11-04-2014, 18:57 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: india Age: 36
Member: 690456 Status: Offline Sonork: 1587650 Thanks Meter: 117 | plz help me on samsung not3 this mobile is verizon usa aloso selact net work gsm and utms mode Last edited by askaralikp; 11-04-2014 at 19:07. |
11-05-2014, 08:35 | #3 (permalink) |
No Life Poster Join Date: Jul 2006 Location: INDIA,TAMILNADU,PATTUKKOTTAI
Member: 304090 Status: Offline Thanks Meter: 210 | One of these functions is to check what kind of SIM card the phone has. When the app notices that the SIM card is not from its carrier, it displays “This SIM Card is from an unknown source” error which cannot be removed. Follow the guide below to fix and disable “This SIM Card is from an unknown source” error. Step 1. In order to remove all the applications, not only disable them, you should be rooted. Follow the guide here to root your Galaxy S5. Step 2. Using a good file explorer, go to System > Apps. There will be listed all installed applications. Step 3. Search and find all the applications which have the carrier name. For example, a Verizon phone has the following application name: vzwphoneservice.apk. Step 4. Once you have found the files, rename the first part and replace it with your carrier name. Step 5. Click save and reboot your phone. |
The Following User Says Thank You to aikonmani For This Useful Post: |
11-05-2014, 15:13 | #5 (permalink) | |
Member: 690456 Status: Offline Sonork: 1587650 Thanks Meter: 117 | Quote:
11-06-2014, 01:54 | #6 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Verizon phones come SIM unlocked. Root using towelroot. Use xposed framework to remove all SIM notifications from the bar. I'm just not too sure What module youd use through xposed. |
