Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 06-13-2012, 11:30   #16 (permalink)
Member: 306828
Thanks Meter: 8
Originally Posted by SPTTEAM View Post
we got some phone with this problem and start work on it please be patient soon solution will be here
not some!all of them are brick.we want to solution curiously..
Old 06-14-2012, 17:57   #17 (permalink)
Member: 1234013
Thanks Meter: 3
i9300 imei repair, no network
i did the same and now no network and round circle where signal should be..
help to fix the problem.
Old 06-14-2012, 19:31   #18 (permalink)
sameenshah123's Avatar
Member: 619308
Sonork: 100.1591829
Thanks Meter: 243
wait and see............
Attention!!!! All user should read!!!
Old 07-30-2012, 20:54   #19 (permalink)
Registered User
Member: 1221313
Thanks Meter: 259
Please Wait Enter Test Mode ...
Enter Test Mode OK!
Timeout !
Total Time: 8.1 s
The Following User Says Thank You to wahid For This Useful Post:
Old 08-06-2012, 10:30   #20 (permalink)
Member: 535033
Sonork: 100.45908
Thanks Meter: 18,866
who have old gpg red box should use other box hardware for i9300 its not work for enter test mode i9300
Old 08-22-2012, 23:54   #21 (permalink)
Member: 677817
okay ....let starts ... no one box sported yet to repair i9300 imei apart from
spt box .. you can change the imei with spt box .. 2nd thing you need to flash your
phone with odin .. whatever flash filr you got it dosent metter ... i done loads of.phones before .. tht was 004474 like that imei .. let me know if anyone got problem ..
Old 08-23-2012, 00:41   #22 (permalink)
Member: 181405
Thanks Meter: 168
Step repair imei I9300
1 flashing whit I9300XXALEF
2 root I9300_Root by Support
3 connect by USB DEFAULT EFS
4 REAPAIR IMEI by cable RJ45 NETWORK ok 3 phones ok
The Following User Says Thank You to hector bermudez For This Useful Post:
Old 08-29-2012, 12:32   #23 (permalink)
Member: 328688
Thanks Meter: 885
i m using ust pro2 i only get one ok 2 i9300 no network wht is wrong
Old 08-30-2012, 03:58   #24 (permalink)
evasoft's Avatar
Member: 515830
Thanks Meter: 77
1 flashing with I9300XXALEF
4 REPAIR IMEI and unlock by cable RJ45.
now 2 phones dont have signal, i use 14.6.6 software.
i flash with odin and root with SGS3 International ToolKit v3.0.exe and still without signal.
i cant make step 3
3. power on phone (usb debugging enabled in phone setting) and press spt mode ( need use usb cable)
Old 08-30-2012, 15:25   #25 (permalink)
.::PHONECRAKER::.'s Avatar
Member: 1610262
Sonork: 100.1608508
Thanks Meter: 44
I had same problem solotion
1-flash with root file imei will be 0049344434432 some thing like that
2-do factory mode with repir imei and unlock
3 flash with firmware from support
ur signal bar will come after wipe factory reset in recovery mode test by me
br Mansour Pakdel
Old 08-30-2012, 16:07   #26 (permalink)
Member: 328688
Thanks Meter: 885
br Mansour Pakdel
still not working i flash root do efs reset imi change no network even full flash still no network and SPT speed very slow pleazzz put download accelerator
beoz i9300 file 745mb i try still yesterday i didnt get download
i download from z3x fine i flash with odin still no luck i use ustpro
Enter Test Mode OK!
Model Name: GT-I9300
S/W Version: I9300XXALEF
Phone SN: 0000000000
IMEI: none
Write New IMEI: 3531640513xxxxxx
All Jobs Done.
Total Time: 41.20 s
Old 08-30-2012, 16:23   #27 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,172
Enter Test Mode OK!
IMEI: none
All Jobs Done.
Total Time: 41.20 s
Then answer is simple you not follow instruction after you follow you fix phone.
Working IMEI changed phone? Barjo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-01-2015 11:49
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 21:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 17:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
Page generated in 0.59233 seconds with 9 queries
