10-24-2011, 22:55 | #1 (permalink) |
Registered User Join Date: Aug 2010
Member: 1359163 Status: Offline Thanks Meter: 37 | samsung s3600i network problem[SOLVED] I have problem with sams s3600i with restart and blinking I flash this one pieces with flash file from spt support then repair imei , and now I have problem with network any solution to repiair network problem ? (how to write good eeprom , maybe this can help) ? |
10-25-2011, 16:45 | #2 (permalink) |
Banned Join Date: Jun 2007 Location: Samsung
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,870 | press restore ee then select eeprom file and write it if havent eeprom file allready then get working phone press backup ee first and make backup eeprom from good phone |
10-26-2011, 14:29 | #5 (permalink) | |
Member: 1359163 Status: Offline Thanks Meter: 37 | Quote:
maybe there is a bug in this model on spt program because when i try to Restore ee, then I have Press Power On Key ... Connect Phone OK. Initialize Phone ... Timeout ! Total Time: 22.37 s there is no way to search and set new eeprom from c:/program files so what is the solution ? | |
10-27-2011, 10:28 | #7 (permalink) | |
When I change speed to 921600 and use only rj45 com,then still have Press Power On Key ... Connect Phone OK. Initialize Phone ... Timeout ! Total Time: 120.87 s any solution ? | |
10-28-2011, 20:46 | #12 (permalink) | |
Today, I uninstall all samsung drivers, restart pc, install spt with samsung drivers, but still same problem. | |
10-28-2011, 22:47 | #13 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
Man can you read ?? Problem are SE drivers no samsung. Install spt software on computer that you not have SE box installed or uninstall ALL SE DRIVERS after uninstall all SAMSUNG drivers and after try and now will work ok. | |
10-31-2011, 09:20 | #15 (permalink) |
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,870 | here i have tested mate without test i not answer you here work may be your cable or box problem ? |
The Following User Says Thank You to SPTTEAM For This Useful Post: |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
