samsung s3600i network problem[SOLVED] Hi brothers , I have problem with sams s3600i with restart and blinking I flash this one pieces with flash file from spt support then repair imei , and now I have problem with network any solution to repiair network problem ? (how to write good eeprom , maybe this can help) ? |
press restore ee then select eeprom file and write it if havent eeprom file allready then get working phone press backup ee first and make backup eeprom from good phone |
eeprom file inside C:\program files\spt\E2p folder if there havent mean havent this phone eeprom just can read from good phone |
maybe there is a bug in this model on spt program because when i try to Restore ee, then I have Press Power On Key ... Connect Phone OK. Initialize Phone ... Timeout ! Total Time: 22.37 s there is no way to search and set new eeprom from c:/program files so what is the solution ? |
its not bug i think u should try just via rj45 without connect usb and speed select 921600 |
When I change speed to 921600 and use only rj45 com,then still have Press Power On Key ... Connect Phone OK. Initialize Phone ... Timeout ! Total Time: 120.87 s any solution ? |
try another pc i think your pc have installed SE driver or box |
I use, setool, dreambox, so I have installed s-e drivers, this is only way to uninstall it , to flash eeprom with spt ?? |
yes coz swift and sysol platform many phone use se chip thats why make conflict |
ow i have ask setool not work with spt i mean if u install setool worning for spt please spt team explan |
Today, I uninstall all samsung drivers, restart pc, install spt with samsung drivers, but still same problem. |
Man can you read ?? Problem are SE drivers no samsung. Install spt software on computer that you not have SE box installed or uninstall ALL SE DRIVERS after uninstall all SAMSUNG drivers and after try and now will work ok. |
here i have tested mate without test i not answer you here work may be your cable or box problem ? |
