Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > SPT BOX
Old 06-27-2011, 10:30   #16 (permalink)
:Aishur:'s Avatar
Member: 1315677
I think these steps are easy, so perform a check list, copy/paste yellow commands (one by one)
Please share template nv_data.bin for the above models
Old 06-27-2011, 10:37   #17 (permalink)
SPTTEAM's Avatar
Member: 535033
u can take from any working phone nv_data.bin its just with one command is possible
adb pull /efs/nv_data.bin thats it will save adb folder nv_data.bin dont forget first need make root phone
The Following 2 Users Say Thank You to SPTTEAM For This Useful Post:
Old 06-29-2011, 02:18   #18 (permalink)
Member: 1368801
hi can;t tried his with t959v or no need know
Old 06-29-2011, 03:17   #19 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
this is not for one-click unlocker or sunday
Old 06-29-2011, 04:15   #20 (permalink)
Member: 1597734
Originally Posted by SPTTEAM View Post
this is not android imei repair spt allready can repair imei this is bad nvm repair if we add under one button so where is professionaly ? Its called for sunday unlocker sorry we havent any plan like this
if we are trying to professionaly like you we dont need your product as well...
i think sunday unlocker cant afford your expensive box...
simple if your investment is high customer will charge...
br,
Old 06-29-2011, 08:42   #21 (permalink)
SPTTEAM's Avatar
Member: 535033
T959v just need copy efs complete then write bad phone but can not change imei its will just clone your hand phone imei good to bad.
Old 06-29-2011, 08:43   #22 (permalink)
SPTTEAM's Avatar
Member: 535033
br,
So anyone push you about buy our box ? Or u even use our box and talking about it ?
Old 06-30-2011, 03:40   #23 (permalink)
Member: 1597734
no sir im just only sharing my thought and idea my point of view is the more technician in the world...the more demand of your customer buying your product...
about sunday unlocker can benefits your gift not your customer...
but honestly im planning to buy your product this week
Old 07-02-2011, 09:12   #24 (permalink)
najegsm's Avatar
Member: 185396
Sonork: 100.1618832
Hi Dear Members Here Is Repair Guide Android phones Following Problem.
- Imei 0000000000
- Imei 0004999999
- No BaseBand
- No Network Or Call
***** IMPORTANT ROOT IS REQUIRED BEFORE PROCEEDING *****
***** ALSO PLEASE READ CAREFULLY BEFORE ACTUALLY APPLYING STEPS *****
First i give here Some Link For Needed Software and Documents.
Before Everything Need Know How To Backup Efs and Nv_data Look Following Links:
http://forum.xda-developers.com/showthread.php?t=850359
http://forum.xda-developers.com/showthread.php?t=882039
http://forum.xda-developers.com/showthread.php?t=859914&highlight=/efs
For Make Root Use OneSuperClick Software and u can find Software here:
http://forum.xda-developers.com/attachment.php?attachmentid=624175&d=1307984755
For Drivers OF Super One Click Following Link:
http://forum.xda-developers.com/attachment.php?attachmentid=624177&d=1307984774
For Android SDK Click Following Link:
http://dl.google.com/android/installer_r11-windows.exe
Solution For Imei Fix For I9000-I897-T959-P1000 And Other New Android:
Better Before Do This Step Downgrade Your Phone Android 2.1 With Mark re-partition on spt after all step complete can upgrade 2.3.3 withour mark re-partition.
- First Make Phone Root With SuperoneClick
- After root Done Restart Your Phone
- Copy Working Phone Nv_data.bin and put adb sdk tools folder near adb.exe
- Open Usb Debug Mode
- Connect Phone To Usb and install Drivers.
- Open Cmd (Dos Command Prompt)
- Go Adb Sdk Folder with Command
- Enter Following Command
adb shell "mkdir /sdcard/efs"
adb push nv_data.bin /sdcard/efs
adb shell
su (When Press Enter Look Phone Screen Its Will Ask Allow Then Press Allow)
mv /efs/.nv_data.bak /efs/.nv_data.bakk
mv /efs/.nv_data.bak.md5 /efs/.nv_data.bakk.md5
rm /efs/nv_data.bin
rm /efs/nv_data.bin.md5
rm /efs/.nv2.bak
rm /efs/.nv2.bak.md5
busybox cp /sdcard/efs/nv_data.bin /efs/nv_data.bin
chmod 755 /efs/nv_data.bin
chown radio.radio /efs/nv_data.bin
- After Complete This Command Disconnect Phone To Usb
- And Remove Battery ( Dont use Power on Button For Powered Off Phone)
- Wait 10 sec and plug phone back then Power On Phone And Connect Usb
- Enter Following Command Again
adb shell
rm /efs/.nv_data.bakk
rm /efs/.nv_data.bakk.md5
busybox cp /efs/nv_data.bin /efs/.nv_data.bak
busybox cp /efs/nv_data.bin.md5 /efs/.nv_data.bak.md5
chown radio.radio /efs/.nv_data.bak
chown radio.radio /efs/.nv_data.bak.md5
- Now Again Disconnect Usb And Remove Battery Then wait 10 sec and plug Battery and Power on Phone
- Check İmei Of Phone will see still 004999 Dont Worry.
- Now Need Go Spt Support And Download Unlock_imei Patch for this Model
- Write Patch file to phone
- Then Use Spt Mark Repair imei + unlock and Press Factory mode
- Voila Phone Imei turn normal and Work well
I5700 / I5800 And Other Old Android 000000 Imei Repair:
For This Phone Make Root need use kernel file u can find on google with search I5700 Root and also need use sdcard for this procedure
- First Need Make Root To Phone And Get Working Phone nv_data.bin
- Download following Link Files to :
http://forum.samdroid.net/attachments/f28/2083d1281453181-complete-imei-restore-how-stl10.img.zip
- Copy This File and Nv_data.bin file to a sdcard(no need unrar must be same zip name)
- Plug Sdcard to phone
- And In cmd sdk/tools folder enter following Command.
  1. Adb shell
  2. Su (When Press Enter Look Phone Screen Its Will Ask Allow Then Press Allways)
  3. Mount
  4. dd if=/sdcard/bml10.img of=/dev/bml10
  5. When Command Complete Write Reboot and Enter
  6. Wait Phone Powered Complete and enter following Command
  7. dd if=/sdcard/stl10.img of=/dev/stl10
  8. After This Command Complete Write Reboot and Wait Again Phone to Restart
  9. Then Enter Following Command
  10. cp /sdcard/nv_data.bin /efs
  11. chmod 644 /efs/nv_data.bin
  12. Now Disconnect usb wait 5-10 Sec and Remove Battery ( Dont use Power button for powered off phone)
  13. Restart Phone u will see good phone imei come this phone now just connect spt and make repair imei for which imei u want write this phone.
All this step tested By SPT TEAM and all info take from xda-developers and samdroid.net
SPT TEAM
B.R
when i type ''ADB SHELL'' saying adb outoff date
Old 07-02-2011, 09:16   #25 (permalink)
SPTTEAM's Avatar
Member: 535033
update your android sdk
Old 07-02-2011, 16:26   #26 (permalink)
najegsm's Avatar
Member: 185396
Sonork: 100.1618832
when take nvdata phone must ver 2.1?
Old 07-02-2011, 16:26   #27 (permalink)
SPTTEAM's Avatar
Member: 535033
its not about android version its about which version u can make root then u can take nv_data.bin its will work
B.R
The Following User Says Thank You to SPTTEAM For This Useful Post:
Old 07-03-2011, 11:48   #28 (permalink)
najegsm's Avatar
Member: 185396
Sonork: 100.1618832
dear SPT team
i can use p1000 nvdata to i9000 ?
Old 07-03-2011, 12:02   #29 (permalink)
SPTTEAM's Avatar
Member: 535033
dear SPT team
here is nv_data file thanks to kasner for share
Error restoring NVM[SOLVED]
Old 07-03-2011, 17:28   #30 (permalink)
najegsm's Avatar
Member: 185396
Sonork: 100.1618832
- Imei 0000000000
- Imei 0004999999
- No BaseBand
adb shell
rm /efs/nv_data.bin
rm /efs/.nv2.bak
adb shell
  1. Adb shell
  3. Mount
SPT TEAM
B.R
yes done i9000 nvdata REPARE TANKS SPT TEAM YOU ARE THE BEST INTHE WORLD THANK YOU VERY MUCH
Searching Samsung USB Modem...
Model: GT-I9000
IMEI: 000000000000000
Model: GT-I9000
SW: I9000JXJPB
IMEI: 004999010640000
Model: GT-I9000
SW: I9000XXJPK
Searching Samsung USB Modem... detected (COM22)
Reading Phone Info... OK
Model: GT-I9000
Country Code: OPEN
Cal Date: 2010-12-21
Factory SW: I9000XXJPY
Unique Number: 79720000349176
Memory Phone: KB100D00WM(I9000)
SW: I9000JPJPA/I9000OJPJPA/I9000XXJPK/I9000JPJPA
Product Code: XXXXXXXXXXXXXX
Bypass MSL... OK
Repairing IMEI... OK
New IMEI: 357242043639373
The Following User Says Thank You to najegsm For This Useful Post:
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-10-1999 22:36
Page generated in 0.58474 seconds with 12 queries
