02-20-2014, 11:13 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: ...
Member: 824361 Status: Offline Thanks Meter: 25 | Shv-E160L imei problem after unlock as per instruction reset Efs then Rebuild + unlock but after unlock and rebuild imei still 000000000000 phone had imei before unlock here is the log everything shows fine but imei result 000000 Please Wait Enter Test Mode ... Enter Test Mode OK! PDA SW Ver: E160LKLJMK4 CSC Ver: none Phone SW Ver: SHV-E160LKLJMK1 Product ID: M9600B-SCAQSVZD-3.1.613102T Phone SN: R91C92M02Y IMEI: IMEI not active Repair New IMEI:359554048399763 Unlocking ... Exit Test Mode .... All Jobs Done. Total Time: 9.31 s |
02-20-2014, 12:37 | #3 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | but how did you manage Factory mode what did you press to enter phone in factory mode and about network you need to change frequency from setting |
02-20-2014, 14:50 | #10 (permalink) |
Member: 824361 Status: Offline Thanks Meter: 25 | that is a uart factory command i dun think root is necessary once command accepted by phone, if not may need root, btw phone is rooted before e160l (cwm + root) by elunchen - Download - 4shared - samoeun un rooted by this |
02-20-2014, 15:55 | #12 (permalink) |
Member: 824361 Status: Offline Thanks Meter: 25 | as normal after efs reset connect to uart then make factory command with rj45 cable Factory Mode: *#7284# and choose UART -> MODEM after that its connected with rj45 but if u cant access that menu i think u need downgrade firmware whatever that is no use because SPT Solution doesn't work for imei as you can see.. |
02-22-2014, 13:00 | #15 (permalink) |
Member: 824361 Status: Offline Thanks Meter: 25 | are you sure about that? its worked for me what do i say watch this IMG 0598 - YouTube anyway SPT TEAM is not responding to get their attention need change thread title "SPT KILLED IMEI FOR E160L" and ppls will know about it strange nobody reported its all this time |
