04-01-2015, 22:01 | #65 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | You can download here: Index of pub/drivers/ |
04-03-2015, 12:08 | #67 (permalink) | |
Try to make this: 1. Download and run http://download.sptbox.info/index.ph...gleManager.rar 2. Update your box firmware 3. Use Activator and Register your box once again 4. run SPT.exe and try to login to support Waiting for your results. | |
04-03-2015, 18:27 | #70 (permalink) | |
04-04-2015, 10:46 | #71 (permalink) |
Junior Member Join Date: Jul 2008
Member: 812044 Status: Offline Thanks Meter: 0 | Sever error DongleManager version: 1.3 PC HWID: 278D1C0D9890E79252EE99DEF0945938 Card-Reader: DITS DITS USB CCID Smart Card Reader 0 Locating server... Server address found Connecting to server Connection to server failedSocket Error # 10061 Connection refused. |
04-04-2015, 10:55 | #72 (permalink) | |
Try again now. What is the results ? | |
04-04-2015, 10:59 | #73 (permalink) | |
Do you have any problems with it ? I suggest you do not update box if it works well !!! | |
04-05-2015, 13:47 | #74 (permalink) | |
Freak Poster Join Date: Nov 2013 Location: Cairo , Egypt Age: 34
Member: 2062433 Status: Offline Sonork: 100.1586838 Thanks Meter: 24 | Quote:
Serial Number (S/N): 0002C08DB196331F (180365) ==> Box owner: ahmed ==> Box owner e-mail: [email protected] ==> Reseller: gsm-sources ==> Connecting to http://register.sptbox.info/... Searching Dongle... Dongle found ==> Result: 2015.04.05 12:46:44 41.41.142.190 : index : Serial [0002C08DB196331F, 180365] should be activated via Reseller ! Wrong reply from server: 2015.04.05 12:46:44 41.41.142.190 : index : Serial [0002C08DB196331F, 180365] should be activated via Reseller ! Contact to [email protected] Failed: 0002C08DB196331F | |
