11-10-2012, 00:16 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 48
Member: 106890 Status: Offline Thanks Meter: 1 | I9300 not go to factory mode [SOLVED] |
11-10-2012, 11:43 | #2 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Procedure is in stick topic with unlock / flash instruction. Realy so hard is read stick topic ? |
The Following User Says Thank You to wgmmmx1 For This Useful Post: |
11-10-2012, 12:08 | #3 (permalink) |
Member: 106890 Status: Offline Thanks Meter: 1 | NOoooo is not hard --I've read istruction but the result is the image I've used this guide...: Instruction to unlock OMAP phones like i8000 and others with USB MICROUSB DATA CABLE: 1. Press *#7284# and select Phone USB 2. Enter in Phone *#9090# 3. Press 1 in new menu 4. Connect to USB microusb cable (normal cable that is with phone in box) 5. Wait untile drivers install 6. Check in device manager on witch port is SAMSUNG DIAGNOSTIC PORT 7. Turn on SPT software 8. Select model 9. Select in port setting COM PORT that is in device manager SAMSUNG DIAGNOSTIC PORT 10. Select speed USB 11. Select UNLOCK/IMEI 12. Press FACTORY MODE 13. After END turn on phone with simcard that not work and when ask for code enter 00000000 14. That's all phone unlocked with USB cable |
11-10-2012, 12:35 | #4 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Man you are stupid or dumb ?? Where is write that this is instruction for I9300 ?? Realy so hard is read english ?? http://forum.gsmhosting.com/vbb/8496157-post23.html |
11-13-2012, 07:47 | #8 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1836149 Status: Offline Thanks Meter: 0 | same problem here. when i connect the box the program only shows USB option and no UART option as it does with other telephones. i connected every UART cable i have and the program still does not see the telephone, therefore it does not go into the factory mode. |
11-15-2012, 13:54 | #9 (permalink) |
Member: 106890 Status: Offline Thanks Meter: 1 | I've resolved problem wirh use the UART cable in USB selection you can do selection of USB port of box |
The Following User Says Thank You to maghiggio For This Useful Post: |
