Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > SPT BOX
Old 05-11-2012, 23:57   #1 (permalink)
Member: 381487
samsung i9020a repaire xxx [ANSWERED]
I need to repair imei samsung i9020a and I need the procedure and how to connect the mobile correctly ....
Thanks before hand.
Old 05-12-2012, 07:25   #2 (permalink)
Member: 381487
Start ADB Server ...
Device ID:3830B15C11CE00EC
Please Wait For Read Phone Data ...
Model:Full Android on Crespo
OS Version:2.4
Phone SW:I9020UCKB4
PDA SW:I9020XXKA3
IMEI:355266040780957
Please Wait Reset MSLCODE ...
Reset MSLCODE OK. Please Use Factory Mode For Repair IMEI.
Tiempo total: 7.98 s
factory mode and gives me this error:
Por favor espere Introduzca modo de prueba ...
Ingrese modo de prueba OK!
Timeout !
Tiempo total: 110.98 s
Old 05-12-2012, 08:36   #3 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
Instruction is in stick topic read it do all step like you should and will work that all. No help for leazzy peaople that even not read stick topic with instruction.
Old 05-12-2012, 14:25   #4 (permalink)
R@SEL.NET's Avatar
Member: 670820
Sonork: 100.1583728
its need RJ45 3300k auto ignition cable then try 100000000%% tested by me
Old 05-12-2012, 14:54   #5 (permalink)
Member: 381487
gives me this error with the cable C3300K any solution?
Model Name: GT-I9020
S/W Version:
Memory Name:
IMEI: none
WIFI ID Number: 78D6F06EF014
Please Wait Calc Lock Code ...
Tiempo total: 119.26 s
Old 05-12-2012, 19:09   #6 (permalink)
R@SEL.NET's Avatar
Member: 670820
Sonork: 100.1583728
S/W Version:
Memory Name:
IMEI: none
maybe its unlocking log.
tick only imei and type imei
untick unlock and reset.
best of luck
Old 05-12-2012, 20:41   #7 (permalink)
Member: 381487
best of luck
1-
Please Wait Enter Test Mode ...
Enter Test Mode OK!
S/W Version:
Memory Name:
IMEI: none
Read IMEI Data Failure !
Total Time: 121.85 s
2-
Enter Test Mode OK!
S/W Version:
Memory Name:
IMEI: none
Total Time: 119.87 s
the same result.
Old 05-12-2012, 20:49   #8 (permalink)
SPTTEAM's Avatar
Member: 535033
are you write test firmware ? and are u sure your phone rooted allready ???
Old 05-12-2012, 21:10   #9 (permalink)
Member: 381487
1-firmware test I9020AXXKC1_Test------yes
2-root mobile--------yes
Enter Test Mode OK!
S/W Version:
Memory Name:
IMEI: none
Total Time: 120.90 s
Old 05-13-2012, 11:03   #10 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
You still not doing what is write in instruction in stick topic.
Old 05-13-2012, 14:25   #11 (permalink)
R@SEL.NET's Avatar
Member: 670820
Sonork: 100.1583728
1-
please wait enter test mode ...
Enter test mode ok!
Model name: Gt-i9020
s/w version:
Memory name:
Imei: None
wifi id number: 78d6f06ef014
read imei data failure !
Total time: 121.85 s
2-
Enter test mode ok!
s/w version:
Memory name:
Imei: None
Total time: 119.87 s
the same result.
bro,your phone imei 000000000 or 0440???????????
Old 05-14-2012, 17:09   #12 (permalink)
Member: 381487
phone imei is 004999
Old 05-15-2012, 08:35   #13 (permalink)
SPTTEAM's Avatar
Member: 535033
select i9020 then press factory mode
Old 05-15-2012, 18:06   #14 (permalink)
Member: 381487
already tried several times and have had no results with the cable .... and I always C3300K throws the same error ...
I need professional help and extra for this mobile ....
Old 05-16-2012, 14:01   #15 (permalink)
Member: 381487
he hecho todo lo que se me ha indicado y tambien he realizado todo como dice el manual y no he podido resolver con este problema, si la herramienta no soporta este modelo para reparacion de imei no lo agreguen....que por tal razon siempre las herramientas quedan mal.
I have done everything that I mentioned and also I have done everything as the manual says and I could solve this problem, if the tool does not support this model for imei repair .... not add that for this reason always the tools are bad.
Nokia "Contact Service" Repairer Dirk Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 10-04-2011 05:45
Repaired dead phone without backup Prodigal Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-29-2011 11:26
Contact Service Repairer 1.2 by Bartek Allen Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 02-23-2011 08:00
New!! Nokia Flash Checksum And Contact Service Repair HookerGsM Main Sales Section 0 01-02-2001 09:12
WinTesla xxx? MBlade Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-07-1999 11:47
Page generated in 0.61527 seconds with 11 queries
