Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 03-09-2016, 14:31   #1 (permalink)
Registered User
Member: 1289396
Thanks Meter: 12
program not open
I activated my spt box, plus it does not open the program already uninstalled drivers and put again ... tested it on another computer and it does not open ... I made last setup version ..
follows the serial of the box and user.ini if you need a code to activate
http://www.clangsm.net/lucas/acesso%20spt%20luciano.rar
Old 03-16-2016, 18:09   #2 (permalink)
Member: 1174820
Thanks Meter: 61
spt do not answer here any more, cheater yassax got your money and gone.
you must copy your old user.ini file to folder with spt.exe.
if you lost your user.ini file you must contact to your seller and get user.ini file from your seller.
The Following User Says Thank You to mk.nau For This Useful Post:
Old 03-17-2016, 00:54   #3 (permalink)
Registered User
Member: 1289396
Thanks Meter: 12
I do not remember the contact seller .... tell me the support email?
Old 03-17-2016, 01:51   #4 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,053
Its hard to fix your problem with dead box.
Br,
xerraco
The Following User Says Thank You to xerraco For This Useful Post:
Old 01-19-2017, 02:05   #5 (permalink)
Member: 2667889
Thanks Meter: 4
DongleManager [SPT] v1.6 [06/01/2017 17.59.05]
PC HWID: 46A94120D517243F6A73DA504BE710E2
Card-Reader: Generic EMV Smartcard Reader 0
Locating server...
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
ID: 0000029AAFF83365 HWID: 0003375CFF021982
Authenticating on server...
Authentication stage error:
Server reported error:[0007] No more upgrade logs.
Dongle is up-to-date and has latest firmware. DO NOT try more !
HI
I need solution for this problem
Searching Dongle...
Dongle is not found
all drivers for box and simcard are ok !!!!!!
Old 01-29-2017, 16:09   #6 (permalink)
Member: 2667889
Thanks Meter: 4
ok ok ok sptbox
Locating server...
HI
Old 02-05-2017, 08:54   #7 (permalink)
Crazy Poster
Member: 2458745
Thanks Meter: 14
There's no answer. Just buy activation jajajajaja all users need updates !! Do not sell Infinity equipment activation and / or return activation cost
Page generated in 0.16736 seconds with 8 queries
