11-11-2014, 22:52 | #1 (permalink) |
Crazy Poster Join Date: Sep 2009
Member: 1119195 Status: Offline Thanks Meter: 34 | Samsung sm-g7102 - grand 2 imei repair solution in spt without rooting STEP 1st- FLASH WITH G7102XXUANC3-G7102ODDANC3-IND.ZIP[ANYWAY IF UR GRAND 2 FIRMWARE VER. INU THEN NO NEEDED TO FLASH] STEP 2nd- SET DO HARDREST WITH CLEAR CHACHE STEP 3rd- SELECT IN SPT SM-G7102 AND CONNECT SET WITH USB DEBUGING ON STEP 4th-AFTER CONNECT SUCCESFULLY DOING RESET EFS DEFAULT WITH MODEMPORT STEP 5th-AFTER EFS DEFALUT SELECT SPT PORT AND FILL UR IMEI IN MASTER AND SLAVE TAB THAN DO FACTORY MODE.. NOW IMEI CHANGE SUCCESFULLY DONE!!! NOW NETWORK REPARING METOD DIAL *#0808# THAN SELECT "DM+MODEM+ADB" NOW SELECT IN SPT TAB SM-G7106 AND SELECT SAMSUNG PORT AND REPAIR 3G NETWROK NOW SUCCECFULLY REPAIRED NETWROK,, DONT FORGET THANXX BRO |
The Following 5 Users Say Thank You to kewat.uk For This Useful Post: |
04-19-2016, 11:09 | #5 (permalink) |
Junior Member Join Date: Apr 2016 Age: 26
Member: 2560981 Status: Offline Thanks Meter: 0 | need QCN, EFS, AND CERT FILE having different imei I tried to change the imei of grand 2. but every time I failed. So if you provide me those 3 files then it may change my imei. |
