11-25-2014, 20:43 | #1 (permalink) |
Insane Poster Join Date: Jun 2013
Member: 1959570 Status: Offline Sonork: 100.1661461 Thanks Meter: 2 | I9500 No baseband after spt mode tried to write imei using the rj45 and factory mode but the response is timeout after enter test mode ok. when i dial *#0011# i find the bottom IMEI CERTI : FAIL. trying z3x box reset efs ,write imei , i get back my imei , but no signal. dial *#0011# still IMEI CERTI : FAIL. try repair network in z3x box also no baseband. so now what is the solution for this problem , and what is the solution for the spt box that it seem that it cant not connect with the phone , is it a box problem or what ? Thank you in advance. |
11-26-2014, 05:38 | #4 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Inside the Box, Panama Age: 34
Member: 1468994 Status: Offline Thanks Meter: 27 | download MK9 firmware, change the tar.md5 to tar, open with winrar, extract modem.bin only, open odin v1.85, select phone box on odin and select extracted modem.bin, flash it |
11-26-2014, 08:46 | #5 (permalink) |
Member: 1959570 Status: Offline Sonork: 100.1661461 Thanks Meter: 2 | You mean the mode code finish With mk9 ? Can you send the complete serial ? But you mean this could solve the imei cert fail ! I am running 4.4.2. Sent from my iPhone using Tapatalk |
11-27-2014, 06:56 | #6 (permalink) | |
Member: 1468994 Status: Offline Thanks Meter: 27 | Quote:
change the extensions from *.tar.md5 to *.tar open the file and extract the modem.bin only flash with odin the modem.bin then u have again 0047*********** imei repair with superimei in factory mode Last edited by carlosm15; 11-27-2014 at 07:04. | |
11-27-2014, 07:00 | #7 (permalink) |
Member: 1959570 Status: Offline Sonork: 100.1661461 Thanks Meter: 2 | I did this before and i got 0049xxxx imei , but the problem when i do factory mode in spt box it says enter test mode okay then time out Sent from my iPhone using Tapatalk |
11-28-2014, 07:26 | #11 (permalink) |
Member: 1959570 Status: Offline Sonork: 100.1661461 Thanks Meter: 2 | Hehe its just to show you because its the same for all , and i used the uart , anyway my freind the problem is solved , it was the ftdi driver problem because the com port of spt wasent shown as i show you in all picture . This is the link that helped me. http://www.youtube.com/watch?v=SPdSKT6KdF8 |
