03-22-2013, 19:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: South Africa/Pakistan
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | samsung i9305 after imie repair no internet no 3g/4g [ANSWERED] Enter Test Mode OK! Model Name: GT-I9305 S/W Version: I9305XXALK5 Phone SN: 0000000000 IMEI: 00000000000000 Write New IMEI: 354478657438254 Exit Test Mode .... All Jobs Done. Total Time: 11.1 s |
03-22-2013, 20:56 | #3 (permalink) |
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | there is no patch for phone its direct imie repair and unlock. what do u mean with patch internet cant work. i dont want to unlock i am talking about ime repair. if i repair imei on it. and then flash. network will disappear after flash. and then i have to repair imie on it again. thats mean problem will start again. |
03-22-2013, 20:58 | #4 (permalink) |
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | * First IN WORLD GT-I9305 Direct Unlock/Imei * First IN WORLD GT-N7105 Direct Unlock/Imei * First IN WORLD GT-P3108 Direct Unlock/Imei/Flash * First IN WORLD GT-I8190N Unlock/Imei/Flash * First IN WORLD GT-S5292 Unlock/Imei/Flash * First IN WORLD SGH-T889 Direct Unlock/Imei * First IN WORLD SGH-T889V Direct Unlock/Imei * First IN WORLD SGH-I317 Direct Unlock/Imei/Flash * First IN WORLD SGH-I317M Direct Unlock/Imei/Flash * First IN WORLD SHW-M440S Direct Unlock/Imei/Flash * First IN WORLD SCH-I959D Direct Unlock/Imei/Flash/MEID * First IN WORLD SCH-I939D Direct Unlock/Imei/Flash/MEID * First IN WORLD SHV-E250L Flash * First IN WORLD SHV-E250K Flash * First IN WORLD SHV-E250S Flash * Auto Root Added for Some Android version like 4.1.1,4.0.4 just use spt mode for make auto root Procedure of new Phone Unlock/Imei(i9305,N7105 etc) * First Put Phone Download mode then select modem port * Press Reset Default Efs. * After Phone Restart Connect to uart cable * Select box Port then Do Factory mode * Phone Should be Rooted.. |
03-22-2013, 21:32 | #5 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Do you root phone before process ? Do you do all step from instruction ? Procedure of new Phone Unlock/Imei(i9305,N7105 etc) Enter in phone *#7284# and choose UART -> MODEM Enter *#9090# And Choise DM over UART * First Put Phone Download mode then select modem port * Press Reset Default Efs. * After Phone Restart Connect to uart cable * Select box Port then Do Factory mode |
03-23-2013, 06:15 | #6 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
1. Flash desired firmware. 2. Use SRS rooting solution -> http://forum.gsmhosting.com/vbb/f606...blets-1606057/ There a is 100% need to say tnx to ssa that provide for us unbelieveble solutions from long time at this place here. 3. Use reset EFS option ( this will f.uck original EFS and you will need to fill new data ) 4. Repair SN ( via USB ). 5. Repair IMEI ( via COM interface ) -> Use *#7284# to select UART -> Modem ( look at wgmmmx1 explanation ). 6. That's all / in 2-3 minutes after restart you will catch network / - in most cases SN will go back to 0000000000 after IMEI repair, BUT radio part will work ( 2G / 3G / Wi-Fi ect... ) ... 7. in most cases update ( FOTA ) or upgrade / downgrade ( Odin ) will compromate current radio again ( IMEI will go to nothing or to factory one ) and you will loose communication, so - you are warned. WBR, DebeliaMark, Bulgaria | |
03-23-2013, 11:24 | #7 (permalink) |
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | my friend thanks for ur advice. first of all i did root . and when i dont root phone same result. second.after repairing imie on this phone sereal no remain as it is . it dont become to 00000. plz dont advise for this phone if u dont know about this phone this phone is difrant than i9300. thanks plz spt team check this problem and then tell if i am wrong. i tried on more than 10 phone. but same result. but if i repari with other tool. internet 3g/4g work perfect but after few houre have calling problem but 3g/4g and internet work. [Utility] SRSRoot: New FREE Root tool for most Android phones / tablets this rooting software do not work on 4.1.2 ok we have root it manualy. thanks for ur information |
03-24-2013, 11:55 | #9 (permalink) |
Insane Poster Join Date: Feb 2010
Member: 1234013 Status: Offline Thanks Meter: 3 | im having a similar problem in my i9305.. after repair imei network is working perfectly fine but each time i change sim card i have to select the network manualy and it cant select the networks automaticly. and i can use all uk sim cards like oragne t mobile o2 vodaphone except 3.. only 3 is not working..any idea how to fix that..? and after repairing imei i flashed it many times with diffrent roms but no signal lost. like normal s3 lose signals after flashing.. |
03-24-2013, 18:25 | #10 (permalink) | |
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | Quote:
03-24-2013, 18:28 | #11 (permalink) |
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | why cant u use 3 network. may phone originality from 3 network. and after repairing imie on it dont work on 3. this kind of problem i also face. |
03-24-2013, 18:44 | #12 (permalink) |
Member: 1234013 Status: Offline Thanks Meter: 3 | no it was from ee..and yes i can use internet 3g though..havnet tried 4g yet..but yes i can use internet and all other sim cards except 3..its just not connecting to 3 network..and even though i flashed the stock firm ware still cant update with kies..offcoure with same eve csc.. |
03-25-2013, 19:41 | #13 (permalink) |
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | what software did u use for root ur phone before repairg imei oni it. i did root phone and then reset efs with usb and repair imie factory mode with uart cable. |
