10-15-2014, 05:43 | #1 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2241499 Status: Offline Thanks Meter: 1 | imei unknown. i tried unlocking it but all i was able to do was reset the efs. then i realized i had the no com port problem that everyone else seems to have so i was not able to proceed any further. i cannot get the driver to install i keep getting the yellow triangle. i installed the ftdi drivers and am able to see the com ports now but keep getting com init failure so im giving up on that aspect. i was able to use it in the past but dont know why for the life of me i cant use it now. all i want now is to fix my imei, it reads unkown my baseband reads correct. my imei is not blacklisted but i get all the symptoms because i have unkown imei. i have saved nv with nv writer, the qcn with qpst, but did not save the efs folder. the real problem is that i cannot restore them, something is blocking the write. is it the s5 firmware? i didnt have these problems when i was working with my note 3 nv and qcn. anyone know how i can extract my efs files from these backups or how to force a write to fix my imei thanks for any help |
10-15-2014, 09:39 | #2 (permalink) |
Member: 2241499 Status: Offline Thanks Meter: 1 | Writing NV-items from a file: Unsuccessfully written NV-items: 00001 (0x0001) - Read only item 00002 (0x0002) - Read only item 00003 (0x0003) - Read only item 00550 (0x0226) - Access denied 00855 (0x0357) - SPC (6 digits) is required 01943 (0x0797) - Read only item 05597 (0x15DD) - Read only item 05598 (0x15DE) - Read only item 10155 (0x27AB) - Access denied Done. an example of the error i get from nv writer |
10-21-2014, 09:47 | #3 (permalink) |
Member: 2241499 Status: Offline Thanks Meter: 1 | ok i got my spt box working, i set my model to sm-g900a entered my original imei in both imei slots, entered my sn. it unlocked my phone i had to enter 00000000 as the network code. recovered my imei and sn so they display properly. only thing now i still need to pass imei certi mine is still fail. i still get the not registered on network error. i still have back up of my qcn before i messed with it but i cant restore/write the file with qpst. i keep geting to 2% and then "Memory Restore Failed!" "Received an invalid command from the phone." is my certi stored in my nv file or qcn file? anyone know how i can extract them or restore them? or any other means? ive tried flashing to official, factory restore initializing on kies3. all still same result with imei certi fail. Last edited by foreverfortune; 10-21-2014 at 09:54. |
