05-02-2014, 23:22 | #3 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2173620 Status: Offline Thanks Meter: 0 | Sorry, my telephone is crazy... Hi all i need help with this box, i have a Note 3 SM-N9005 with imei null (/01) and i need to replace it with superimei... reset default efs is ok, but when i insert UART cable in NOTE 3 ( power on), SPT not found nothing... at right of PORT, it says me "USB" and not UART... reset efs work only with usb cable and not with UART. Command *#7284# don't work on my telephone. I have baseband N9005XXUENB1 4.4.2 and modem N9005XXUENB4... i need to activate anyone function for recognize phone at box? I have superuser and knox disabled. And *#0808# is mtp+adb or Dm+modem+adb? I have alrrady tested other uart cable (i have tested 2 cable c3300) With usb i can only reset efs... with uart telephone enter in test mode ok but after it or say me TIMEOUT or at 8% fail the job... please help me Sorry for bad english, i'm italian EDIT: i have tested with another note 3 n9005 4.3, another computer and another version of SPT but give me this problem too Last edited by peyadragons; 05-02-2014 at 23:28. |
05-02-2014, 23:27 | #4 (permalink) |
Freak Poster Join Date: Oct 2012 Location: TURKEY
Member: 1823773 Status: Offline Sonork: 100.1622605 Thanks Meter: 97 | i need help spt box! Pls read post here http://forum.gsmhosting.com/vbb/10135672-post1.html Sent from my iPad 4 using Tapatalk |
05-03-2014, 12:19 | #5 (permalink) |
No Life Poster Join Date: May 2006 Location: XpErTs GsM ® Age: 40
Member: 272796 Status: Offline Sonork: 1603232 Thanks Meter: 411 | First Open You Eyes And See The Step........ You See No Need To Enter Command To Select Settings Before 3g Repair..................... Unlocking And Repairing Need Phone in Normal Condition... ****Procedure of Unlocking/Repairing(NEWBIES)***** 1- Select Supported Model From List 2- Put Your Phone In Download Mode 3- Reset Default EFS 4- Select Comport Use UART Cable 5- Chose Supper IMEI 6- Select Repair IMEI + UNLOCK 7- Do Factory Mode (Further Network and 3g Problems for Any Note 3 Select N9005 or N900w8) 8- Select Comport Use UART cable 9- Dial *#7284# and choose UART -> MODEM and Qualcom Setting DM+MODEM+ADB 10- DIAL *#0808# Select DM OVER UART 11- Do 3G NETWORK REPAIR |
05-03-2014, 12:38 | #6 (permalink) |
Member: 2173620 Status: Offline Thanks Meter: 0 | Repair efs work but when i connect with uart at the box, it or give me "Read SIMLOCK Data Failure" or say "Read MSL Address Failure".. why? And this on note 3 N9005XXUDMJ7 with build MK2 android 4.3 .... and in my Note 3 N9005XXUENB1 4.4.2 and modem N9005XXUENB4 box say TIMEOUT... |
