should active spt mode for i9003 if still cant see put phone download mode and press efs repair then later write patch file and write imei and unlock |
hi, i am patched phone with i9003patchunlockimeiv3, all process appears ok, but same imei is inside phone. |
solved selecting imei and unlock fields. may be a software bug. if select only imei field reset user code. tnx |
this is not bug should select both for repair imei and unlock B.R |
