Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 01-10-2012, 17:47   #1 (permalink)
saily's Avatar
Member: 152585
Thanks Meter: 6
Problem with I727 unlock[ANSWERED]
hello sir I am new with spt & i activate spt on ust after getting my user ini i start software it ok but my problem after installing driver of I727 & select modem port & when i click on "FORCE DOWNLOAD MODE" SOFTWARE SHOW ME
Please Wait Enter Downlaod Mode ...
Enter Downlaod Mode OK.
Total Time: 0.35 s
bUT NO ACTION ON PHONE ITS REMAIN IN NORMAL MODE WHERE I AM WRONG PLS CORRECT ME
Old 01-10-2012, 17:56   #2 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Force Download Mode only work if you select correct comport in spt sw that is SAMSUNG MODEM in device manager and in phone must turn on use degub mode without this will never work this button.
Old 01-10-2012, 19:20   #3 (permalink)
saily's Avatar
Member: 152585
Thanks Meter: 6
sir before posting i read all information about what is the procedure of i727 i knew about this i have to select debug mode all step done correctly by me but no luck i also try with volume up + down then insert usb but when i do manually computer did not detect phone IS this possible Its happen due to andriod version is high 2.3.5?
Old 01-12-2012, 08:05   #4 (permalink)
Member: 535033
Sonork: 100.45908
Thanks Meter: 18,870
firs u need do RESET DEFAULT EFS then later uart cable and factory mode should active usb debug and *#9090# select uart
Old 01-12-2012, 11:25   #5 (permalink)
saily's Avatar
Member: 152585
Thanks Meter: 6
what i do for unlock I727
1.Enter *#7284# And Set USB to Modem
Enter *#9090# And Choise USB Diag
Application -> Settings -> Applications -> Development -> USB debugging
2. i start spt.exe & select samsung modem port in port selection then i click on "force on download mode"
& software show
Total Time: 0.35 s
BUT phone remain in normal mode
I change cables, computer, create lock table everything but no result
Old 01-12-2012, 11:33   #6 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Just turn on DownLoad Mode manualy turn off phone press and hold vol down + home and press power and hold all 3 button untile you not see on lcd download mode turn on. After connect to usb cable and in spt press rescan and select comport that in device manager is samsung modem visible.
After press Reset EFS , next turn on fully phone do like you write and use BOX cable S7070/C3300k in spt select correct sptbox comport and select unlock press factory mode.
More simple can't write if still got problem then you should change job.
About this
Should be like this
1. Application -> Settings -> Applications -> Development -> USB debugging
2. Enter *#7284# And Set USB to Modem
3. Enter *#9090# And Choise UART <--- you use box cable mean UART need select , like PRODUCT MANAGER write you before your post.
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.18753 seconds with 10 queries
